Help on Av8 Front End
Discussion in 'The Hokey Ass Message Board' started by BanjoBoy, Sep 4, 2012.
  1. BanjoBoy
    BanjoBoy
    Hello Everyone.
    Need some help and this place has always done just that.
    Here we go
    Im Building an AV8 (1930 Model A Roadster)
    - Using Model A Frame
    - 33-34 Unsplit Wishbone
    - 32-36 Non Heavy Axle or 32 Heavy Axle (Still Undecided but have both)
    My only confusion here is, Which Spring Perches Do I need?
    Model A ? or 32-34?
    Im sure this has been covered before but I tried searching and no luck?
    Thanks
    BBOy
  2. BanjoBoy
    BanjoBoy
    Obviously Model A Ones are Cheaper and easier to find as opposed to 32-34 perches
    Also, Im going to Run Early Style Shocks (Houdaille)
  3. Groovybaby6
    Groovybaby6
    from Denver
    '28 thru '34 should be the same and will fit in the axle but the I.D of the spring perch
    for aftermarket stuff is different than original Ford.
    What spring are you using, an old Ford one or aftermarket?
    The shackles you'll need will depend on the I.D of both parts. Don't buy shackles until you figure out what you need. Since you are in LA, go see Jim Gordon at Vintage Ford Parts in Rosemead, he'll have what you need and they'll be better quality than Speedway.
  4. BanjoBoy
    BanjoBoy
    Thanks for the info
    Running Original Model A Front Spring
  5. Groovybaby6
    Groovybaby6
    from Denver
    You should be able to find real Model A spring perches but, usually they are worn out or have been beaten out of the axle with a hammer or the threads are screwed up.
    Mac's and some others repop those with the ball on top for the Houdaille shocks in case you can't find any good og parts.
  6. BanjoBoy
    BanjoBoy
    So shock ball placement does not change with the Model a perch vs 32-34 ?
  7. lowsquire
    lowsquire
    from Austin, TX
    It does. the shock ball is lower and closer to the shackle on an A model one.
  8. BanjoBoy
    BanjoBoy
    So let me Get this straight for my own piece of mind
    28-34 Spring Perches all have the same OD into axle ID
    Spring Perch hole to leaf eye hole ID changes on 28-31 compared to 33-34 (33-34 is bigger)
    Shock Ball Is located Higher on 33/34 than 28-31 (lower placement)
    Bottom line is Anything Can Be made to work!
    Sounds Like Hot Rodding to me!
  9. BanjoBoy
    BanjoBoy
    So many variations
  10. 117harv
    117harv
    Here is a 32-34 perch bolt, (left) and a model A, as far as I know they have the same spring bushing id. The 32-34 spring eyes are bigger than model A though.
  11. pasadenahotrod
    pasadenahotrod
    from Texas
    All 28-34 spring perches and 35-48 Axle bolts have the same diameter shank and threads and use the same tapered castle nut for installation. The lengths from the top taper to the bottom vary though.
    The spring perches have the same ID hole for the shackle but 28-31 and 32-34 use different style shackles. 28-31 has simple steel bushings whereas the 32-34 have a pin/rubber bushing/steel sleeve combo.
  12. So-Cal Speed Sacramento
    Alliance Vendor
    from Sacramento
    The diameter and taper where it goes through the bone and into the axle is essentially the same from 1928-1948. Model A perches and early V8 perches only differ in the ID of the shackle bushing hole and the locations of the mechanical brake actuator eyelet and the shock ball.
    Even though the perch shackle bushings are different, the aftermarket ones makes swapping springs painless. I ***ume you will be running juice brakes and so the eyelet will be for show. If you are able and willing to make some minor modifications the shock ball won't really be an issue either.
    That being said, it's just a question of where you want to spend your money. You can get an NOS set of A perches for a fraction of the cost of some 1932-1934s. BUT people who know will know and people that don't won't care. It's all up to you.
  13. BanjoBoy
    BanjoBoy
    Jack Pot
    117Harv
    Thank you
  14. BanjoBoy
    BanjoBoy
    amazing info and Im grateful for the sharing guys
    beyond thank yous to all of you
  15. BanjoBoy
    BanjoBoy
    Okay heres the latest
    I thought I had a model a spring, however it is a 32 Spring
    So,
    -32 Spring
    -Model A Spring Perches
    -Houdaille Shocks
    -32 Heavy Axle
    -33/34 Unsplit Wishbone
    -Juice Brakes
    What Shackles / Shackle Bushings Do I need?
    Should I even Run Model a Perches? Or just find 32-34 Perches?
    Will the Houdaille Shocks Line up Better With The A Perch or 33-34 Perch?
    Thanks
    BBOY
  16. ChuckleHead_Al
    ChuckleHead_Al
    Did you ever figure it out? I'm going thru the same thing. Bump
  17. visor
    visor
    from Missouri
    Have you thought how you are going to attach the rear of the un-split bones?
    If you are going to use a '32 type K-member, the 33/34 bones are to short.
    You will need '32 bones or add length to the 33/34's. I would use the
    32/33/34 perches also.
