my way to chop a '41-'48 tudor sedan
Discussion in 'The Hokey Ass Message Board' started by CHOPPED '46, Sep 26, 2012.
  1. I know there are a few different ways to chop a '41-'48 tudor sedan,but this is the way I did it.
    with much help of a friend.
    the first thing I did was to remove the paint of the roof.
    then we cut the doors
    did some bracing in the body.
    we welded in some more square tubing after the pic
    cut some original bracing with the plasmacutter
    removed the original bracing behind the quarter windows.
    welded the p***enger door to the body for support.
    the drivers door was removed and we added some more tubing of support
    removed the B pillars
    the first plan was to remove the intire rear section and weld it back in a different angle
    from the inside
    cutting the rear section
    nice hatchback.
    removed some centimeters of the A pillar
  2. new position of the roof
    I did'nt want to cut the roof and fill/stretch it with a piece of metal because of the radius of the roofline
    the first plan was to change the angle of the rear section of the roof.
    but that didn't work for me.
    so we are going for plan B !!
    we are going to remove a piece of 5 centimeter of the quarter panels
    the whole rear section moves up to the front and makes it much easier to
    line it up with the roof.
    cutting
    lost a few pounds
    put everything together with clamps
    the other side also
    the tile's in the car are to recieve the proper stance.
    the car was much lighter in the back. I removed the interior and the propane gas tank.
    shortening the rear quarters
    the rear axle is moved up front 5 centimeter later on.
    recreating new rain gutter
  3. the plan is to move the battery to the trunk in the right fender.
    the bracing for it is allready made
    reshaped the quarters
    we used some cardbord reference pieces to make both sides the same
    the first step is made to reshape the fenders.
    reshaped the radius of the quarter window.
  4. chaddilac
    chaddilac
    Very Very Cool!!!!!
  5. and we move on.
    the most difficult part of the chop.reshape the rear fenders :hammer:
    some labour behind the english wheel.
    it needs some minor m***age:hammer:
    and filling.
  6. the other side.
    removed the hole for the gas filler door also.
    this hole needs to be filled with some new metal
    much hard labor on the englisch wheel.
    made some mig spotwelds
  7. the p***enger side after some tig welding
    the drivers side needs to be done to.
    reshaped the upper part of the door.I want slanted doorposts.
    the B pillars needs to be done.
  8. the drivers side tig welded together
    and it goes on and on.
    after some welding on the inside and outside we rolled it outside.
    the upper side of the doors need to be replaced,so it looks a bit funny for now.
    the rear of the car goes down when there is more weight in the rear.
    gas tank and some more stuff.
  9. [​IMG]
    left B pillar is welded in.
    many things to do for now.
    what do you guys think of it ?
  10. chaddilac
    chaddilac
    Looks right on to me!! Looks great!!!
  11. koolkemp
    koolkemp
    Great to see all your chop pics in one place! Looks great!
  12. fordman1
    fordman1
    Will you be sliding the axle or the rear wheel opening to align them?
  13. I will slide the axle.
    looks better in my opinion.
  14. slider's house of kustoms
    from idaho
    i've seen guys trying to make a 444 volvo look like a ford never seen a guy cut up a ford to make into the proportions of a 444! :) Just kidding amazing work.
    volvobrynk likes this.
  15. Nice side profile on the chop. Hard to make these cars look rite with a chop. A guy in Oregon has basically the same profile, but with straight B pillars. He dropped the top straight down at the B pillars, angled the A posts, then reworked the rear and fenders like you did. No cutting out the back window and no cuts in the top of the roof. The drip rail in the rear lined up with the belt line crease on the body. The trunk lid dropped down and eliminated the rear pan above the splash pan. This was the 1st chop on one of these cars that I liked. It was still proportioned. Yours is the 2nd one I have seen that looks rite. I have had these cars for 45 years and am very critical of chops on them. You done good. Love it. Pat
  16. thanks for your kind reactions.
    the back window is welded back in the original position.
    may this be a lesson for the next one who wants to chop it the same way.
  17. el Scotto
    el Scotto
    from Tracy, CA
    Very nice!! I like the way you did that! :)
  18. draider
    draider
    from Texas
    That was a lot of work, but it turned out nice!
  19. dad-bud
    dad-bud
    Geez, that looked easy - so what did you do after lunch then?
    Hmmmmm???
  20. It was a lot of work, so to come. Now the last pieces yet, that we still have.
  21. More pics in a few days
  22. Mean Lean
    Mean Lean
    This model is a ***** to cut down but I think you did it the right way, just a bit of welding and a bit of lead and you are on the right way, see you next summer.
    Leen
  23. thanks Leen.
    the car is also at the motorama in november.
    maybe I'll see you in Rosmalen ?
  24. Looks good.
    Do yourself a favour, start wearing glove a GOOGLES. You've only got 2 eyes. They don't do well with sparks.
  25. walter
    walter
    Nice job!! I realy like the side profile.
  26. Besty34
    Besty34
    Thanks for sharing , I would have never thought of doing that way - beautiful job
  27. That,s not me. It,s my buddy.
  28. just another pic.
  29. chaddilac
    chaddilac
    That looks so natural!! Nice job!!
  30. billys54
    billys54
