Customs 1954 Ford Ranchero
Discussion in 'The Hokey Ass Message Board' started by deek, Sep 11, 2012.
  1. deek
    deek
    from Tulare,CA
    I've been wanting to build a 54 Ranchero for a while now. It all started about 3 years ago when I was looking for 52-54 Fords for parts and ended up with 2 wagons, 2 Ford sedans and 2 Merc sedans. None of them that complete or nice, but I figured with 6 cars, you should be able to build at least one right?!
    I'm starting with a 2 door wagon and using the wrap around sedan rear gl***. I told my friend John about my plan and he found this pic and e-mailed it to me.
  2. deek
    deek
    from Tulare,CA
    I pulled the body and hammered out the big dents and sent it and the frame to the blasters. Here's some before shots.
  3. deek
    deek
    from Tulare,CA
    Now it would be fun enough to just convert it to a Ranchero, so after some rocker panel work, a mild 1-1/2" section was next. And after remarking it about a dozen times, here's what I came up with
  4. deek
    deek
    from Tulare,CA
    And this is what happened after my buddy Jerrad and I went after it with some cut off wheels
  5. deek
    deek
    from Tulare,CA
    Back on with the top half of the body and mocked up with the door. That's where it's at so far. Drivers door, fenders and wheel wells are next. After that, it's time for the top. And that's when I'll know if I ruined a wagon or not :D
    Deek
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    Lot's of cool pictures on Google Images under "1955 Ford Ute" I thought this pic was a winner. Also since you will have some leftovers from the parts cars,maybe pic#2 might be next?? :D
  7. HOTRODPRIMER
    HOTRODPRIMER
    I'll be following this build. HRP
  8. Gotzy
    Gotzy
    This one is going to be fun, sub'd in
  9. Rikster
    Rikster
    Sectioning an inch and a half.... and using and sedan rear window!!!
    Now you have my attention!
    This will be very interesting to watch.
  10. bonez
    bonez
    from Slow lane
    Beautiful so far. I like the fact you are using the stock suspension.
  11. sko_ford
    sko_ford
    What no gl*** top? I kid I kid. Pretty cool so far.
  12. general gow
    general gow
    MODERATOR
    well, judging by the section job, i'd say your ranch' conversion will go quite nicely.
    you did that section job so well that it's hard to believe you made enough cuts to do it.
    can't wait to see where this goes.
  13. junkman8888
    junkman8888
    Greetings! I think you're going to be disappointed with the way the sedan back gl*** flows, I think a better choice would re-use the rear portion of the station wagon roof or maybe use the back panel from a mid '50 chevy truck. At this point it would be easy to take some pictures of your car, print out a few copies then "cut and paste" until you like what you see. Best of luck with your project, Mike.
  14. I agree that the sedan rear window just doesn't lend itself to a ranchero rear gl***. The wagon gl*** would look better with more correct proportions. The wraparound gl*** is just too large and round for a short cab.
  15. thunderbirdesq
    thunderbirdesq
  16. Stoke 49 Ute
    Stoke 49 Ute
    mine is coustom cut gl*** it's flat so pretty easy to install
  17. Joey7319
    Joey7319
    49 ute, thats one cool ride you have. I dig it.
  18. Squablow
    Squablow
    I like the concept and I think you did a fantastic job with the sectioning so I'm sure the metalwork execution will be top notch.
    I'm not going to question your plans for a rear window but I will say that there are some really talented photoshop artists on the HAMB who could knock out a couple quick renderings of what it will look like with the sedan window versus wagon window versus something from a donor truck.
    Seeing what it will look like done really gives an inspiration to finish it, but also sometimes makes you change your mind on the direction you want to take it.
    Also, I've heard that a Victoria windshield is an inch or two shorter than a sedan windshield and can be used in a mild chop without cutting the gl***. Not sure if you'd planned anything like that but might be worth mentioning.
    Looking forward to seeing more pictures.
  19. plymouth1952
    plymouth1952
    nice cutting ! Gl*** top ? I **** that Idea.
  20. koolkemp
    koolkemp
    I love the mild section job, too often guys take way too much out, but I think you nailed it! As for the back window I am not a big fan of using the sedan backlight...why not post some pics in the m***ive photoshop thread, and ask if some of the guys could do some different renderings for you..I am looking forward to following your progress!!
  21. koolkemp
    koolkemp
    Neat ride Stoke! I would love to see some build pics!
  22. Jims35
    Jims35
    Looking good and i plan to follow the progress.:cool:
  23. Stoke 49 Ute
    Stoke 49 Ute
    49 biz coup was sectioned 4 inches 25 years ago then sat in front of a body shop in FL then years later was chopped 3 inches and cut into a Ranchero there it sat till i found it 5 years ago and did all the running gear
  24. rustyfords
    rustyfords
    from Conroe, TX
    Looking great so far....I'll be following along.
  25. Mr48chev
    This might just get interesting, I'm in to follow along.
  26. chopd top
    chopd top
    from Florida
    I like how you've sectioned it. I'll follow along to see what you do with it.
  27. afaulk
    afaulk
    That sectioning job will have folks scratching their heads "now whats different about this"
  28. Kustom7777
    Kustom7777
    from Austin, TX
    love that,,,,great job on the section...heres a 56 crown vic ranchero i owned a few years back,,,purchased in primer and had it sprayed pearl white w/ red flaked roof, lowered it, added skirts,,,sold it to some guy in virginia
  29. deek
    deek
    from Tulare,CA
    Thanks for the input guys!
    I did think about that! But it's too long and would interfere with the slope into the sedan back gl***.
    I know that using the sedan back gl*** is a gamble and may seem odd, but I forgot to mention that the top is getting a fairly heavy chop. The chop will help flatten out, or de-bubble, the top. The only problem with a heavy chop is that the lower half of the body will start to look tall, but the 1-1/2" section just too care of that ;)
  30. deek
    deek
    from Tulare,CA
    I like it!
    Kustom7777- do you have a pic of the rear window?
