Hot Rods 303 Olds OR 331 Caddy ???
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Sep 30, 2012.
  1. harleycontracter
    harleycontracter
    Have to decide this week. What woould be the best motor to run in my 5 window? Looking for Period look and cost to rebuild and cost of speed parts.
  2. Paul
    Paul
    Editor
    what period?
  3. 31modelo
    31modelo
    You'll save a little using the Olds.
  4. harleycontracter
    harleycontracter
  5. thunderbirdesq
    thunderbirdesq
    Maybe, but probably not much all said and done.
    **Cough, cough, cad, cough cough***:D
  6. Paul
    Paul
    Editor
    can't beat the cl*** of the Cadillac
    but for me a well dressed Olds is where it's at
    whether it's a stock '49 303, a '57 J2 or blown '62 394 or anything in between
    I dig them all
  7. belair
    belair
    I like the Olds.
  8. zman
    zman
    from Garner, NC
    Either one will be great, I lean a little more towards the Olds.
  9. i think you'll have an easier time dressing up an olds. but a caddy is damn cool too!
  10. Dave50
    Dave50
    try to find the caddy parts bedfore you make a decision very bhard to come by and you will pay way more for caddy stuff so if your on a budget its a no brainer JMO
  11. Rusty O'Toole
    Rusty O'Toole
    If you mean the period 1949 to 1954 everyone's first choice was the Cadillac. If you couldn't find one or couldn't afford one the Olds was second choice. Chrysler hemi got respect but was too big, too bulky, too heavy and complicated. Studebaker too small in displacement and power. Buick was good but the starter made it hard to fit in engine swaps.
    Cadillac and Olds were #1 and #2 choice.
  12. 36 ROKIT
    36 ROKIT
    And speaking of starters, that's the one big advantage of the Caddy; its already on the
    right side, making the swap somewhat easier. As stated, however, speed parts for them
    are rare and spendy. As for the Olds, its "turn at bat" has come around again, so expect
    their prices to follow suit.
  13. langy
    langy
    I've had both so its either for me, both are expensive but the Olds slightly cheaper
  14. tubman
    tubman
    I've found 2 Olds aftermarket intakes at neighborhood garage sales. Never seen anything for a Cadillac.
  15. flatheadkid1
    flatheadkid1
    from OHIO
    Cadillac with early stamped steel script valve covers. Good looking engine....for an overhead that is.
  16. racer756
    racer756
    Olds...tony at Ross Racing Engines has all the parts you need.
    Cool build!
  17. ss34coupe
    ss34coupe
    Both are great motors, but I agree with others who say that some of the Olds speed parts - like a 3-2 manifold - are going to be easier to find and cheaper than one for a Cadillac.
  18. F&J
    F&J
    Period look with either motor.
    cost to rebuild- In the northeast, core motors that are not stuck would be hard to find under 500. Most core motors won't have a stick flywheel like the 331 you found.
    if you find that the 331 really does have 30 over pistons that are almost new, and if the bores are still good, that is a big savings compared to a typical Olds/Cad core that almost always would need a rebore and new pistons.
    Get a friend that knows motor rebuilding, to check that basket 331 out, looking for problems it may have. If it checks out OK, it would save some money that you can get an intake setup with.
    No matter what core you buy, there is always a chance there may be a problem that might be missed.
    I agree that the original old Cad speed parts are not as available as Olds. Two things would be the intake setup and adjustable rockers if you want those. I also agree that the stock Caddy valve covers look nice on an old build.
  19. Torkwrench
    Torkwrench
    Or with a set of these, by Bell Auto. :cool::cool::cool:
  20. harleycontracter
    harleycontracter
    Frank
    Already has adjustable rockers
  21. Paul
    Paul
    Editor
    what else comes with the Cad?
    it's sounding better all the time
    and that's from an Olds guy
  22. harleycontracter
    harleycontracter
    Motor
    Been degreased
    bored 30 over w/ piston & rings
    crank turned
    complete minus intake
    early Ford trans adapter
    Standard flywheel
  23. woodbutcher
    woodbutcher
    :D Sounds like a fun build.As for motor.(Cad/Olds),go with what your bankroll will support.Both are fun motors.
    Good luck.Have fun.Be safe.
    Leo
  24. harleycontracter
    harleycontracter
    Butcher,
    What's a bankroll? Haven't seen one in a long time..................
  25. F&J
    F&J
    Hmmm... Russ S. had a 331 up for sale late last summer... I saw it in his van at the Brooklyn CT swap. I don't recall the 30 over part, but I do know it had adjustables, and he was trying to sell the nice Eldorado factory Tri-power setup seperate. Motor was apart. I don't think the cam was there, or I would have looked at it. But I am positive there was not a stick flywheel in that pile, nor the adapter. I suppose whomever bought it, may have bought those two things later, if it's the same one that Russ had.
    I am pretty sure the Trips sold without the motor.
    That motor came out of Bolton; the long time owner was moving south I think. I should have bought it, it was a great deal when the intake was with it. He told me 800 for just the trips, but take the whole thing for 1k.
    It had Thomas aluminum or magnesium rockers, not steel ones.
  26. TERPU
    TERPU
    There's no replacement for displacement. Go Cad.
    Tim
  27. choptvan
    choptvan
    my 331 has high compression pistons, a dual quad edmunds intake, adjustable pushrods, and a few chrome pieces. Looking to get it rebuilt, running on a stand, and then going to get it sold. Got to fund buying a house. Don't plan on this getting me the whole down payment, but a big chunk of it for sure
    http://www.jalopyjournal.com/forum/showthread.php?t=733233
    So that being said, I am with a caddy all the way.
  28. vtwhead
    vtwhead
    I vote for Olds. IMHO the Cad stuff is grreat but I find that it is harder to cme by and more $ typically. Harley, between F&J and me we probably have everything to set you up with an Olds and we are only a couple hours away.
  29. GOATROPER02
    GOATROPER02
    from OHIO
    and an Olds bottom end is way stronger than the caddy...... I know.... I build both
    Also In Stock trim the Olds makes power easier and has way more torque.
  30. langy
    langy
    Listen to Tony, he knows his stuff !!! .................
