49-51 Mercury quarter glass solutions
Discussion in 'The Hokey Ass Message Board' started by GreggAz, May 24, 2009.
  1. GreggAz
    GreggAz
    there is another thread running about Merc quarter windows here : http://www.jalopyjournal.com/forum/showthread.php?t=185012
    We are working on a customer's merc, and the owner was not happy with the seal of his hinged rear windows. He requested that we make the gl*** fixed, and have the garnish moldings and trim chromed and polished.
    After dis***embling everything, we had the outer trim polished and reinstalled it on the lip around the opening with new clips.
    We then took the car to our favorite gl*** shop and asked them to cut new gl***, and use urethane to glue it into place. They did this, and did a good job of smoothing the glue out on the outside where you can see it.
    I then took the stock swing out garnish ***embly
    dis***embled it, and trimmed off the channel that the rubber registers into.
    I made one cut with a cut off wheel, taking off the side and bottom of the channel, leaving the side that is spot welded to the garnish.
    Then I located the spot welds ( long, not round, which made it difficult to use a spot weld cutter) and I used a cut off wheel to grind through the welds, and remove the remaining strip.
    I then used a grinder to clean up the welds.
    With the modified garnish back in the car, there is now a gap between the garnish and the gl***, where I will use some closed cell foam rubber to fill the gap after the garnishes are rechromed.
    This was our solution, as we could not find a rubber product we liked that would seal, and hold the gl*** in place. The down side is that both the gl*** and the outer trim are now glued to the body of the car.
  2. Mr48chev
    Slick, I know from experience that those quarter windows get cracked on a regular basis if you actually open them when you are using the car.
  3. GreggAz
    GreggAz
    back up for all the custom guys who were at PasoMaria
  4. GreggAz
    GreggAz
    wow did this drop, no input?
    back up for tech week
  5. Looks good, hope I can eventually find someone local to me to make nice window trim for my Merc.
  6. 46fatford
    46fatford
    Are those factory plated garnish moldings from a Monterey? Also in 1950 Mercury sold a cheap model that had fixed 1/4 windows. Unsure how they mounted/sealed the gl***.
  7. GreggAz
    GreggAz
    In the other thread there was discussion about the factory parts, and it seems that there is no reproduction of the weatherstripping that was used. There are a few creative solutions, and this was ours.
  8. hot rust
    hot rust
    where the gl*** meets the body, first there is a foam tape available for ford trucks that act as a dam for urethane on i believe 97 and up years around the back gl*** . it is uv safe and lasts(ie: it doesnt break down in a short period of time) i did my buddys car on the back gl*** and quarter gl***es over 4 years ago no problems. you install the foam to the body and then build the urethane past the foam. then press the gl*** against the foam for a seal on the urethane. you could then add another strip of the foam to the modified moulding to cover the gap left by the modification to it and it creates a very neat finished looking edge to be proud of. no pics but i will get some of the finished project and post tomorrow.
  9. chaw5634
    chaw5634
    Hi,,what happened to the pictures in this thread?
    I really would like to see them, can you help me please?
    Regards
    Carl
  10. GreggAz
    GreggAz
  11. chaw5634
    chaw5634
  12. Hot-Rod-Howard
    Hot-Rod-Howard
    Really Nice!
    I am looking to do this exact this thing, only I don't have the garnish molding and cannot find any anywhere. Anyone have any extra's they are looking to unload? I was also wondering where you got the little clip for the outside trim?
