Projects Found on Kijiji 1928 Roadster!
Discussion in 'The Hokey Ass Message Board' started by RetroSteel, Apr 7, 2012.
  1. Started making a floor out of 16 gauge steel. Used a bead roller also. Made a hatch to get at the Master Cylinder and a transmission tunnel
    Step up behind the seat
    Floor behind seat where fuel tank will sit
  2. hillbilly4008
    hillbilly4008
    Very nice, 28-29 are my favorite roadsters! Collecting parts to build a Coupster now.
  3. Thanks Hillbilly! Keep us posted on your Coupster build!!:D
  4. Here are some updated pictures showing the progress on the '28 Model A Roadster
    Using a '32 dash with custom insert Custom made Using Speedway Motors (You polish & drill blanks) 2 inch chopped & leaned windshield posts
    Custom made access plate for the Master Cylinder
    Custom bent 1 3/4" pipe for side impact. Also removable floor piece over the transverse spring. Will be using an O'Brian Optima battery box.
    This roadster was an original rumble seat car. We have changed that to a regular opening trunk lid. Sprung for a Brookville trunk lid as the original trunk lid was bent up inside & out. Trunk lid was just sitting in there for the pic and will be needing adjusting!
  5. Drivinford
    Drivinford
    Great looking roadster
  6. Johnny C.
    Johnny C.
    Really cool roadster. I am starting on a 28 as well. Look forward to watching your build.
  7. 41woodie
    41woodie
    My gosh am I out of touch or what. When I saw the ***le of the thread I thought Kijiji was probably a south Pacific island and wondered how a '32 got way out there. Sad
  8. Thanks!
    Thanks Johnny! Good luck on your 28!
    Here's a Tim Mcgraw that explains it all:
    http://youtu.be/9PgfQpJFYp8
  9. ss34coupe
    ss34coupe
    Coming along nicely! Good work!
  10. hillbilly4008
    hillbilly4008
    That this is like *** on Wheels! Love it!
  11. Thanks!
    Thanks hillbilly!
    Here are a couple of update pics i took while test fitting parts.
    Using curved gl*** SoCal gauges and a seperate SoCal Tach & bucket on the column. Old school chrome turn signal unit also. It comes with a 4 way flasher knob.
    Using a vintage style racing gas cap
  12. Blue One
    Blue One
    from Alberta
    Where did the gas cap come from and how will it be attached to the tank when mounted to the body.
    Next question, is it vented or not ? I can't seem to remember if you need a vented cap with a mechanical fuel pump and carbs, I believe you do.
  13. Don's Hot Rods
    Don's Hot Rods
    from florida
    Your roadster is VERY cool. I think the wire wheels and whitewalls make it.
    Don
  14.
  15.
  16. 206tee
    206tee
    Lookin' good. Great work. Keep us posted.
  17. reece
    reece
    from NC
    Tubing inside the body looks great. I imagine it stiffens the body pretty well. I may do the same on my coupe. Everything about it looks fantastic.
  18. Thanks and will be posting more progress pics in the future!
    Yes, it stiffens the frame like a cross member and can be used as a fastening point for seat belts & for mounting a bulkhead between the fuel tank & the back of the bench seat.
    Thanks redlineracer!
  19. Test fit the bench seat. Had to use 1 3/4 inch spacers in the front to get it above the transmission tunnel. used 3/4 inch spacers in the rear. With the added clearance i will run the fuse panel under the p***enger side of the seat. This will leave the inside of the firewall nice & clean of wires.
    Lots of usable space behind the seat when it is tilted forward. You can also see the front mounting tabs for the fuel tank which mounts to the steel cage.
    Custom stainless tank is aprox 21 gallons. Yes, we are planning some long trips!:D
  20. Looks great!!! From the little I can see of them though, the wheels don't look like Kelseys..... Just stock ford wheels. I could be wrong though, I would appreciate a better pic....
  21. skatermann, I maybe wrongly presumed that all Ford wire wheels were Kelsey Hayes? While Kelsey did manufacture bent wire 35 & 40 spoke wire wheels it looks like Ford made the 30 spoke?:confused: nHere is a pic of the back of one of the rims.
    Which brings me to my next question. I bought this car with the rims & tires you see. They were mounted to the Chevy 5 x 4.75 bolt pattern using these multi pattern adapters for the 5 x 5.5 Ford wires. Is it safe to use these adapters with these wire wheels?
  22. Here is a pic of the bottom of the seat in the up position. Lots of usable space under the seat.
  23. tedley
    tedley
    from canada
    I'm really diggin this build.
  24. Thanks tedley!
  25. I talked to H.A.M.B. member Wheel Kid today about the adapters. I ordered a set of (4) steel spacers from him which sit on the adapters made specically for running 16 inch Ford wires .
    No need to buy a set of new adatpters!:D
  26. Atwater Mike
    Atwater Mike
    Regarding that frame setup, I did one using a 'T' frame like that, (as a 'subframe' in design, but actual 'frame' for legality!
    Customer wanted to register his '27 'T' Highboy as a 'T', and NOT stamp the 'T' numbers into his '32 frame. CHP came to my shop, looked at it, and signed it off.
    4 months later, I did one like that with a '28 'A' frame & body. Both jobs were done using rusty and damaged gennie '32 side rails.
    I also had a pair of damaged '32 rails, Turlock swap, $100. Got a pair of fronts from Jerry Kugel for very reasonable $$, nice fix. They went under my '27 Hiboy.
  27. servi53
    servi53
    looks great, excellent fab work
  28. ChuckleHead_Al
    ChuckleHead_Al
    Have you thought about running drum brakes up front instead of disk brakes? I think they ruin the look especially with wires.
  29. Here is a recent pic of the frame (upside down) for working purposes. I have the stamped number on the actual Model A frame. It will receive a new provincial government serial number as it has been modified when i apply for the Modified License Plate.
