Tri-power air cleaner pics
Discussion in 'The Hokey Ass Message Board' started by VoodooTwin, Sep 13, 2012.
  1. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Did a search, couldn't find much. Let's see your tri-power air cleaners!
  2. M_S
    M_S
    from SoCal
    Mine are factory GM style, which requires quite a bit of modification to get them to fit the small 283.
  3. Bam...
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    I'm still on the fence as to whether I will run the common Speedway $20 little chrome air cleaners.........
    or a set of scoops, like in my mockup picture. Guess I won't know till the car is done.
    Don
  5. hotrodpodo
    hotrodpodo
    Here's mine...:cool:
  6. JMel
    JMel
    I'm in Dons boat right now. Running pretty generic louvered air cleaners....quite tempted to go with scoops.
  7. tommy
    tommy
  8. lurker mick
    lurker mick
    I am using "Maund" finned velocity stacks to match the valve covers. They have screens installed to keep out dirt and small birds etc.
    Mick
  9. GassersGarage
    GassersGarage
  10. BigDrag
    BigDrag
    from Milwaukee
    Had to make a simple adapter ring but otherwise right out of the magazine.
  11. BigMikeC
    BigMikeC
    A couple of my sets-
  12. I keep playing around with this, but always come back to the chrome louvered ones. The stacks are 2 1/2 inch stainless, the red ones are homemade, I've got some K & N tapered ones and a few other homemade ones that I don't have pics of, but like I said, my favorites are the louvered ones. Winter is comming though so we'll see what I come up with. :rolleyes:
  13. tommy
    tommy
  14. Love your Meteor injected Poncho powered A coupe! Looks like you're putting on some fun miles.
    Now if I can find another tri-carb air cleaner like this I would build a car around it!:cool:
  15. Judd
    Judd
    this is how Ford did it in 1962.
  16. jgb7038
    jgb7038
    from Indiana
    Here's mine,was running the scoops with bug dome inserts,and switched to the finned aluminum one with air cleaners.
    hhjh
  17. CruZer
    CruZer
    Whatever you choose,put K&N filters inside. They flow 3 times as much air as a paper filter.
  18. Jimv
    Jimv
    Mine are the tops of sugar bowls i bought at the flea market,They're SS, i drilled the center & had them polished were i worked.Bottoms are cheapos & the Filters are K&N knock offs i got from Dennis O'brien.( best investment i ever made)
    JimV
  19. LSGUN
    LSGUN
    from TX
  20. perk30
    perk30
    s[​IMG]tandard chrome louvers
  21. Pooch
    Pooch
    from Oklahoma
    heres mine
  22. burt21
    burt21
    Heres mine in as cast or black wrinkle powder coat
  23. burt21
    burt21
    Those look pretty dang good on there.Good to see my scoops out there!!
  24. Deuces
    Deuces
    I like the oval type used on Fords...
    Same tops were used the 2x4 setups also...
  25. SLO POK
    SLO POK
  26. Von Rigg Fink
    Von Rigg Fink
    from Garage
  27. Normbc9
    Normbc9
    Here are some to look at. Different ideas and also appearances too.
    Normbc9
  28. Deuces
    Deuces
    What the heck... Here's one more........
  29. ArtofHotRod
    ArtofHotRod
    <input id="gwProxy" type="hidden"><input jscode="leoInternalChangeDone()" onclick="if(typeof(jsCall)=='function'){jsCall();}else{setTimeout('jsCall()',500);}" id="jsProxy" type="hidden">
