Offset pinion and pinion angle
Discussion in 'The Hokey Ass Message Board' started by ADReese, Sep 29, 2012.
  1. ADReese
    ADReese
    from spokane
    Just a quick thought here and I would love to hear some opinions. The 9" in my model a has an offset pinion so the drive shaft angles toward the p***enger rear of the car. Can I run less of an up/down pinion angle because the sideways angle will already help to lube the u joints. I have the engine mocked up at 3 down at the tail shaft and 3 up at the pinion, but Id really like to lower the engine a little in the front for firwall clearance and visual appeal. Thanks in advance for your thoughts guys!
  2. pasadenahotrod
    pasadenahotrod
    from Texas
  3. gimpyshotrods
    gimpyshotrods
    No.
    The up/down angles should still match. If you are at 3º, stay there. If you need to move the engine and trans, move the pinion too.
    It is not just about circulating the lube in the u-joints, it is about cancelling out the non-uniform velocity of the u-joint at the operating angle. They do not move at a constant speed.
    When viewed from the side, you can see that u-joints, at any other angle but 0º, operate in an ellipse. That results in a speeding up and slowing down of the joint. This must be offset by an opposite movement at the other end of the driveshaft.
    From Tom Woods: "If you were to watch a "U" joint move through an angle (the operating angle) from an end view . You would see that the joint in the driven shaft has to move through an ellipse. Because the joint has to move through each of the quadrants of this elliptical path in a fixed amount of time, the velocity or surface speed of the driven shaft increases & decreases 2 times per. revolution.
    With a conventional two joint drive shaft, if your second "U" joint has an equal or intersecting angle , The second "U" joint will be decelerating at the same time and at very near the same rate that the first "U" joint is accelerating, resulting in a smooth power flow through to your pinion.'
  4. ADReese
    ADReese
    from spokane
    How many degrees of articulation does the u joint need to lube properly? Can I add the two offsets together? ie 1 dgree down, 2 degrees offset=3 degrees articulation?
  5. 32ratsass
    32ratsass
    All you need is adequate, opposing angles at either end of the drive line. It doesn't matter if it's up and down, side to side, or a combination of the two. It'll work just fine.
  6. ADReese
    ADReese
    from spokane
    Gimpys: Ya I would absolutely change pinion angle to cancel the tailshaft, thats a given :) no worries there
  7. mpot
    mpot
  8. gimpyshotrods
    gimpyshotrods
    An angle as little as 1º, as measured between the trans output shaft center line (or pinion), and the driveshaft center line, is sufficient to circulate the grease and move the bearings.
    THAT angle can be on ANY plane.
  9. ADReese
    ADReese
    from spokane
    Gimpys: were talking about the same thing here, just in different words, its all good. My hypothetical setup would be 1 down at the tailshaft, 1 up at the pinion and 1-2 offset both front and rear caused by the offset pinion.
    Thanks for all of the input guys! I love the HAMB
  10. gimpyshotrods
    gimpyshotrods
    Ah ha! Makes sense now. Coffee still has not kicked in yet. Off to get another cup.:eek::D
