I am looking for weather stripping for my Rambler. All of it. Doors and Windows. Any leads on where I can find this?
That's the Rambler Mercedes copied the rear end of... Look thru a Steele rubber catalog The weather strip is probabay just shaped extruded rubber lengths like the aluminum window frames are extruded aluminum.
Here are some numbers Galvins.............................. 209 365 6315 Blaser............................... 309 764 3571 Kenndys American............... 614 879 7283 So.Tx.AMC......................... 830 980 3165 American Parts.................... 937 678 7249 Galvins and Blaser are prob your best bet...... Good Luck MM64
you wouldnt happen to have a pic of the original steering wheel would you? http://www.jalopyjournal.com/forum/showthread.php?t=66680
There are pix of the steering wheel on my web site....... both before and after I cut it up www.rgkustoms.com/rambler MM64
AWWW DUDE!!!!! THATS IT!!!!! THANKS!!!! you dont know where i can get that chrome wheel center do you????
You need just the center or the horn ring to???? I left those at my sisters house when I brought the car home........ Soooooo if she didn't trash them they should be there She lives bout 100 mi from me so I'm not sure when I'll be going down there I try to go once a month or so...... So when I do I'll check and see Send me an email at rgkustoms@greganti.com so I can let you know when I find out cuz I "know" that I won't remember who here had ask..... Think it has something to do with old age MM64
Keep on preaching the good word of the Rambler. I just talked to this guy here that is re-building my starter and he said, "Why did you pick a Rambler to re-do? I have seen other cars here but never a Rambler." I told him that he just answered his question.
AMEN!!!!!!! You wouldn't believe how much flack I got when I said I was going to Kustomize a "Rambler".......... But now everyone thinks it kool. Being different is KOOL!!!!!! MM64
nice job. you dont see enough ramblers and you for sure dont see enough of that model. should be pretty cool and unique when your done. later.
get this ****!!! I JUST GOT BACK FROM LOOKING AT A 59 RAMBLER 4 DOOR!! SOLID AS HELL!!! NICE SEATS!!!!(if someone buys it i get the pie cut white walls) who wants her? push ****on auto and all......no motor BRAKES WORKED! like i said, ill go in on it too. i want the front seat and the white wall tires. guy wants 500....its a car lot we can get him down to 400!!!!!
What are you running under the hood, the stock drivetrain? The one I picked up I finally got under to see that the unibody frame rails have some pretty nasty rot spots in them (although the only iffy spot in the suspension is around the sway bar bracket). So I'm thinking I will see if I can just cut it out and fit some other frame under it, who knows - it's going to be a long time before I get to it. Sad thing is the car's been parked since 1967 right down to the plates, it's pretty nice and would clean up easily other than that rot.
