Need road side help in Knoxville, TN... Anyone close?!?
Discussion in 'The Hokey Ass Message Board' started by Ryan, Sep 26, 2012.
  1. Another bump for the dayshift
  2. jd55f100
    jd55f100
    from alabama
    Bump ....for the A.M. did joe make it to TN
  3. jd55f100
    jd55f100
    from alabama
    He did say he had an electronic ignition
  4. I was on the phone with him thru out the evening. The car is sorted out. He hammered 'Lil Jewel 75-80 to Knoxville. It was an overly rich condition. The gremlins of the New Orleans humidity bit him. He'll post a bit later. Thanks, he appreciates y'all.
  5. ratster
    ratster
    i wish i seen this yest. here is my number if Joe still needs help. 865-964-5566
  6. The unilite has a 12V switched power lead, it has a ground wire than needs to go to ground and then it has an external coil with a resister between the 12 power and the coil on the positive side and a wire that runs from the distributer to the negative side of the coil. I have used GM and MOPAR resistors but they prefer the mallory resistor. Will run on any of the 3.
    Give me a minute and I'll get the wore colors for each lead.
    Back in a jiff,
    Benno
    Green - negative coil
    Red- switched hot
    brown - ground
  7. Harrison
    Harrison
    Just saw this. I'm in Knoxville.
    Sounds like it's sorted out but if he needs any help have him call me at 865-719-9919.
    JH
  8. Harrison
    Harrison
    Joe just called me an hour ago. He is at The Hot Rod Barn in Knoxville. I'm tied up at work but he is still having trouble. Said it is running.like **** and burning fuel like crazy.
    I gave him a number of a guy to call. Don't know what he found though.
    JH
    Sent from my YOUR MOM'S HOUSE device using the TJJ mobile app
  9. JOE C.
    JOE C.
    Met up with El Jefe in Knoxville. Changed plugs, again. Replaced plug and coil wires.
    About to get it back on the road. Will keep y'all posted.
    Thanks for all the support. Y'all are way cool. Larry Griffey and his crew at Griffeys Hot Rod and Restorations helped us diagnose and let us use his shop.
    Reggie Hill has been dispensing sage advice the whole time. Thank you one and all.
  10. JOE C.
    JOE C.
    Can't forget my boy Raymond Rupert at Reliable Hot Rods.
    Thanks
  11. AHotRod
    AHotRod
    Keep us posted fellas
  12. pwschuh
    pwschuh
    BTT, Hope he's still making progress. They'll be plenty of flathead support at Pimlico.
  13. vrod64
    vrod64
    from Katy,Texas
    Reggie mentioned fouled plugs..may be water in the gas ? Is this the Riveria ?
  14. Clark
    Clark
    What kind of air cleaners is he running? We just had a flathead that had a problem running rich under load. Thought it was ignition and then carbs...ended up the air cleaners were choking it.
    Just a thought.
    Clark
  15. Count Scrapula
    Count Scrapula
    from Mid TN
    Don't know where you guys are at now. I didn't see this til now. There's an old timer here in Crossville that's a flathead guru. We're about 65 mi west of Knoxville. Let me know, I can put you in touch with him if needed.
  16. SakowskiMotors
    SakowskiMotors
    So what was it? How is it running?
  17. slobroy
    slobroy
    What Clark said. That would be hell if it was.
  18. vtwhead
    vtwhead
    BTTT...did Joe ever make? Anyone heard anything? Curiosity is killing me!
