Wide ratio vs. close? Help!
Discussion in 'The Hokey Ass Message Board' started by BuickBrad, Sep 24, 2012.
  1. BuickBrad
    BuickBrad
    from minnesota
    Could someone help me decide which to put in my car? it has a 4.10 rear end, a mild 327 and its most going to be street driven. Ideas?? BTW this is my first manual trans swap so any advice on flywheel weight would be great too, heck ANY advice will be greatly appreciated!
    Thanks!
  2. Deuces
    Deuces
    Close ratio Muncie M-21 or M-22 4-speed.. If you got the $$$$..:D
  3. pitman
    pitman
    I doubt you'd want a wide ratio with that rear gear. First would be good for pulling stumps.
  4. 29AVEE8
    29AVEE8
    Flywheel weight? What car what weight? '27's like to rev, my advice make it light.
  5. BuickBrad
    BuickBrad
    from minnesota
    the car will weight around 3200 with me in it...so about 15lbs or 20lbs?
  6. ct1932ford
    ct1932ford
    close ratio 220 is what you need. if you had say a 336 rear you could use a wide range 254 box.
  7. Black Panther
    Black Panther
    from SoCal
    You should use a close ratio trans...with a wide ratio 1st gear is lower, that coupled with your low rear gears would make 1st gear last you about 5 seconds when you drive it...it will wind out really fast and you wont be moving. With a wide ratio you get to wind out a little in first gear and it wont seem like a granny low in a pickup truck...my buddy uses later model lighter flywheels in all his cars...I regularly see near new aluminum flywheels with a clutch insert at swapmeets here for about $100 or so..
  8. BigPerm365
    BigPerm365
    Close raito Muncie transmissions had a 2.20:1 first gear....& the wide ratio had a 2.54:1 first.
  9. BuickBrad
    BuickBrad
    from minnesota
    what about the new Richmond 4 speed units? the tallest first gear they offer is a 2.43...would that ratio make my car drive like a dump truck with that 4.10 rear??? if i were to get one of those, would you recommend i throw in some 3.89's or 3.70's instead of my 4.10?
  10. nwbhotrod
    nwbhotrod
    from wash state
    That rear end will get old real fast I run a 3.50 rear and M20 trans
  11. Cerberus
    Cerberus
    With a 4.10 rearend you may want to consider a 5-speed. I installed a TKO600, 5-speed close ratio, 3.73 posi, mild 350/300 hp, in my '56 Chevy. It's a 3200 pound car.
  12. BuickBrad
    BuickBrad
    from minnesota
    Good call man...i used to run the 4.10 with a TH350 :-/ it was fun when i was 17, but not really that enjoyable anymore haha. are you satisfied with your cars off the line acceleration? is it a small block or big block car?
  13. maybelene
    maybelene
    Close ratio M22 in my '55 with 4.10 gears. Good street setup w/ 327 as 327 winds up good. Quick,quick, quick off a dead still start.
  14. nwbhotrod
    nwbhotrod
    from wash state
    I dont Race it but I do like to light it up ya it gets it on
  15. BuickBrad
    BuickBrad
    from minnesota
    Cool stuff man, are the rpms actually reasonable at highway speeds?
  16. Jalopy Joker
    Jalopy Joker
    search online: project33.com and click on calculator you can include a lot of options, including tire size to help figure things out
  17. pitman
    pitman
    The 5-speed suggestion becomes more feasible if you were running 3.23 ratio or thereabouts. 5th is usually an overdrive in certain factory trans's.
    Then the lower gears would still launch OK, but conserve on the top end.
