Should I Grind My WhiteWalls???
Discussion in 'The Hokey Ass Message Board' started by Malarky, Sep 13, 2012.
Grind 'Em...or Leave 'Em Skinny?
Poll closed Sep 18, 2012.
  1. Grind 'Em!
    50 vote(s)
    48.1%
  2. Nah...Leave 'Em Skinny
    54 vote(s)
    51.9%
  1. Malarky
    Malarky
    Disclaimer: Grind white walls at your own risk. Some folks know this to be dangerous.
    That now being said, I cant make up my mind...
    I've always loved the look of wide whites ; And I know-I know, www's were pretty much phased out by '62 (year of the car in question) But I trashed one of my tires so I decided to try out grinding the ww...Turned out pretty F'n rad! I didn't go as wide as I could have, I like this width.
    I've seen some cars that didn't fit the www era that looked great with them!
    I found a cheap set of used tires in good shape, should I grind 'em, or leave 'em skinny??? Let me know what you think.
  2. pinkynoegg
    pinkynoegg
    honestly i think they might look a little goofy on the car. I like wide white walls but not on anything after about 60.
  3. chaddilac
    chaddilac
    I like that width on the tire above, looks fatter than what you have on the car! I like it!!
  4. tudorkeith
    tudorkeith
    I like wide whites too but I think the skinnies look good on your 62
  5. Squablow
    Squablow
    What you have above would look great on a '62 and would still be period correct. Full-on wide whitewalls would look goofy, but that's not what you have there.
    I'd also sand off the lettering in the black wall area for a clean look, the modern lettering gives these away as being modern tires.
  6. Malarky
    Malarky
    Right, they aren't straight up "gangster whites"... just wider than skinny whites. I agree 3" ww's would look goofy.
    Squablow, Thanks for the tip on smoothing out the blackwall, that'd look slick.
  7. Malarky
    Malarky
    I hear ya.
  8. tfeverfred
    tfeverfred
    WWW don't go with every car. The skinny ones look cl***y on that year.
  9. Silhouettes 57
    Silhouettes 57
    Back in the early 60's they went from wide white to what I use to call "wide narrows" because the white wall started about an inch or two from the rims but they were still bigger then what you now have. Look at some of the car ads from the early 60's and you see just how they changed.
  10. Malarky
    Malarky
    Great idea! The car on the bottom is a Monterey (like mine) and its got the same size whitewall I ground.
  11. I'm all for grinding WWW to make a set. But on you car I think they would out of place. Bottom line it's your car, do what you want.
  12. 49ratfink
    49ratfink
    this is the perfect width for the right 60's car.
  13. diamond jeff
    diamond jeff
    from montana
    Nice merc', leave the whites skinny and put some 30" bellflowers on that baby.
  14. Malarky
    Malarky
    I really like how the width turned out. I just went out and measured, it's 1 3/8" wide.
  15. Malarky
    Malarky
    Thanks man I've been tossing that idea around in my head for a while now.
  16. Malarky
    Malarky
    A bump for the morning crowd.
  17. Jimv
    Jimv
    If you grind them they won't be super wide! Try a old tire & see how you like it, Its your ride.I did mine & the WW isn't from the rim to the edge, it leaves a little at the bottom & about mid way thru the letters( sometimes!!lol)
    JimV
    PS If you get a dremel you can grind a small line at the top & the bottom of the WW & see how far it goes, if its too much you can just go over it with a Sharpie in black.
  18. 100% Matt
    100% Matt
    Leave the whitewalls, invest in astro supremes or chrome reverse. Nice lookin car ya got there btw
  19. Squablow
    Squablow
    That's what I did on the last set of whitewalls I made, and it makes a huge difference. If the letters aren't too tall, an 80 grit disk on the DA works great. If the letters are real thick, sometimes you have to grind some meat off of them first.
  20. Blue One
    Blue One
    from Alberta
    White walls **** on pretty much any car of any year vintage.
  21. BAD ROD
    BAD ROD
    I'm going to go out on a limb and guess no one has ever called you "Mr Positive". ;)
  22. ONE8SEVEN
    ONE8SEVEN
    gtfo
  23. ONE8SEVEN
    ONE8SEVEN
    get white wall toppers, they are cheap!
  24. n.z.rodder
    n.z.rodder
    You should've done a tech on how you ground the sidewall and got it looking so neat and tidy.
    I say grind em.
    Scotty.
  25. Malarky
    Malarky
    I've got supremes on my Ford, I wanted something a little different for the Merc. And thanks.
    They look nice but I've been advised to stay away from them.
    There is a thread on here somewhere of some guys grinding ww's. There are also a couple videos on Utube. If I can find 'em I'll post the links.
    I'll do a tech if you'd like, but I know how some folks feel about starting a new thread that's been covered before. Maybe I'll just add to the old one.
  26. mike1951
    mike1951
    from Colorado
    I was thinkin those looked pretty clean for a home job
    Posted from Jalopyjournal.com App for Android
  27. 100% Matt
    100% Matt
    Now that I can see the pic 1" 3/8 looks nice. good deal!
  28. Lone Star Mopar
    Lone Star Mopar
    **** those look real good, I can see em rolling those in 62 63 easy.
    Forget about those janky *** port a walls, what you have looks way better !
  29. Geargoyle Curtis
    Geargoyle Curtis
    The 1 3/8" whitewall you ground will look great on your car.
  30. flathead okie
    flathead okie
    I wouldn't **** with a tire. Buy the ones you want, sell those.
