Projects 61 C-10 Cevy
Discussion in 'The Hokey Ass Message Board' started by Yajr, Sep 26, 2012.
  1. Yajr
    Yajr
    from DFW
    OK I am just starting my new project a 61 Chevy C-10 custom and am thinking that I'd like to put a Chevy 350 or 305 in my truck the previous owner put a ford 9" rear end (I haven't checked the ratio yet ) and a T400 trans in it so my question is,Does anyone know What do I need to do in the way of motor mounts for my power plant ? any advice here would be greatly appreciated
    Thanks Guys
    Yajr
    ___________________________________
    No sign off statement thought up yet.
  2. squirrel
    What engine does it have now?
  3. Yajr
    Yajr
    from DFW
    The engine bay is empty now.
    Yajr
  4. squirrel
    Is the transmission in it? can you maybe take some pictures of the engine bay, so we can see what you have to work with?
  5. Yajr
    Yajr
    from DFW
    Yes I can take some pics but will have go to the truck....its not at my house. The trans is it and it has a bar across the frame rails to hold up the front of it Hold tight I will get some pics and thanks again
  6. 327Eric
    327Eric
    find frame mounts for a 63-66 pickup, set the motor in place and drill the holes. The trans crossmember is tricky because of the torsion bars. A buddy and I put a 389 Pontiac into a 60, and just drilled the torsion bar crossmember, and used a stock trans mount.
  7. BOWTIE BROWN
    BOWTIE BROWN
    Yajr.... pay attention to Squirrel , show some pictures & everything will be ok .
    Keep it posted please .....good luck .
  8. squirrel
    I'm guessing that if it has a TH400 in it then someone already made motor mounts too
  9. Yajr
    Yajr
    from DFW
    Thanks Squirrel and will do BOWTIE BROWN. I will get some pics as soon as I can got my Bud sending them to me when he gets home
    Yajr
  10. Yajr
    Yajr
    from DFW
    Thanks Studebaker eric
  11. 65gregg
    65gregg
    from Willis, TX
    67-72chevytrucks.com is home to a wealth of info. Check out the 60 thru 66 section to start.
  12. Brad54
    Brad54
    from Atl Ga
    I'm with Squirrel on this one--a TH400 doesn't just bolt in... nor does ANY Chevy trans.
    Originally they had bellhousing mounts, with the trans hanging in space. The front mount was a saddle that went to the front of the engine, with a single mount below the crank pulley.
    If someone already mounted a modern trans in it, that means they made a cross member, and there's a good chance they took care of the side motor mounts.
    though.... now that I think of it, there WERE some side mounts available, for auto-equipped trucks. I think they might have used a factory trans crossmember for auto-trans equipped trucks.
    Either way, there's a good chance you've already got what you need if someone started the swap.
    -Brad
  13. Yajr
    Yajr
    from DFW
    OK I finally got some pics and here they are....
  14. squirrel
    Looks like they didn't put side mounts in it. You should.
  15. I used a set of engine towers from a '69 c10 on my '62 c10 when I swapped from the 235 inline 6 to a sbc.
    David
  16. Yajr
    Yajr
    from DFW
    right on thanks guys
