help I.D.ing these wheels
Discussion in 'The Hokey Ass Message Board' started by hot rust, Sep 14, 2012.
  1. hot rust
    hot rust
    scored a set of artillery wheels today with all 4 caps also and i would like to identify them, i believe they are chevy as they are a 6 lug variety. measure to be 16x5 1/2 inches. the centers appear to be forged or cast? hope maybe the hub cap will tell what they are. thanks for any help. hot rust
  2. I know nothing about those wheels, but a quick search shows that they came on 1935/36 Chevy Master Series trucks. I used Google Image search and typed in "1935 chevy master truck artillery wheels" . The first picture that comes up shows a truck with kegs being loaded/unloaded. Wheels look spot on.
    Here is the link to that pic:
    http://www.google.com/imgres?q=1935...&ndsp=18&ved=1t:429,r:0,s:0,i:72&tx=100&ty=95
  3. hot rust
    hot rust
    thanks elgreco for the link, but it says in the dialogue that the truck wheels were 17 inch wheels and these are 16 inch, so the saga continues
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    Hubcap appears to have DB on it. Dodge Brothers.
  5. Those are not Chevrolet, but should be Dodge.
  6. 55 dude
    55 dude
    thought mopar was 5 lug 5 on 4.5" pattern?
  7. tommy
    tommy
    I've never heard of a 6 lug Dodge wheel. Chevrolet and maybe Buick had 6 lug wheels.
  8. 32-3 WINDOW
    32-3 WINDOW
    from utah
    they sure look like g.m. artillery wheels to me
  9. damagedduck
    damagedduck
    from Greeley Co
  10. You're right Tommy.
    I saw the large center hole and immediately thought Dodge, but they were 5 lug.
    Might be GM, but NOT Chevrolet.
  11. mike hamel
    mike hamel
    Can you measure the 6 lug bolt pattern? Ya it's 6 lug, but it looks to be bigger then standard Chevy.
  12. hot rust
    hot rust
    the bolt pattern across 2 lugs is 3 inches and across 3 lugs is 5 1/4 inches.the lug holes measure 9/16 inch. hot rust
  13. 302GMC
    302GMC
    from Idaho
    Those are aftermarket Chev or Pontiac early to mid '30s wheels for the "Balloon" or "Jumbo" tires. The centers look to be cast, which is rare in these wheels. If tires are removed, the maker should be clearly visable, stamped into the center of the rim.
  14. hot rust
    hot rust
    thanks i will remove one and check it out.
  15. Atwater Mike
    Atwater Mike
    I believe the mfr. was BUDD. Look for that logo, (just the name) It should be stamped somewhere on the center. (flange part or 1 spoke)
