1933 Plymouth Build
Discussion in 'The Hokey Ass Message Board' started by cjo13, Aug 14, 2012.
  1. cjo13
    cjo13
    from SD
    Just checking the waters here, Does anybody know the Rear end width on a 1933 Plymouth PD Coupe? I was looking for a 440 engine for my coupe and found a so so deal on a 71 Plymouth Satellite Sebring plus. This has a rebuilt early 440 and 727 trans. Thinking if I could use the Rear end and a few more parts off the car it might be worth it. Some research found that the Rear is 57.8" flange to flange and 62" Overall width.
    For some reason I am thinking a 440 and a 4 speed is just what this fenderless coupe would love.....
    CJO13
  2. 73RR
    73RR
    Any fenderless coupe would benefit from a 440 4-spd...;)
  3. Old Dude
    Old Dude
    I have several early 440, 400, 361 & ect. I have a few 727 trannies. When i built mine over 12 to 14 years ago, i used 8" Maverive with built '78 360 from a Dodge Magnum, Lady owned, with low miles. Just seen a Hi-Boy '33 Friday night at ****ord Cruise In. It looked tough ! I have all kind of speed parts for 440's. Reduction Starter, Cromed Alternator & so on. I was going to build a '34 Dodge Pk. Up. Cruise On,
    Old Dude.
  4. Von MoPar
    Von MoPar
    from Australia
    I think the "A body" 8 3/4" rear end would be the narrowest, and you would need a positive off set rim.....
    or the 58 to 60 ford 9" rear end (u bolts shockers/plates) will drop straight onto your existing rear leaf springs, still requiring a more positive off set rim.....to fit bigger rims and tires under the fenders.
  5. notaford1
    notaford1
    from webster ny
    Satellite rear should fit fine I have an 8 3/4 coronet/satellite rear in my 29 Dodge and it is same width as the 8" ford I have in my 33 plymouth.Hope this helps.
  6. 1933dodge
    1933dodge
    from MN
    You want an A body it will bolt up to the springs
  7. notaford1
    notaford1
    from webster ny
    Just be aware that an A body rear has the small 4" bolt circle for the axles not the 4 1/2 that all the other mopars have
  8. signalsteve
    signalsteve
    from NH
    74 dodge dart 8 3/4 posi works well too////
