History Why so few sedan gas class cars?
Discussion in 'The Hokey Ass Message Board' started by II FUNNY, Sep 9, 2012.
  1. II FUNNY
    II FUNNY
    I was wondering why there were so few sedan gas cl*** cars?
    I understand your top gas cars were really light and so these were mostly small cars, but what about c/g on down? If the idea was to move the weight of the car up and back on the rear wheels , then wouldn't it have been an advantage to start with a sedan? If I am correct they were only allowed to have 150lbs. of removeable ballast, so having a sedan would have allowed you to have ballast there before adding any correct? The gl*** and sheetmetal at the back of a sedan was at least 12" farther back than on a coupe, so technically they would transfer weight better right?
    I thought someone on here would have to know why?
    Was it a looks thing?(most comp cars were not about looks)
  2. II FUNNY
    II FUNNY
  3. newjersm3
    newjersm3
    Wives and kids don't really care for open headers?
  4. Most tri five chebbies were 2 door sedans. :D
    I can't answer your question, I think that the coupes got more paper because coupes are more popular. The cl*** was called gas coupe/sedan for a long time.
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
    Probably one reason is that coupes were considered to be cool and sedans were for Grandpap. I'm sure weight had a lot to do with it too.
    There were some notable exceptions because a few guys built 4 door Willys into g***ers, as well as some 32 Ford Tudors I can remember seeing. But the majority of guys who went out looking for g***er material first looked for a coupe.
    Don
    Andamo likes this.
  6. 50dodge4x4
    50dodge4x4
    Sedans just weren't as cool as a coupe.
    Most sedans were a couple hundred lbs heavier then their coupe counterpart.
    The cheapest way to go faster is to start with a lighter car. Gene
  7. I think that being stylish is the biggest part of the equation.
    My '38 tudor was a 2800 lb car, what did a tri five chevy weigh from the factory?
  8. Because the right wheels don't look good on a sedan
  9. Don's Hot Rods
    Don's Hot Rods
    from florida
    Here are a few I found with a quick search:
    Don
  10. II FUNNY
    II FUNNY
    I know there were a few Studebaker sedans too, but I was wondering if what I was thinking made sense? If your going to lighten the car as much as possible then add ballast at the back wouldn't a sedan be a better choice from the start?
    I guess I would probably have run a coupe too because they do look cooler (Austins Anglias excluded)
  11. Unless they were crager's of course.:D
  12. jcmarz
    jcmarz
    from Chino, Ca
    you guys need help from Dr. Phil. Tri-5 sedans rule
    volvobrynk likes this.
  13. HA HA No ****!
  14. Larry T
    Larry T
    I don't think I ever saw an Anglia (or Austin) coupe. :D
    OK, before everyone starts posting pictures, I know there were "late model" Anglia coupes.
  15. cheveey57
    cheveey57
    Never a fan of the sedan the roofline is a bit longer and the hardtop is just sportier and lighter ( for racing)
  16. Larry T
    Larry T
    I'm pretty sure a sedan is lighter than a hardtop.
    Doctorterry likes this.
  17. cheveey57
    cheveey57
    Damned if aren't right Larry the hardtop is heavier by @ 40 lbs. Go figure.
  18. el Scotto
    el Scotto
    from Tracy, CA
    Yep, I'm going to go with the "Four Doors are for ****s" sentiment. :eek:
  19. flatheadpete
    flatheadpete
    from Burton, MI
    That Vicky is sssooooo cool. Damn.
  20. 'Cause too many guys are coupe'd up!
  21. southern thunder
    southern thunder
    I saw a 48 anglia "coupe" at a streetrod meet once, somebody cut it up to make a 3 window. personally, I thought it looked awful. as for sedans, (4dr.)The g***erp***er in orginal form, and the Jr. thompson built prefect are 2 bad rides. as well as some austin devons, and willys sedans. imo.
  22. Normbc9
    Normbc9
    These are all sedans or wagons aren't they? Still running too.
    Normbc9
  23. jimmy1931
    jimmy1931
    This is officially a 5 p***enger coupe according to Chevrolet & the ***le, but most people call it a sedan.:)
  24. BOBBYA312
    BOBBYA312
    from Ala
    Couple of Willys sedans that ran locally but were national record holders. Paul Contorno/Glenn Houser "Worlds Wildest Willys" C (?) Gas record holder-can't find a picture. Another was the "Chicken Picker" belonged to Bill and M.A Madden D (?) Gas record holder. These cars had small C.I. SBC and screamed when they left the line at the Mountain.
  25. Sphynx
    Sphynx
    from Central Fl
    Owww that takes my breath away. That is a beautiful sedan / coupe. I was going to say when I see a sedan pre 50 I think station wagon....... But you shut my mouth before I could open it.
  26. Rocky Famoso
    Rocky Famoso
    The term Sedan does not necessarily mean it is a four-door.
    Most G***ers in the lower cl***es were two door sedans because they were lighter than a four door, and had more body rigidity than a hard top due to the "B" pillar (center post). Usually cheaper to.
  27. Rusty O'Toole
    Rusty O'Toole
    4 doors weren't cool. The younger crowd doesn't have the prejudice against sedans because, there aren't any cool cars made anymore anyway.
    A few guys used station wagons and sedan deliveries because they had more weight over the back wheels. But that level of dedication, to give up cool looks to go fast, was rare.
  28. jimmy1931
    jimmy1931
    Everyone calls my '31 a sedan. It is officially a 5 p***enger coupe..
      98.1 KB
  29. Dale Fairfax
    Dale Fairfax
    I don't think it ran in a Gas coupe/sedan cl*** but Jack Roush (and his partner Wayne Gapp) tore 'em up with a 4 door Maverick.
