58 ford f100 v8 swap options?
Discussion in 'The Hokey Ass Message Board' started by punchdrunk, Sep 20, 2012.
  1. punchdrunk
    punchdrunk
    from las vegas
    i have a 58 ford f100 short bed truck it currently has the 223 inline 6 but could never get the engine running so now im looking into swaping it out for v8. Im looking for a fairly easy engine swap that i can do, im not sure either what would be needed when it comes to motor mounts and wich engine would some of you recommend a ford v8 or sbc wich is easier any info on doing this swap would be helpfu i wanna get the truck running and driving.
  2. Dan10
    Dan10
    from Joplin
    These trucks also came stock with a 292 Y-block. Probably the easiest swap to get it on the road.
  3. Rob68
    Rob68
    Check out the 57-60 F100 group here on the HAMB. Lots of great info and knowledgable guys there.
  4. punchdrunk
    punchdrunk
    from las vegas
    If i look for a 292 Y block would it bolt up to transmission i have now in it?
    Cool I'll look into the group see what i can find out.
  5. Zapato
    Zapato
    500 Cad or early Olds.............. just thinking out loud
  6. My 40,000 mile dodge 360, out of my mini motor home fit extremely well. what the helll it was cheap!
  7. punchdrunk
    punchdrunk
    from las vegas
    yea im wondering on how would i go by as for the motor mounts? is their a kit they sell for do you have to make your own?
  8. punchdrunk
    punchdrunk
    from las vegas
    where o the website do i find this group at?
  9. moefuzz
    moefuzz
    I've used the 67-72 F100 V8 Frame/motor mounts on many different projects.
    They attach at both top and bottom frame rail and with a little work can be adjusted for different frame widths.
    The same goes for the transmission cross members. Ford often offset the ****** cross member to one side or the other so the center bolt (trans mount) is often off center. You can flip the cross member end for end to center the trans mount bolt for either left or right depending on desired mounting position.
    BTW, a 5.0/302 with an auto or standard overdrive is a natural choice.
    jmho
    moe
  10. moefuzz
    moefuzz
  11. punchdrunk
    punchdrunk
    from las vegas
    well im looking to keeping the frame om it now just want to know what to use for motor mounts
  12. punchdrunk
    punchdrunk
    from las vegas
    cool thanks
  13. moefuzz
    moefuzz
    "Frame/Motor mount" = Motor mount to frame bracket
  14. fanspete
    fanspete
    I've got the 292/3spd out of my '57 F250, 60k miles, you can have it if you can get it shipped!
  15. willowbilly3
    willowbilly3
    from Sturgis
    Speedway has the motomounts/cross member for cheap. It will bolt a 302 right in. They also have the ****** mount/crossmember but you will have to cut and drive out the rivets to remove the old one. I personally prefer a Ford in a Ford but a same vintage Olds or Caddy would be even cooler. If you ever decide to sell it and it has a 350 chevy engine, you will not have the interest and will have to take less money, IMO.
  16. ididntdoit1960
    ididntdoit1960
    from Western MA
    I put an FE in mine - I "cheated" and used the available crossmembers too. Plenty of room, an easy swap. If your going to lower the truck significantly, be careful of oilpan clearance - you may need a 4x4 pan for the FE or, if you go small block ford a fox body dual sump 5.0 pan usually fits nice
  17. DRUGASM
    DRUGASM
    Check online with LMC too. I browsed their catalog and they have bolt in kits for just about any engine out there. Bolt in kits! You should be able to choose just about anything.... Won't run short on room.
  18. punchdrunk
    punchdrunk
    from las vegas
    i tried checking lmc but couldt find anything on their website i try maybe calling to see
  19. 56 ford custom
    56 ford custom
    from Socal
    I don't see why a y block wouldn't be a near direct bolt in...I know its not a truck but a lot of the ford cars and trucks that had the y blocks in them were very similar. My 56ford 2door sedan had the stock 223 six in it but was toast so I got a 292 and it bolted right up no issues at all.
    I would consider that before anything..Y blocks run and sound great! Some guy offered you a free yblock and trans you just have to get.it shipped and that wouldn't be too bad honestly
  20. d2_willys
    d2_willys
    from Kansas
    I plan on putting a 368 Lincoln Y-block in my 57. Dual range hydramatic behind the Y too. Should be pretty easy. I just need to know what mounts to use. I am thinking something off an FE might just work.
  21. punchdrunk
    punchdrunk
    from las vegas
    Yea i just realized that and pm him about
  22. Blake84
    Blake84
    I was looking into same situation with my 59 f100 but decided to keep the original 223 and ad a few things to it........I was going to go with 302 or 351 Windsor
  23. jcmarz
    jcmarz
    from Chino, Ca
    There's only one V8 that's perfect for your F1 and that's the mouse motor. Chevy rules.
  24. The Y-Block will bolt right in but you will need a different bell housing, other than that should be the easiest way to go. If you get the one that is offered free spend a little time and a bit of cash and make the thing run while you have it out. If you want a few tips I can tell you how to get some power for not much $. You will have to do some work though. ;)
  25. punchdrunk
    punchdrunk
    from las vegas
    Yea that be cool can't complain about adding a little more horse power,
  26. punchdrunk
    punchdrunk
    from las vegas
    After searching again I've found the motor mounts to install a v8 in my Ford now i feel more comfortable in getting a v8 to do swap the engine
  27. fiftyv8
    fiftyv8
    from CO & WA
    Check out my engine swap thread in my 1960 F100.
    http://www.jalopyjournal.com/forum/showthread.php?t=366906
    From my limited experience after completing that project that the SBC engine does lend itself to this swap.
    However, if I had not changed the to IFS I am sure I would have gone with a 292 Y block and searched for a more modern ****** to bolt up behind it.
    The other thing you may wish to consider is changing the diff ratio as the 223 runs something like 3.9:1 gears and I am sure the Y Block even stock ran taller gears probably about 3.7:1.
    I used 3.54:1 during my swap which are fine since I also have a O/D T700R4 ******.
    I probably got a little carried away during my build but I am gald that I did the disc brakes, power steering, IFS and a/c which have all gone some way to making it a real nice driving truck.
    Check out the Industrial Ch***is Inc website in AZ and even give Steve down there call he is full of great ideas and has kit stuff too boot.
  28. kracker36
    kracker36
    What exactly does Chevy rule at? Mounting distributors in the wrong place or running a business into the ground?
  29. fiftyv8
    fiftyv8
    from CO & WA
    Chevy's win with the most oil leaks every time in my book.
  30. jcmarz
    jcmarz
    from Chino, Ca
    now that's a cheap shot right there. Ford got a restructuring loan from Uncle Sam (taxpayers money). If you need proof, here's proof from FoMoCo itself, pleading for money because they made some "mistakes". Click on the link if you dare.
    http://banking.senate.gov/public/_f...NTATIONOFFORDMOTORCOMPANY122_SenateFinal_.pdf
    And don't forget, it wasn't Chevrolet who took the money. It was General Motors Corporation, which Chevrolet just happens to be a division of, best division by the way.
    Peace.
