If anybody out there has an UNinstalled Flat-O kit, I need a dimension. What is the front to back dimension of the aluminum bell/adapter that mates the C-4 to the Flathead block/bellhousing? Like if it was face down on a flat surface and you stuck the ruler thru the opening and measured up to the mounting surface. Can anybody help?
Flat-o Products in Salem Or is owned by Gene Benson Gene is a great guy and a quick call to him and you'll have your dimention. Flat-O , 503 364 2934 Ted
