Projects "Rusty Cheese" 29 Model A BUILD
Discussion in 'The Hokey Ass Message Board' started by Rusty Cheese, Nov 12, 2010.
  1. moparnate
    moparnate
    from minnesota
    dude, congrats on getting it on the road, good to see some updated pics
  2. ColoradoDan
    ColoradoDan
    Curt what's going on man it's Dan Sprague from Littleton. I just stumbled on this thread and saw it was you. I just picked up a 30 Model A sedan that I'm starting to build. Hope everything is going well for you guys up there!
  3. Chucky
    Chucky
  4. writerDennis
    writerDennis
    Looks interesting. Keep up the good work.
    Dennis W. Parks
    Author of automotive how-to books
  5. Rusty Cheese
    Rusty Cheese
    Here some photos my buddy took. This was the first time on the highway.
  6. Rusty Cheese
    Rusty Cheese
    Thanks! I finally get it running and then it snows...
  7. Rusty Cheese
    Rusty Cheese
    Cruising...
  8. Rusty Cheese
    Rusty Cheese
    Applying to the State of South Dakota to let me use the 1929 plates...
      292.1 KB
      435.2 KB
  9. Ghost of ElMirage
    Ghost of ElMirage
    lol yup
  10. jamiee
    jamiee
    I got a ride in it the other day, moves real quick,has a great ride, and lots of people staring at her!! Thanks Curt
  11. Rusty Cheese
    Rusty Cheese
    Well, I got to drive it today! No better way to spend the day, Hot Rodding around the Black Hills with my son! 78 degrees in the middle of November. Thanks for all your guidance Jamiee!
  12. gnichols
    gnichols
    from Tampa, FL
    As Cosby might say: Way-B, Cool-B. Congrats, Gary
  13. themoose
    themoose
    Sounds like a great time.Damn...I'm jealous!
  14. Rusty Cheese
    Rusty Cheese
    THANKS! Who's Gary? LOL!
  15. woodbutcher
    woodbutcher
    :D:eek:Hi RC.Sueeeeeeeet build.Lovin` every bit.As my dear departed Dad would say"Now that`s the cats whiskers".
    Good luck.Have fun.Be safe.
    Leo
  16. Rusty Cheese
    Rusty Cheese
    THANKS!
    It could be the cat's meow, also! LOL!
  17. Rusty Cheese
    Rusty Cheese
    Cold here in South dakota. Everyone should be out in the warm heated shop building something. With out spending any damn money...
    Gauge Relocation Project.
    Paper Template-CHECK
  18. Rusty Cheese
    Rusty Cheese
    Check the angle.
    Cheap plexigl*** and the heat gun santa got me.
      122 KB
  19. Rusty Cheese
    Rusty Cheese
    Flat, not for long...
      147.1 KB
      122 KB
  20. Rusty Cheese
    Rusty Cheese
    3 layers of fibergl***. All I need to do is cut the holes...
  21. Rusty Cheese
    Rusty Cheese
    Seat Ideas. Trying out my new piping foot for the Juki sewing machine...
      165.7 KB
      472.4 KB
      123.4 KB
      197.8 KB
      181.8 KB
  22. Roy might be able to help. I guess you have been asking him already!
  23. Rusty Cheese
    Rusty Cheese
    Cartoon 29.
    Too many ideas...
      106.8 KB
      129.8 KB
  24. Rusty Cheese
    Rusty Cheese
    Ok time to ,make the pattern for the seat cover. I'm going for a 60's sparkle vinyl with snaps and and Diamond inserts pleats. I'm not a upholstery expert by any means, just learning as I go. so any input is always appreciated...
    First I used a small amount of spray glue on my pattern to keep it from moving all over.
    Working off the center line.
      125.7 KB
      239.5 KB
      187.3 KB
      155.3 KB
  25. Rusty Cheese
    Rusty Cheese
    I want a uniform size around the outside and going to add a few snaps.
      105.1 KB
      137.2 KB
      126.1 KB
  26. Rusty Cheese
    Rusty Cheese
    working on the diamond pattern layout. ohh that makes my head hurt!!
    Now if only santa would bring me a couple hundred dollars worth of 2" inch foam and a few yards of vinyl.
      154.4 KB
      211.5 KB
      207.4 KB
  27. n847
    n847
    Thats gonna look *****in!
  28. Rusty Cheese
    Rusty Cheese
    Not much going on... Made template for door panels.
      115.5 KB
      159.3 KB
  29. Rusty Cheese
    Rusty Cheese
    I'm making my template for my door panels... Do I have to notch the top two corners because it doesn't seem to sit flat.
    Second. How far up should I go with the panel under the dash. Any advice or pics would be great.
      114 KB
      138.3 KB
      139.7 KB
      485.6 KB
  30. nsidemn
    nsidemn
    Dude!! Looks like I may have to walk across the street and see how my future employee is doing...lol Your garnish moldings will extend to the edge and push your panel tight. That is an area where the plastic works great because you can heat it and it will hold the bend. I know it is a lot more cost factor with plastic but with you super tight roof you know its going to get wet. With the plastic you don't have to worry about warpage.
    As for the kick panel you are good at the dash. The 1/2" wide strip right next to the dash panel is where the metal trim piece attaches that holds the windlace. If you are not going to install windlace you may need to cover that spot.
