painted my truck best way to clean flat paint
Discussion in 'The Hokey Ass Message Board' started by 1948stude, Sep 29, 2012.
  1. 1948stude
    1948stude
    here are a couple of pics. I also did try and search for this but was not finding anything...... web search showed some stuff but mostly people trying to sell products....It is PPG paint with flat clear 2 stage paint Thanks!
  2. 65PANELRAT
    65PANELRAT
  3. Cerberus
    Cerberus
    For the past five years, I only use water, squegee, spounge, chamois, new beach towels.
    Great job on the truck!!
  4. Rob Paul
    Rob Paul
    I tried tons of stuff. Nothing worked. Mine was PPG flexed and flat clear. Couldnt clean up fingerprints and smudges. I made it shiny once I got sick of trying to clean the flat finish. (crazy right??)
    Ive head guys using everything from windex to pledge, spray detailer and everything in between. Gotta try a few and see what works for you.
    Good luck.
    ROb
  5. kyvetteman
    kyvetteman
    I haven't tried this yet on mine, but someone told me they use powdered Ajax and water and it keeps the finish looking "flat". Said it buffs the finish without being too abrasive. Mine is getting shiny in places like where my arm lays on the window sill.
  6. Gman0046
    Gman0046
    On my satin black I use spray detailer to remove hand and finger prints.
  7. Old Heap
    Old Heap
    I use Lucas Quick Detailer on my Hot Rod Flatz paint job, works well.
  8. slowmotion
    slowmotion
    Heard of guys using Windex on their factory 'denim' painted motorsickles.
    __________________
    posted using a tin-can & fishin' line, tied to a pole out by the road
  9. cobra_4
    cobra_4
    I've never found anything that really works good. Awesome truck though!
  10. ronk16
    ronk16
    i use Castle gl*** cleaner and a micro fiber cloth. thats it nothing else. i paint for a living and use it to pre clean all my cars prior to prep for paint. the stuff just works. I clean my flat metalic black t-bird with it also , try it and you wont need anything else.
  11. 1948stude
    1948stude
  12. 1956 F100
    1956 F100
    from Louisiana
    I used Windex on my truck paint is 5 years old. Still looks good.
  13. wallyringo
    wallyringo
    my thoughts too, im burnt out on my flat satin paint, your truck is awesome.
  14. GassersGarage
    GassersGarage
    This is a base coat without a clear coat. I use "Adams" detail spray once week.
  15. On my flat forty, I us mainly soap and water, for bad spots I use foaming window cleaner. But over all, what a pain in the *** to keep clean, I'd never do a flat colour again---al least I don't think so!
    BTW, your truck looks great!
  16. ronk16
    ronk16
    exactly the same as i have , one can lasts quite a long time. you dont have to sause it up just mist and wipe.
  17. I don`t have a solution but I like that Truck! The paint looks great.
  18. no55mad
    no55mad
    Water wipe down then Lemon Pledge.
  19. hot rod wille
    hot rod wille
    I did the same thing on my roadster--Lemon Pledge smelled good ,too!
  20. the boogieman
    the boogieman
    i use all serface pledge on my hot rodz flatpaint works great!
  21. the boogieman
    the boogieman
    i use all serface pledge on my hot rodz flat paint and it works great.
  22. Don's Hot Rods
    Don's Hot Rods
    from florida
    Mequiars Tech 2.0 wax and a microfiber towel. I wouldn't have believed it, but someone posted that on here one time and I tried it on my SEM Hot Rod Black paint job. It made it look like the day we painted it, not shiny, just fresh. It also repels water and dirt really well. I have also dripped gasoline when filling up and a little more wax and the mark comes right off.....it actually protects the finish.
    Not cheap, about $20, but a bottle lasts forever and you only need to do the car maybe every 3-6 months, or less. It is also the very best chrome polish I have ever used, gives the chrome a deep look, and no abrasives to damage the plating.
    Here is the stuff I am talking about.
    Don
  23. ratman
    ratman
    I use gl*** cleaner never had any problems.
  24. sololobo
    sololobo
    Some nice tips there, should keep the
    Stude lookin real nice. Great job on the p.u., very cool! ~sololobo~
  25. 1badnov
    1badnov
    from South Bay
    I used PPG flexed and flat clear on my 65' & its been sitting out side for 6years now. I have never had any problems with fading or cleaning it. You can also try this http://www.houseofkolor.com/news/demo1.jsp
  26. terry48435
    terry48435
    I know Harley Davidson makes a cleaner for their bikes that have the factory satin colors.
  27. 1931modela
    1931modela
    from montana
    foaming window cleane in the can. non amonia.. clean lint free rag. nothing else or better
  28. jazz1
    jazz1
    Your truck looks great,,saved yourself a lot of grief using a quality paint and getting the flat clear on. Easy to clean,,just like the shiny ones. I also used the flat clear just not ppg paint
  29. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    see below
    If you ever plan on painting that truck - DO NOT use PLEDGE - ever - not even once.
    Yes it makes it look great as far as clean and a little liqourish shine, but you will have to blast that primer off and respray the primer and then your top paint coat.
    PLEDGE has oil/ wax in it and it will seep into the pores of the paint. Body shop wax and grease remover will not romove all it so if you paint the truck, it will look good in the paint booth regardless of paint brand UNTIL you get it out into the sun and heat from the sun will leech out the oil/wax of the body pores and your paint job will react and won't be nice.
    TRUST ME - don't use Pledge if you ever plan to put paint over ANY primer or you will have to strip it and reprimer prior to painting.
  30. 1949 caddyman
    1949 caddyman
    from arizona
    I had SEM hot rod black on my 32. I used spray detailer and micro fiber towels. Worked good, the paint was single stage with hardener.
