Projects Rancho Deluxe '32 pick up shop truck build.
Discussion in 'The Hokey Ass Message Board' started by lowsquire, Jun 4, 2012.
  1. Roger53
    Roger53
    MORE please your doing a bang up job the rear shock mounts look super. The whole build is super but you know that.
  2. ynottayblock
    ynottayblock
    love your work and ideas dude. The rear shock mounts are brilliant
  3. HOTRODPRIMER
    HOTRODPRIMER
  4. A Boner
    A Boner
    Just if you have tunnel vision.
  5. lowsquire
    lowsquire
    from Austin, TX
    Waiting on parts for customer work, so used the morning to make these. I'll cut the ears off the waterpumps.
    Jimmy Tee likes this.
  6. TexasSpeed
    TexasSpeed
    from Texas
    That'll clean up the engine compartment some! Killer.
  7. HOTFR8
    HOTFR8
    Nicely done Ben.
  8. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Very very cool!!!!! Man I normally don't always recommend getting rid of the welds since that's just more meat off the bone but if those were filed they'd look like a cast Ford part!!!!
    You're my hero.
  9. lowsquire
    lowsquire
    from Austin, TX
    Thankyou all. I thought about overfilling the welds and grinding them back, but once everything is installed you practically cant see them at all! And I've gotta work on customers stuff today, so that'll do. :)
  10. LeeKustoms
    LeeKustoms
    from earth
    very nice work man!
  11. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    That's why someone like you can build cars for a living and someone like me cannot.....well that and that whole having a lot of skill thingy that everyone thinks is the rage today. :D:D:D
  12. brady1929
    brady1929
  13. BLAKE
    BLAKE
    That's damn tidy... you got style what spills over onto all you touch, my man!
  14. Deuce_Eddie
    Deuce_Eddie
    from Portugal
    One more for the subscription list... love the ch***is work and care for all the details. It's going to be a killer company car!
    Cheers, Eddie
  15. HOTFR8
    HOTFR8
    Must be time for an update please Ben.
  16. oddcraig
    oddcraig
    Lookin' good Ben...
    Hope you're not going to let Chris near it.. Could end in trouble, especially is he is wearing his wrestling mask and wielding a blow torch!
  17. deuce1932
    deuce1932
    from Australia
    I'm not overly convince that's a good idea...
    original flathead water pump / engine mount bolts (4) are mounted in sheer over approx 8 inches total c-c for a reason.. they carry & spread engine load throughout the block without loading the blocks threads..
    your design with two bolts about 2 1/2 inches apart is reliant on thread loading / pullout resistance only..especially on the lower two bolts... & you've increased the loading on the mounting bolts by moving the ch***is mounting point forward to the crossmember.
    hope those 70 year old flathead threads hold ! I'd hate to see that motor come loose...
  18. thunderbirdesq
    thunderbirdesq
    Oh, hogwash.... For a fella with a username like yours I think you would know that's the same a way 32 v8 engine mounts from the factory.
    Looks great too, by the way, Ben. I mounted the engine in my roadster the same way.
  19. deuce1932
    deuce1932
    from Australia
    hogwash maybe....Ben's call on how he mount's it.. I wouldn't
    by the way...did you ever think it may be a reason Ford changed the design for later motors....
  20. thunderbirdesq
    thunderbirdesq
    It's also a similar design to every Hurst engine mount ever made. I'm sure those four grade 8 - 7/16" bolts torqed to spec in one of henry's finest blocks will be more than enough to keep his oil pan off the pavement. ;)
    back to your regularly scheduled programming...
  21. deuce1932
    deuce1932
    from Australia
    just because something has been done aftermarket in the past doesn't make it stronger..hurst made race parts...sometimes used for street cars.
    In Australia & particularly NSW we have to justify modifications of our vehicles to engineering inspectors to ensure each modification is an improvement in design & strength..
    in this case.. it isn't.. it's a backward step in strength...
    function comes before style...sometimes:D
  22. LabRat
    LabRat
    Rad stuff squire , love your idea's ...
  23. Malcolm
    Malcolm
    from Nebraska
    I like all the details and great, tasteful ideas. Very nice work!
    Malcolm
  24. lowsquire
    lowsquire
    from Austin, TX
    Deuce 32, I guess you know that this design is original to 32s , there is a step that catches under the block at the back of the mount, which takes the gravitational shear load off the bolts, you can't see it in the photo. The only disadvantage I noted is a slightly smaller resistance to rotational torque loads of the engine, but neither I , nor my engineer, consider this a problem. Thanks for the feedback though!
  25. deuce1932
    deuce1932
    from Australia
    Hey Ben.. no can't see the tab in the pics.. they would be fairly small to clear
    the pan rail so doubt they would show...hey.. as long as your happy & your engineer is
    OK with it.. all good...some nice fab work..
    I just mentioned it cause it's one of those things I would worry over.
  26. 35fordcoupe
    35fordcoupe
    from Virginia
    Very nice work! I'm in for more :):cool:
  27. Sutton Speed
    Sutton Speed
    Beautiful truck man... excited to see this thing come together!
  28. Rem
    Rem
    This looks great, somehow I missed it before.
  29. Pete
    Pete
    Slick idea using the F-1 front shock mounts as rears!! Very nice.
    Pete-
