Features Econoline Madness Who's got one?
Discussion in 'The Hokey Ass Message Board' started by kornfedlifer, Apr 25, 2007.
  1. Fringe
    Fringe
    from Sacramento
    For sale in SLO CA. A bit rusty, but looks great.
  2. yamadafacka
    yamadafacka
    it will make alot more sense when its finished. still have a grille and bumper to do. and a height adjustment :D
  3. econovanman
    econovanman
    from yakima wa
    ok guys im hoping someone can help me out. looking for some pictures of crossmembers made to fit a c4 and 302 on a 65.
  4. go-twichy
    go-twichy
    i know a guy who makes them, no website, but i got a number if you like.
  5. greensheads
    greensheads
    I just brought this home. 52000 miles always stored in a shed. Needs paint, thats about it. I definitely have the Madness!
  6. dyoung
    dyoung
    from Goliad, TX
    My 64 Club Wagon
  7. kgp50
    kgp50
    Great thread, brings back lots of good memories. Learned to drive in Dad's 63 E Line going to the town dump.
  8. Needs Paint? Looks good from here.
  9. greensheads
    greensheads
    The paint is peeling off in several places. It looks like the body wasn't prepared right and the primer didn't stick. It looks fine, but I will go ahead and strip it down and repaint it when I have everthing out to swap in a v8/4spd/9inch :cool:
  10. dyoung
    dyoung
    from Goliad, TX
  11. econovanman
    econovanman
    from yakima wa
    well i can make just about anything but doing it right is the thing. do u know of any pictures i could look at? im trying to get the right idea.
  12. go-twichy
    go-twichy
    you eye is not going to pick up on what makes it fit. if you want to make it yourself, more power to you. take a stock crossmember and grind everything off of it except the frame flanges on the ends. prop-up your 302 with trans in place and make some cardboard templates to make up the space to your motor mounts. these should be new. the econoline c4 trans has a special hanger cast into the housing and uses a rubber donut. this should be new as well. my friend has all the templates and welding jigs for all the differnt years and engine combos. in a nutshell, this is how you would go about doing one for yourself. when i added the aod trans to mine, i needed to add a 1/2" thick spacer to get the engine down for floor clearance. the box like spacer that you will fabracate should be made of 3/16" plate, and will need to have access to motor mount center bolt. this will make more sence when you get all the parts lined up and get into it. good luck, kurt.
  13. Kurt, do you have any pics of the mounts for the AOD?
  14. go-twichy
    go-twichy
    i made the mount, but i dont have any pictures of it. i'll try and take one or two tomorrow for you.
  15. go-twichy
    go-twichy
    okay, it's not pretty, but here's my aod trans mount i made. this is a van that gets driven every week, so the underside is dirty!
  16. j.r. Nice
    j.r. Nice
    Nice mount.
    Is the AOD pan the lowest point on the truck? Looks lower than the straight axle?
  17. go-twichy
    go-twichy
    it's about the same as the axle. i had installed a trans drain plug when i put in the aod, and bent it over and lost some fluid. so i re-mounted it on the angeled rear face of the pan where it is in the pics.
  18. Thanks for the pics.
  19. Does anybody tow with their Econoline?
    I know it would have to be light, but...
  20. econovanman
    econovanman
    from yakima wa
    ok looks like a pretty simple design. but how well does the floor hold up to the torq of the v8? should i maybe extend mine to the subframe rails and possiably bolt to the corss support instead?
  21. greensheads
    greensheads
    For my v8 conversion I am going to be making some good horsepower, and i am concerned about this as well. My plan is to build a frame that extends from forward of the engine clear back to the rear suspension, and mount the engine and trans to it. possibly even mount the rear springs to the subframe(move the rear springs inward and down to allow for more clearance/ put the axle on top of the spring). This frame will bolt to the existing subframe.
    So basically i would be able to remove the drivetrain from the truck all in one unit if I wanted to.
  22. go-twichy
    go-twichy
    thats a 3"x4" angel 5/16" thick with 8-7/16" bolts going through the floor on the low ribs! there's no movement. the old ford mount was as you probably know, was a single 1/2" bolt through a rubber doughnut. you could tie it in to the sides if you want, but i cant see it adding much because the unibody frame is pretty light gauge. you would need to weld tubes through with plates on the ends so you could put bolts through without crushing the frame.( if you can call it that!) the shock mounts can give you an idea of how you might go about doing it. the aod does weigh more that the stocker. kurt.
  23. Hogride
    Hogride
    Hay Guys ! Has eny One put a big block in yet. 460 ford or 454 chev with a little set back & a auto trans
  24. olgraybeard
    olgraybeard
    I pickrd this 63 up a couple of weeks ago engine runs good, needs every thing else, going through it one thing at a time. Rewired ignition added single wire 65 amp alternator out of a Mazda. Needs all hoses /brake lines replaced. Lots of rust throughs to repair. But the big deal for me is I need a manual 3 speed stock transmission (short shaft for van) cheap this one has no 2nd gear.
  25. Hellfish
    Hellfish
    A 351 barely fits between the seats with floor and dog box cutting. A big block would probably have to be set back behind the seats.
    1. What engine do you have? The 144/170 trans is very different from the 240. The small 6 trans will only bolt to a small 6 engine, and is fairly weak. The Big 6 trans shares the same bolt pattern with the 300ci 6 and the SBF v8s (289/302/351w) and is fairly stout. Different driveshafts, too.
    2. I think the only difference (I think) between the Econo and other Ford 3 speed 6cyl transmissions is that the car/PU versions bolt to a crossmember, and the Econo line versions hang from the floor. You might be able to get a regular trans and swap the mounts.
  26. olgraybeard
    olgraybeard
    I have the 144 cu in a small transmission it has a short tailshaft (about 8-10") the Falcons and Rancheros have a long tailshaft (about 24" long)
  27. Hellfish
    Hellfish
    Shorten your driveshaft. :) swap the guts from one trans to the other? Skip 2nd gear? :) Get it rebuilt?
    You should be able to find a junked Econo or one being parted out in your area on CL, ebay, or in an old junkyard
  28. rodfather28
    rodfather28
    Hi George
    just been catching up on this thread, do the headers on your L6 fit in the dog house ok or did it need modifying? was thinking of using the headers from cl***ic inlines on mine but before i go to the trouble of shipping them over to the UK was wondering if there were any clearence issues.
    Mick
  29. econolineherb
    econolineherb
    Go to the Econoline groups and get your headers . The over the counter won't work in our Econoines .
  30. olgraybeard
    olgraybeard
