1956 F350 Conversion
Discussion in 'The Hokey Ass Message Board' started by jsullivan317, Sep 2, 2012.
  1. jsullivan317
    jsullivan317
    from Omaha, NE
    Have an opportunity to pick up a Ford F350 1956 for free. It needs quite a bit of work and I want to somewhat convert it back to a F100 style truck. I've heard that the front fenders are bigger and there may be some differences in the frame. Anyone with some knowledge on this be able to help me on this. It has a flatbed with duallies and I plan on replacing the rear end and front suspension and finding a bed for it. If the frame is larger, is there going to be issues with the drivetrain fitting?
    Thanks
    Josh
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Don't think the fenders are bigger rather it is the wheel cutouts that are taller on the larger wheel trucks, 3/4 ton and up.
  3. My uncle has had many of those '53-'56 trucks. I know the fenders have a bigger opening. Don't know about the frame. Will try to find out. Gene.
  4. Carbs & Chrome
    Carbs & Chrome
  5. jsullivan317
    jsullivan317
    from Omaha, NE
    Thanks guys!!! That helps me out. I'll be sure to post pictures.
  6. willymakeit
    willymakeit
    Do not s**** the frame! Someone building a one ton will want it. There not easy to find.
    I have a friend who has a crew cab 3 door built in 56 I'd like to have.
  7. Shaggy
    Shaggy
    from Sultan, WA
    What is wrong with a 3/4 ton? a dana 60 should be a bolt in too....
  8. Crookshanks
    Crookshanks
    You had me at "1956 for free".
  9. jsullivan317
    jsullivan317
    from Omaha, NE
    So is there anything wrong with just keeping the frame that it is on even though it is bigger?
    Josh
