Anyone build an engine run stand?
Discussion in 'The Hokey Ass Message Board' started by raidmagic, Sep 16, 2012.
  1. raidmagic
    raidmagic
    Pics and info please. If there is a thread on it a link to that will work. I tried searching but those three words bring back way to many searches.:D
    I want to build something to break motors in on and to keep something that isn't in a car in good running order if needed. Thanks for any advice.
  2. c-10 simplex
    c-10 simplex
    What type of engine?
  3. big duece
    big duece
    from kansas
    There is no right or wrong, some are simple, some are complex.
  4. Mr48chev
    I built several of them when I was teaching High school automechanics. Basically they were a steel table frame without a top that had motor mounts and a small dash board at the back. With a radiator on the front, a battery holder and a small gas tank and an oil and temp gauge we were good to go.
    On a new engine you want an exhaust that is quiet enough so that you can actually hear any and all noises in the engine when you run it. The cool factor of busting one off the first timewith open pipes soon fades if you can't hear a noise that might cause damage.
    We had five or six of them on castors and when they weren't being used by students we could roll them in the corner out of the way. When I took the cl*** over we had test engines setting in the front sub frames or frame stubs of cars complete with wheels and tires and they took up a lot of room and the tires were always getting in the way of freely moving around the engine.
    The one that Big Deuce showed above is a lot nicer than the ones we had but works about the same and takes up about the same floor space.
  5. tubman
    tubman
    When I built mine, I had several engines I wanted to test (331 Hemi, Olds Rocket, and a couple of flatheads), so I wanted it to be universal. For the rear mount, I bought a cheap engine stand and cut it down and mounted it on the stand. So far I have been able to bolt the engine directly to it (with the bellhousing bolts) or bolt the bellhousing to it (using the transmision bolts). You have to do some twisting and turning, but so far I have been able to mount every engine I've tried successfully. At this time, the front mounts have been custom for each one because they are quite simple. When I get around to doing one of the flatheads, I think I'm going to permanent mount the flathead mounts, and use Hurst-type adaptors for the other engines. The rear mount was the hard one though. I can include some pictures tomorrow if you'd like to see it.
  6. mochevy69
    mochevy69
    from sc usa
    <cite>Try this site.
    www.easy-run.net/</cite>
  7. raidmagic
    raidmagic
    Nice pics Big Duece the bellhousing is interesting. Is that necessary as opposed to bolting it to the back of the block?
    It will be used mostly for small block Chevys but I'd like to be able to adapt it to other motors if needed.
    Thanks for the site mochevy but I'm not looking to spend 2 grand on something
  8. big duece
    big duece
    from kansas
    I am building one, and using a 4 speed bell housing also. I feel better with the flywheel covered.
  9. DadsBlueFord
    DadsBlueFord
    from Hayden, ID
    There's a guy on eBay selling a quality set of plans and instructions for an engine run stand, that is collapsible/foldable for storage. It's $8.50, by fishermanruss. I bought a set but haven't built it yet.
  10. 53sled
    53sled
    from KCMO
    I saw one in a post here the other day made from a Deere riding mower. Epic.
  11. hoggyrubber
    hoggyrubber
    sbc, i figgured it'd be a 308 for that hudson.:D i built one out of 2x12 for a 308 was very basic. i left the ****** on it. this is not a very good picture, but it had the battery on it and i just had a pvc pipe with rad hoses for short run.
  12. MeanGene427
    MeanGene427
    from Napa
    Mine is very similar to that, except the control panel is in the front, for two reasons, away from the bellhousing area and exhaust, and much easier "loading" of an engine as one end of the stand is "open". Started with a warehouse cart with HD solid rubber casters, and have another HD flat table about 30" high that's just slightly larger than the castered cart (actually a motorcycle engine ***embly table that came from the Indian factory in Gilroy ;)) that I can set the whole ***embly up on to work on it at normal height, 2', then pick up the whole deal with the hoist and set it on the floor to fire up and run.
  13. rpkiwi
    rpkiwi
    from Truckee CA
    This is one that I used to run my engine in before putting it in my truck.Just modified the existing engine stand as it was already on rollers and pretty easy to do.
    Roger
  14. henryj1951
    henryj1951
    from USA
  15. henryj1951
    henryj1951
    from USA
  16. Dave Downs
    Dave Downs
    from S.E. Penna
  17. Bigchuck
    Bigchuck
    from Austin, TX
  18. henryj1951
    henryj1951
    from USA
    and mine is NOOO better ...lol
    :cool:
  19. raidmagic
    raidmagic
    wow those are scary. I have an X frame here that I'm going to cut up to make my stand. That will give me engine mounts and strength and I'll put it on casters to move it easy. when not in use I can just leave it outside.
  20. verno30
    verno30
  21. 47.Poncho
    47.Poncho
    I built mine out of a Princess Auto engine dolly. Me and my buddies have used this idea about a dozen times and works everytime. Much easier to find the problem on the stand then compared to in the car all hocked up and you have to pull it out again. Thats the 400 in the car and it hasn't come out yet. Just make sure to go over your flywheel bolts and fan bolts cause it's scary when it's running.
  22. seabeecmc
    seabeecmc
    The one I built from s**** and drops. Ron
  23. DadsBlueFord
    DadsBlueFord
    from Hayden, ID
  24. MeanGene427
    MeanGene427
    from Napa
    Nice thing too is working with headers- I have a used 390 on the stand now, and can gently "bake" my customer's new ceramic coated FPA's, and then break in the cam on his 450cu CJ stroker with my old "stand" crusty headers without overheating his new ones. Got a set from the old sprint car that ran at Calistoga in the old days with High Riser 427- you should have heard that beast come off Turn 4 in the days before mufflers :eek:
  25. bigmikes50chevy
    bigmikes50chevy
    Here's mine
    Sent from my DROID device using the TJJ mobile app
