Sizing for Exhaust Manifold Bolts - 55 Belvedere
Discussion in 'The Hokey Ass Message Board' started by DaveGerard, Sep 24, 2012.
  1. DaveGerard
    DaveGerard
    I busted a few of these, and the rest are rusted enough that I figure it is a good idea to replace them. I think that they are 3/8, but I'm not sure, and the manual doesn't say anything about them, so I was wondering if anyone knew offhand the size that I am looking for. Thanks.
  2. squirrel
    What size wrench did you use to bust them off? If it was a 9/16" wrench, then they're probably 3/8".
  3. DaveGerard
    DaveGerard
    Yup a 9/16. I bet they are a 3/8, thanks for the help.
  4. DaveGerard
    DaveGerard
    Is there any reason I can't just use an appropriately sized bolt? My local Lowes has Grade 8s, is there any reason why that wouldn't work?
  5. Ebbsspeed
    Ebbsspeed
    Are they bolts, or studs? I thought most all Mopars back then had studs holding the exhaust manifolds on. My 56, 57 and 58 Hemi's all used 3/8 studs, co**** thread into the block and fine threaded nuts holding the manifold. A lot of them went into the water jackets as well, so you might need a dab of sealer on the threads.
  6. DaveGerard
    DaveGerard
    Studs, and you are right, I think one or two of them do go into the water jacket, I'll put something on those. Bolts would just be easier to grab and throw on, all the auto parts stores around me are little dinky outlets that don't have ****, so I either have to order off the internet, or if I go with bolts I can just run to Lowes. But I have been reading that the bolts can put some unhealthy pressure on the threads, unless that is just blown out of proportion. Basically once the new intake manifold goes on, these things ain't coming off for a while.
  7. Ebbsspeed
    Ebbsspeed
    You might try a hardware store instead of the home improvement places. Most every hardware store around this part of the country has quite a variety of studs in their fastener section. You could also order them from McMaster Carr and have them in a couple of days.
  8. DaveGerard
    DaveGerard
    Forgot about McMaster, that would work. Unfortunately the hardware stores in my neck of the woods also ****, but McMaster may be the best solution.
  9. pitman
    pitman
    If you do plan to take it apart anytime later, get some anti-seize paste for the threads, either way.
  10. DaveGerard
    DaveGerard
  11. RichFox
    RichFox
    Bolts will work fine. You might get stainless and use some antiseize.
  12. DaveGerard
    DaveGerard
    Ha ha and a pair of gripping pliers apparently, ****ers are stuck mighty tight.
  13. squirrel
    might want to use some heat too....so you don't just break them off shorter
  14. chopolds
    chopolds
    from howell, nj
    McMaster also sells hi-grade studs......if you do use them, get br*** nuts for them.
  15. 55 dude
    55 dude
    use some heat like squirrel said or your gonna be sorry as hell, studs break off and then the real fun begins!
  16. DaveGerard
    DaveGerard
    I got the torch all ready to go!!
