1936 Chevy Chevrolet Truck
Discussion in 'The Hokey Ass Message Board' started by nhmikel, Aug 5, 2012.
  1. SmokinBill
    SmokinBill
    Found some left-overs from a resto at the swap meet last weekend. Put'em together in the backyard for the wife's Hot Rod Planter box
  2. nhmikel
    nhmikel
    from NH
    Thanks Bill
    Not exactly what I'm seeking on my thread
    Willing to sell those parts?
  3. Graham M
    Graham M
    from Calgary AB
    Mines a 38 Chevy half ton, Close but not quite. :(
    You may want to take a look at some of the Gel batteries out there, such as Optima as an example. You can mount them on their side, upside down, anything and anywhere. Which really opens up your options. I'd almost leave it where it is, get a Gel battery and mount it sideways, so it'll save a bunch of ground clearance.
  4. Under the passenger side floorboard.
  5. That is pretty much what mine is like as well.
  6. mustang6147
    mustang6147
    from Kent, Ohio
    Thanks,
    My wheel base is 105" and my bed is 64".
    Under the floor is great, I opted for the bed, because I have watched so many struggle when trying to get or give a jump start to a fellow rodder. If I ever put it under the floor I will put a remote post for ease.
    Just my thoughts.
    Like these old trucks
  7. nhmikel
    nhmikel
    from NH
    Correction I need to measure the WB.... it should be 109
    Like you if I keep under the saet there will be a remote positve post
    Or just put under the bed????
  8. I can reach the positive post from the engine room. I have a door on the floor in the cab that allows access to the negative post with a disconnect on it.
  9. 50adrod
    50adrod
    from Louisiana
  10. nhmikel
    nhmikel
    from NH
    Lets see more pics
  11. nhmikel
    nhmikel
    from NH
    Completed yet another goal........
    Was able to my project back under cover
    Went into newly built "small" garage under my deck
    Just enough space to work during the winter
    Hope all goes well
    Anybody else updates?
  12. nhmikel
    nhmikel
    from NH
    Anybody close by? Got extra parts? Maybe getting another cab soon
  13. jarhead
    jarhead
    I live in Connecticut....you can private message me.....
  14. nhmikel
    nhmikel
    from NH
  15. Streight8
    Streight8
    I put my battery under the seat but I built up a box area and sunk the battery so it was partially exposed underneath to ensure it would stay cool. Hinged the box top so i could lift it up when the seat was folded forward.
    Build used 69 Nova front clip and rearend (3.08) the Nova mono leaf springs and gas shocks. Camaro rear sway bar. Very smooth ride and great handling. Kept drum brakes to keep wheels inside fenders on front. Drive train was a 350 4bbl 4 bolt with a performance power glide. Box was shortened to end where the frame did. PU Box was built using sheet metal and 11/2 inch exhaust pipe. Running stock truck to finished rod was 18 months. Haven't come close to that record for a long well. (pre kid daze):D
    attached a picture of truck
  16. nhmikel
    nhmikel
    from NH
    Any more pics out there?
  17. Rons36
    Rons36
    from San Diego
    Here's mine
    [​IMG][​IMG].
    All Stock everything.
  18. nhmikel
    nhmikel
    from NH
  19. nhmikel
    nhmikel
    from NH
    My truck is inside. Hope to get to it soon....as the snow flys
    Who's got parts or needs?
