O/T Czech Tatra T 57 B questions
Discussion in 'The Hokey Ass Message Board' started by Dave Downs, Aug 17, 2012.
  1. Dave Downs
    Dave Downs
    from S.E. Penna
    Mods - please allow this to stay for a day or two; I don't know of a better place to get automotive information - on any automobile.
    My neighbor, who has no mechainical ability whatsoever has a Tatra T 57 B -1939?. I heard it run last year, he can't get it to run this year and has asked me for help.
    The engine is an aircooled flat four front-mounted
    The car has an electrical system, he has a starter but is is not on the car - last year he started it with the crank.
    I was looking it over today; gasoline is old (I can smell it) ignition is battery/coil/points - I have power to the points but no spark from points or coil.
    Need some basics:
    6 or 12 volts (he thinks 12 but that may have led to burning up the coil)
    I think it is positve ground
    Any sources for parts - the points look to be in bad shape
    Looking for any information sources, preferably in English, I don't speak or read Czech but my neighbor does.
    I did 'google' the car; the best I info I found was a British collectors club but no discussion board.
  2. dirt t
    dirt t
  3. ev88f
    ev88f
    Maybe put this over on thesamba.com I believe that there are some people there that know about tatras
  4. Hitchhiker
    Hitchhiker
    I bet if you clean the points up and some new fuel and it will run.
  5. UK RUSS 1960 OLDS
    UK RUSS 1960 OLDS
    Hi Dave Downs,
    I took these pictures at the Twinwood's Car Show (UK) 05-09-2010.
    Cheers.
    Russ.
  6. UK RUSS 1960 OLDS
    UK RUSS 1960 OLDS
  7. UK RUSS 1960 OLDS
    UK RUSS 1960 OLDS
    Hi Dave,
    If you try and contact cl***ic car of the year as in the pic there is a possibility they may be able to put you in contact with the owner of this one. I spoke to him at the show and he seemed to have an encyclopedic knowledge of Tatra cars.
    The man that runs this show, Dave Brown is a friend of mine and he may well have contact details of the owner as quite a few cars are pre-entered.
    Try and contact Dave Brown via this site,
    http://www.claphamcl***icevents.co.uk/
    If you have no joy drop me a PM and i will make enquires for you. It is possible Dave could be in the USA at the moment as he spends a fair bit of time over there and it is also possible that some of the HAMB members may know him anyway.
    If you think i can help in anyway just get in touch.
    Cheers.
    Russ.
  8. Mike51Merc
    Mike51Merc
    Gotta love those Czech Tatas.
  9. UK RUSS 1960 OLDS
    UK RUSS 1960 OLDS
    Hi again Dave,
    Try this website, i havn't had a chance to look properly but it may be of some use and seems to be all in english.
    http://www.tatraplan.co.uk/
    Cheers.
    Russ.
  10. Smitkees
    Smitkees
    from Amsterdam
  11. truckedup 28
    truckedup 28
    my moms cousin posted his picture on facebook. trying to find out if its for sale
  12. toddc
    toddc
    X2
    I'd bet that the points have closed up. If you clean and gap them it will probably run.
  13. UK RUSS 1960 OLDS
    UK RUSS 1960 OLDS
    Hi All,
    Took these pictures at the Silverstone Cl***ic 2011. Tatra V8.
    Cheers.
    Russ.
  14. Dan Timberlake
    Dan Timberlake
    A work buddy is a Czech engineer and a Tatra enthusiast and multi car owner. He says it would have been 6 v negative ground originally, but conversion to 12 v over the years is not unheard of. The starter and generator will be marked with voltage, etc.
    He also wonders if it is a car he heard about recently. All he was told was The owner (somebody long active in the Tatra community) of many years died about 2 years back, and the widow left the car has been sitting in a garage or barn in PA someplace.
  15. magoo
    magoo
    There is one at this museum that they restored some years ago
    http://www.southwardcarmuseum.co.nz/
    contact John Bellamore in the restoration workshop,he or his mechanic may be able to help
  16. Pauly da mick
    Pauly da mick
  17. Ned Ludd
    Ned Ludd
    People know all about the rear-engined Tatras but do not realize that the front-engined models like types 57 and 11/12 are as interesting, and arguably better cars:
    [​IMG][​IMG]
    To my mind these (and the Steyr type 50) were better Beetles than the VW Beetle ever was. For a start they've got their engines in the right place. The ch***is (type 11):
  18. mrjynx
    mrjynx
    heres a photoshop of one.
  19. Dan Timberlake
    Dan Timberlake
    Hi Dave - get the Tatra running yet?
    Dan T
