Projects 1938 Chevrolet Pepsi Truck
Discussion in 'The Hokey Ass Message Board' started by the metalsurgeon, Jan 15, 2012.
  1. the metalsurgeon
    the metalsurgeon
    from Denver
    thanks guys much appreciated...
    Wanted 36 3 or 5 window coupe body shell or parts
  2. nhmikel
    nhmikel
    from NH
    Hi metal surgeon
    Would u be able to advise?
    What would you do to fix these little bumps? or what can i do in my garage to remedy?
    Also what do u do on the underneath sides?
  3. CGkidd
    CGkidd
    Damn that is some awesome work.
  4. matt mcnamara
    matt mcnamara
    from The UP
    How long did it take you to complete that task, just out of curiosity?
  5. JYPSEA
    JYPSEA
    from Florida
    You should change your name to Metal Genius.
  6. Big Nick
    Big Nick
    Down right amazing and very inspirational! Thank you for taking the time to post up all these pictures!
  7. the metalsurgeon
    the metalsurgeon
    from Denver
    Media blast first then re access
    Wanted Ford 36 3 or 5 window coupe
  8. nhmikel
    nhmikel
    from NH
    We did that and got all these little bumps about the size of the ends of my fingers
    Really did not know what next? So we primered them
    Once again pondering what to do?
    cold hammer them out or heat?
  9. the metalsurgeon
    the metalsurgeon
    from Denver
    no heat. you need a s****,dollies and a flat file
    wanted 1936 Ford 3 window or 5 coupe
  10. nhmikel
    nhmikel
    from NH
    What size would you recommend? It seems that the local supply shop has "small" sizes. I do not think it would work with 1936 steel maybe the newer years.
    I would like to learn this but no locals I know of? Anybody?
  11. the metalsurgeon
    the metalsurgeon
    from Denver
    i make my own s****s from old files.Not sure what you mean by 'small' sizes .Typically old panels are pressed out of 19 swg material thickness.New cars are 22 swg, thinner material.I use 18 swg pretty much for everything,doors ,roof skins etc
    wanted 3 or 5 window 36 ford
  12. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  13. the metalsurgeon
    the metalsurgeon
    from Denver
    Updates on truck.Running boards re designed and modified.Cab valance changed from bolt in to one piece with the cab.
  14. blue57ford
    blue57ford
    WOW! Incredible work.
  15. nhmikel
    nhmikel
    from NH
  16. TFoch
    TFoch
    Very nice work!
  17. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    x2 :cool:
  18. nhmikel
    nhmikel
    from NH
    Hi Metal Surgeon
    I need to fix/replace my lower cowls as well. Would you be able to give me the dims of the little detail (pointed arrow?) like you did.
    that seems to be on the lower cowl area. You can see in this pic someone patched over it.
    I can understand if your to busy. Can anyone else help?
  19. nhmikel
    nhmikel
    from NH
    Hi Jon
    Where did you place the battery?
    Any pics?
  20. K13
    K13
    Beautiful work as always Jon.
    I have been thinking of doing the same thing with my cab valance(never knew what it was called) I can't tell for sure in your pictures but did you leave the seams (where the door line runs into this panel) on the outside. I was considering welding those up as well but worry that with the two piece design of the floor near the front of the door opening might flex too much in that area to weld the front seam up solid. Any thoughts?
  21. jesse1980
    jesse1980
    That's a cool job you have for sure. The truck l
  22. Zoomzoooie
    Zoomzoooie
    from BC Canada
    What metal wizardry!
    I too have a 1938 Chevy pickup I am slowly working on. Luckly mine is much better shape, but for a few parts needing a little repair. The worst however is a very badly rust pitted rear fender with some metal missing. I will trying to replace the worst of it myself, learning as I go. I will be electroliticly removing the rust to start with once the weather is warm enough. I will be using hand tools since I don't have the budget or space for larger tools.
    Following along on this tread has help emmensely! Just seeing what is possible gives me ambition to try to repair my fender.
    I have one question though.
    I notice some of your panels are baddly pitted too. I wanted to use as little poly filler as possible on my truck. Methods I have thought of is body solder, but both sides of the fender will reqiure filling and how will it stick when heating to apply the other side? Another method which looks possible, but may be expensive is flame spraying zinc or steel, grinding down between each coat.
    So my question is:
    What do you recommend for the best rust pit repair on the fenders?
    Regarding the cab seam, how did you clean, neutralize or treat the rust between the panels before welding?
    I know it was requested, but personally I think its sacrilege to change the hood and dash in these vintage vehicles. These are what give them character and nostalgia.
    ZZ
  23. ownerizer
    ownerizer
    from Parker, Co
    yes!!!
  24. the metalsurgeon
    the metalsurgeon
    from Denver
    Sacrilege ! thanks !
  25. K13
    K13
    Haha I am part of the sacrilege club as well:D. Great work as always Jon!!
  26. billsill45
    billsill45
    from SoCal
    How about an update ??
  27. 4444Design
    4444Design
    you have stunning skills in fabbing those sheetmetal parts
    congrats for that
  28. gwarren007
    gwarren007
    x2 :)
  29. the metalsurgeon
    the metalsurgeon
    from Denver
    Aluminum hood build.We decided to head in a different direction with hood as we felt the hood was a little on the weight side,so we made an aluminum one instead including inner structure panel.Same deal forward moving hood.Here's the work in progress...
  30. mustang6147
    mustang6147
    from Kent, Ohio
    I guess these pics reflect why your the metal surgeon.
    Looks fantastic
