ID this Flathead .
Discussion in 'The Hokey Ass Message Board' started by Ester Eddie, Sep 9, 2012.
  1. Ester Eddie
    Ester Eddie
    from Alaska
    My friend said he thought it was a "Continental " engine .Does anyone know by looking at it.I don't know much about Flatheads period .He turned the oil pan around to put it in a little dozer but took ended up taking it out a while back and now its mine.:)
  2. Ester Eddie
    Ester Eddie
    from Alaska
  3. RichFox
    RichFox
    The DDCP cast into it makes me think of Chrysler DeSoto, Dodge, Plymouth. I don't know.
  4. Ester Eddie
    Ester Eddie
    from Alaska
    Me either . thanks Rich
  5. 1950Effie
    1950Effie
    from no where
    Looks like a 218 CDPD flat 6.
  6. squirrel
    yup, that's a Chrysler corp trademark, not likely to be a continental...more likely to be a Dodge, Desoto, Plymouth, or Chrysler engine.
    look for a stamped number
  7. MERC 55
    MERC 55
    can you give us a picture of the other side, intake/exhaust side?
  8. Ester Eddie
    Ester Eddie
    from Alaska
    Awesome. I plan on putting it in my 41 Plymouth . He has transmission too .
  9. telecustom
    telecustom
    from Langey, BC
    Yep I would say, I got an early 50's dodge near me and that engine looks the same.
  10. Ester Eddie
    Ester Eddie
    from Alaska
    I didn't take a pic of that side. I was excited and distracted by this gift and other stuff at his place..I will when it gets here.
  11. squirrel
    look for the stamped number here on the side of the block, near the top front. Should have a letter and numbers sequence at the beginning like P10 which would be for something like a 1940 plymouth. P plymouth, D dodge, C chrysler, S desoto
  12. Ester Eddie
    Ester Eddie
    from Alaska
    Cool .He said he got it in the crate and ran smooth . He is an army truck guy and thought it was for them.
  13. Ester Eddie
    Ester Eddie
    from Alaska
    I will check again .I wish I took pics of the other side too. Here is the transmission.
  14. squirrel
    wow, with that remote control transmission, it probably is.
  15. Ester Eddie
    Ester Eddie
    from Alaska
    Remote control ? Well once again thanks guys for the info and helping me out and answering my newb questions .
  16. squirrel
    The shifter box on top of the transmission...for a remote shifter, instead of a normal floor shift.
  17. Ester Eddie
    Ester Eddie
    from Alaska
    Oh ..Like a 3 on the tree ? I'm just happy things and parts are coming together for me up here.
  18. gimpyshotrods
    gimpyshotrods
    An old codger once told me that the letter in the DPCD embossing that is exaggerated indicates which division the part came from. In this case, it is the P. I have seen other exaggerated letters, matching the division of the part origin. Not sure if this is all bunk, though.
  19. squirrel
    No, like a rear engine bus or something.
  20. squirrel
    I'd be curious how the Ds could be extended? the P is a natural.
  21. gimpyshotrods
    gimpyshotrods
    The D's I have seen where simply larger than the other letters (taller, slightly wider). I have seen a big C too. Might just be casting mold variances.
  22. Ester Eddie
    Ester Eddie
    from Alaska
    Well shoot ..... Do you think that would work in a 41 Plymouth ? I'm sure a guy can get anything to "work". Maybe the transmission thats in it already will bolt up to this engine.Can I turn it into a floor shift?Damn :eek:
  23. squirrel
    If you have the complete transmission and bellhousing then you would probably be better off using what's in the car. It's hard to say...you're going to have to look things over carefully. Often, car and truck bell housings and flywheels were different.
  24. Ester Eddie
    Ester Eddie
    from Alaska
    Thanks squirrel .Yeah I will have to have a closer look at what I'm working with.It will all work out in the end.It must!
  25. arkiehotrods
    arkiehotrods
  26. Ester Eddie
    Ester Eddie
    from Alaska
  27. Ester Eddie
    Ester Eddie
    from Alaska
    I saw this 4 banger today at work ..It's not stuck.I think it ran a generator . I wonder what kinda transmission would hook up to it?
