Repairing a punched out lock hole - trunk lid.
Discussion in 'The Hokey Ass Message Board' started by umassjj, Sep 6, 2012.
  1. umassjj
    umassjj
    from MA
    This falls pretty low on the list of things to deal with on my '64 Comet at the moment, but I've had it in the back of my head and figured I'd ask. Other than someone knocking the lock out of the trunk lid, the lid is in great shape. Don't have the cash or the want to go to a fibergl*** lid and I've noticed that they don't seem to make patch panels for this situation.
    Any of you guys ever cobbed anything together to save a trunk lid?
  2. Just take your time and tap and dolly it out.
  3. i think i have seen patch for that , not sure where.... just keep looking
  4. Noland
    Noland
    cut a lock hole out of something and patch it into yours. Or make one
  5. squirrel
    pictures? we can't see how stretched the metal is, or if it's torn, or what....
  6. umassjj
    umassjj
    from MA
    I'll shoot a couple when I get home tonight- should have thought of that. Thanks for the responses fellas
  7. Rusty O'Toole
    Rusty O'Toole
    Weld up the hole for a custom look. Use an electric latch salvaged from a minivan or car with electric latch. Don't forget a backup, using a long choke cable leading into the back seat area or door jamb.
    Or, hammer and dolly the hole and put a new lock in.
  8. Had a patch in my hand last month.
    Had about 10 on the wall.
    William wolf supply, Cleveland ohio
  9. Stu D Baker
    Stu D Baker
    from Illinois
    They make lock cylinder patch panels. Most body supply houses that also sell generic patch panels have them. There are a few different styles (flat hole, recessed, etc.) so you can pick the one for your car. Stu
  10. umassjj
    umassjj
    from MA
    Here's a pic I shot just a little while ago. The hole is toast. I think I'm either looking at a patch or welding it up and using a solenoid to pop the trunk.
  11. umassjj
    umassjj
    from MA
    thanks 31 Vicky! I'll call those guys tomorrow.
  12. squirrel
    that doesn't really look like it was punched thru, it looks more like it was wrecked and fixed, and the bondo was so thick that the lock retainer didn't stay where it belonged, and the lock rattled around and fell out.
    We used to make them look a lot worse when we punched the locks out at the junkyard
  13. mikhett
    mikhett
    from jackson nj
    Use a Knockout plug from an electrical junction box a coupla bux at home cheapo or lowes.Grind off the galvanizing befgore migging it in.No mig welder? Use JB Weld.
  14. JimInrADFORDva
    JimInrADFORDva
    Yeah, I gotta agree that it looks like a really poor repair job. Either cut it out and weld in a replacement or cut it out and weld in a flat panel and use an electrically operated latch.
    +1 on the cable-actuated back-up.
  15. niceguyede
    niceguyede
    from dallas
    Here's a simple trick, but will possibly require some welding...find a socket that will fit the lock recess( usually between 1/2-5/8) and use it for a dolly on the outside where the lock cylinder goes. Hammer it back into shape from the inside of the trunk. If you can't get a hammer in there(this is where the welding would come in) cut out an access panel inside the trunk. Hammer and dolly back to stock, weld and grind the cracks and tears, and weld the piece you cut out back in. No use for electric chinese **** that will fail you when all you need is your cooler full of beer!!
  16. niceguyede
    niceguyede
    from dallas
    btw... a little file work might be in order to get the cylinder to fit just right.
  17. umassjj
    umassjj
    from MA
    Freakin' A! That why this place is the cat's ****! Awesome.
  18. tnich123
    tnich123
    That VW latch is from a Thing. They are out there but not as common as the VW bug. I would consider a later VW Jetta or golf latch they are more common and are used in most of the fibergl*** bodies.
