Home made tailgates - pictures please!
Discussion in 'The Hokey Ass Message Board' started by ahawes, Sep 4, 2012.
  1. ahawes
    ahawes
    The tailgate that came with the Dodge bed I got for the '58 is thoroughly hammered. I know there are plenty of these style tailgates roaming around but I'd love to see some custom ones that you all have made! Debating whether to make one or track down a stocker somewhere...
  2. propwash
    propwash
    from Las Vegas
    be careful making your own - taillights have a job to do, and all state DMVs publish regulations for how far back they must be visible to the naked eye. Most have some sort of prismatic feature on the inside to ***ist in illumination.
  3. ahawes
    ahawes
    TailGATE, not tailLIGHT.
  4. swade41
    swade41
    from Buffalo,NY
    I was wondering when DMV got involved in tailgate making..lol
    Mine is non functional but I made it none the less, fuel cell is right on the other side by the way.
  5. unkamort
    unkamort
    I made mine out of 1x6 thick wall stock. There are 4 of them under the skin, notched and welded to tube on the bottom and a flat bar on the top. I had a sheet metal shop make the double bend at the top of the outer (back) panel, The inner skin is just flat sheet. I used 3m panel adhesive to bond the skin to the frame and rolled/trimmed the seam at the bottom of the tube. I had to have an iron ****er roll some eyes into flat stock to form the hinge the bottom tube rides in. I did some other non traditional things to it too... but thats how I got the basic shape
  6. cornfieldcustoms
    cornfieldcustoms
    here is one use to make for international trucks
  7. ahawes
    ahawes
    Nice work cornfieldcustoms!
    I like the inner structure idea of yours unkamort, makes sense to make it substantial enough to do work with like that.
  8. unkamort
    unkamort
    It is 'deceptively' heavy. If your going to add weight...
  9. ahawes
    ahawes
    I couldn't help but think to do the same exact thing you are MoparMan, the front panel is basically what is sold as a 'reproduction' tailgate now anyhow, I may end up going that route yet since the front panel of my bed is in nice shape still.
  10. This one is homemade ,so is the latch and hinge.The bed is also.
      320.7 KB
  11. ahawes
    ahawes
    Very cool and clean look!
  12. RMR&C
    RMR&C
    from NW Montana
    Pic of mine being built, it is just single wall...
    Finished with Ford script added....
  13. Looks nice!! How did you add the script?
  14. THE_DUDE
    THE_DUDE
    I made this one. Sometimes I like it sometimes not so much
  15. Dchaz
    Dchaz
    I don't have any pictures but a friend of mine made a tailgate for his model A and made a mold for his press out of bondo and pressed it in. Looked great.
  16. RMR&C
    RMR&C
    from NW Montana
    I cut the script out of an old junk tailgate and used panel adhesive to attach it. Then blended the edges.....
  17. 117harv
    117harv
    THE DUDE, your truck looks sooo good! I like the tailgate, nice to see your didn't bead roll a Bow Tie into it as it's so over done...hope I didn't offend anyone who has one with that statement:eek:
  18. Chaz
    Chaz
  19. Drewski
    Drewski
    Built mine for 55 F100
    Turned out a little heavier than stock.........32.5 to 26.5 pounds.
  20. gasserdan
    gasserdan
    Man thats a fantastic job! You do great work.
  21. jazz1
    jazz1
    I bent some tin into a pan. put a frame of 1" square tubing inside, welded a flat piece on tin on the inside so the tailgate is smooth inside and out..welded a piece of 1 1/4 tube stock on top...nothing fancy
