best Vega box mounting bracket for 32 frame
Discussion in 'The Hokey Ass Message Board' started by TBonez, Sep 6, 2012.
  1. TBonez
    TBonez
    Ive got a 32 frame from Squeek for my 29 Tudor and looking for the best mounting bracket for a Vega box. Most of the ones Ive seen in catalogs dont look strong enough. Thought Id try here for some help. Any advise would be greatly appreciated. Below is a pic where Im at so far.My friend Sam ( SamIam ) is giving me a hand with the build. Its running a 327 with 3 deuces, turbo 350 transmission, Ford 9in rear end, 35 Ford wires with 7.50 16' out back 5.50 16" up front, exhaust manifold off an early Corvette so I can mount a generator. Mild 3" chop and body on top of the rails. Interior 35 Ford dash w/ early Stewart Warner guages for the important stuff and an old speedo out of a F-1 pick up. Seats are buckets out of an early T-bird. Lookin forward to posting pix here of the build as it goes.
  2. metal man
    metal man
    Pete & Jake's makes the best one I've used (dozens of them). Don't use the one Speedway sells.
  3. yes , Pete & Jakes is good
  4. Unkl Ian
    Unkl Ian
  5. yes , they are easy to make. i bought one Pete& Jake's bracket and have copied it many times
  6. man-a-fre
    man-a-fre
    I agree with making one too as others have said but i also really like the ch***is engineering inc. mount part# ar2130 due to it gets the box closer to the frame.
  7. opu27
    opu27
    from ONYX,CALIF
    you can use the same bracket for 525 steering gear. it's just a little bigger and makes steering a lot better. might need a small spacer. ****
  8. 40FordGuy
    40FordGuy
    Agree....C.E., or Pete and Jakes.
    4TTRUK
  9. TBonez
    TBonez
    Thanx everyone. Going to check out Pete n Jakes and C and E's.
  10. 327-365hp
    327-365hp
    from Mass
  11. BAD PENNY
    BAD PENNY
    from mass
    Here's a pic of the ch***is eng. vega box mount and their SBC motor mounts in my deuce frame...they nest together really nicely.
  12. Chemin
    Chemin
    http://www.welderseries.com
    Try Welder Series. They have lots of other bracketry and such too.
    Pretty much every Model A and '32 Ch***is component you can think of.
