240 Ford 6cyl carb replacements, help!
Discussion in 'The Hokey Ass Message Board' started by hotrodwelder, Jul 21, 2012.
  1. hotrodwelder
    hotrodwelder
    I have a '67 F-100 w/ a 240 6cyl-4spd trans 2wd. the ford/autolite carb is shot, shafts are worn and its just plain worn out. Engine is all new overhaul with a stage 2 cam and s.s. valves for our ****ty fuel we can buy..
    What i need is some info on a replacement carb that peeps have had good luck with. 6 cyl stuff is new to me so i'm at everyones mercy..
    Thanks,
    Hotrodwelder
  2. 65EconoPU
    65EconoPU
    I switced from the Ford/Autolite to a YF Carter on the 240 in my 65 Econo. went with the Duraspark dizzy with GM module as well. What a diferrence. Plenty of spark for a smooth idle and quick cold starts.
  3. sunbeam
    sunbeam
    Holley 1920 series One from a slant 6 dodge pu works best.
  4. carbking
    carbking
    The old "my dog is bigger than your dog" question.
    Both Carter and Holley produced carburetors for the Ford 240 CID engine as original equipment.
    Follow this link to find the identification number of many different Autolite, Carter, and Holley carbs used as original equipment:
    http://www.thecarburetorshop.com/TruckkitsF.htm#TkitFord
    Which is best? Probably the one YOU (or your tuner) is most comfortable with!
    Personally, I would rank them Carter, Autolite, Holley.
    The Holley has the advantage that parts are more readily available, and the disadvantage of using 20~30 percent more fuel than either the Carter or the Autolite.
    The choice is yours.
    Jon.
  5. FrozenMerc
    FrozenMerc
    An Offy Intake and small Holley 4 barrel (390 or 500 cfm) makes a great replacement for the OE stuff. :D
    David Chandler likes this.
  6. BISHOP
    BISHOP
    Hotrodwelder,,,Do you have the Autolite 1100....
    Do you want to sell it. PM me if you do.
  7. vint
    vint
    I put an Autolite 2100 from a 352 on my 240 F-100 and it worked out nicely after fiddling with the linkages
  8. jack orchard
    jack orchard
    FrozenMerc: Just saw your motor today. I like it. Clean , simple and down to business. How does it run? Best of luck...jack
    Long live the longmotor.
  9. FrozenMerc
    FrozenMerc
    It runs great, pulls hard, and gets 18 mpg all day in a very unaerodynamic truck.
  10. TexasPanMan
    TexasPanMan
    What did you have to do to make the carter Yf work with 65 240 motor? Getting ready to do the same but need more info, thx!
