Hot Rods '32 Ford Pickup Rear Fuel Tank Install
Discussion in 'The Hokey Ass Message Board' started by 2935ford, Sep 30, 2012.
  1. 2935ford
    2935ford
    This may have been asked before but there seems to be conflicting information about this installation.
    I'm looking to install a rear fuel tank in my '32 pickup.
    Which one? What mfg's?
    I've heard both '32 car or '33 - '34 truck are possible candidates.
    The '32 car tank seems to have the right width while the '33/'34 tanks seem to be wider?
    Help with this would be much appreciated.:)
  2. krylon32
    krylon32
    from Nebraska
    I've been reading your thread on the Barn and have not understood how the 33/34 tank could fit. The frame in the tank area of a 32 is 40 inches wide and the same area in a 33/34 is 44 inches???? The 33/34 tank is flatter on top and doesn't stick as far above the frame as the 32. Maybe that's why some think it will fit????
  3. 3wLarry
    3wLarry
    from Owasso, Ok
    Hotrodprimer put a stock '32 car tank in the stock location and just cut a trap door in the bed for the cap...
    remember, all '32 frames are the same for car and pickup, so the car tank will fit just fine back there...
    kidcampbell71 likes this.
  4. 2935ford
    2935ford
    krylon32...that's why I'm trying to get to the bottom of this.
    The Tanks 33/34 tank is 42 1/2" wide...that won't work!
    The last thing I want to do is order the wrong tank!
    3wLarry...yes, I heard he did this. I'll have to see if he will send me pics or post some here. I hear from others the '32 won't fit as there is not enough room for the bed to sit down on??
    I'm just trying to buy the right tank.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Larry is correct,but ain't he always?:D
  6. 2935ford
    2935ford
    Gee, that was quick!
    Thanks.
    Who's tank (mfg)?
  7. HOTRODPRIMER
    HOTRODPRIMER
    Stock style metal p***enger car gas tank,,original or Vintiques but not the over sized ones. HRP
  8. 2935ford
    2935ford
    Oops...disregard my last PM to you about the oversized ones.
    I take it they are taller on top as well?
  9. HOTRODPRIMER
    HOTRODPRIMER
    I don't know but they look like a diaper full of poo,,no scene in adding a unknown to the equation,,, plus your gonna need to stretch your legs soon than later. :D HRP
  10. 2935ford
    2935ford
    So, the oversized tanks are that visible under a pickup rear?
  11. 2935ford
    2935ford
    I'll be using the stock "long" looking bed. So the tank will be further back under the rear and may not show so bad?
  12. HOTRODPRIMER
    HOTRODPRIMER
    Honestly,I've never seen another truck with a p***enger car gas tank,not to say they are not out there I just haven't seen any.
    I have seen them(BPGT'S) under coupes,sedans and roadsters,,I don't think they look good,I'm not knocking anybody for using them it all just boils down to personal preference. HRP
  13. rc32tx
    rc32tx
    I've got a p***enger tank, 11 gallon on my 32 pickup. My bed is shortened.
  14. 2935ford
    2935ford
    Yup, and I understand. I like the extra 3 gallons. I think my 59A, 276ci, 4bbl, 3/4 cam flatty is going to be very thirsty!
    I had a 17 gal Tanks poly in my hopped up 8BA flatty powered '35 slantback and that tank emptied pretty quick.
  15. 2935ford
    2935ford
    rc32tx....pics of the install? Same thing as Hotrodprimer having to trim the cross brace?
  16. 3wLarry
    3wLarry
    from Owasso, Ok
    even with the long bed and fenders, you'll see the bottom of the oversize tank.
  17. krylon32
    krylon32
    from Nebraska
    I've got the Tanks 14 gallon tank in my delivery and 3 window and it doesn't seem so bad with the extra depth but I've got the Vintique 16 gallon tank under my pu and it's got kinda of a droppy bottom??
  18. 2935ford
    2935ford
    Well, the Tanks 14 gallon is stated as being 1 7/8" deeper......I think the tank will show either way...stock form or extra gallon?
  19. 2935ford
    2935ford
    I guess I should make a mockup out of cardboard and stand bak and look at both depths and then decide.
    I sure appreciate everyones help on this issue.
    At least now I know....it's the '32 tank...not the '33/'34.
    Thanks all.
  20. ratrod0
    ratrod0
    Here is a 1932 ford truck ,6" short bed, car tank 14gal
  21. ratrod0
    ratrod0
    pics
  22. 2935ford
    2935ford
    ratrod0...thanks. I have those very pics. I could not remember if this was a '32 tank or not.
    I like how he did the side filler which is what I would like to do rather than cut a hole in my stock steel floor.
    This setup is more to the '33/'34 style and not sure how he got the side filler to work on a stock '32 tank and not intruding into the top side of the bed?
    Anyone know who's this is?
  23. tommy
    tommy
    I used an aftermarket tank and modified it for a 34 style filler. I prefer the Ford old time look to the streetrod look. I ended up using a 39 Ford coupe filler neck.
  24. 2935ford
    2935ford
    Tommy...thanks, that's what I was looking for. I'll be looking for the '39 coupe filler neck now! Probably repopped by someone?
  25. ratrod0
    ratrod0
    thats my dads truck I did all the work on it. bruse rod shop has it now in TX.
  26. 2935ford
    2935ford
    ratrod0...thanks....pics above and description helped a lot.
    Bruce's Rod Shop now has a very cool truck. Good work!
  27. HOTRODPRIMER
    HOTRODPRIMER
    I remember talking to Barry and his dad in Pigeon Forge,Tennessee a few years ago when they were asking me a few questions about my pickup.
    They went home and built a beauty! HRP
  28. tommy
    tommy
    I doubt it. I looked at a lot of filler necks to find what I wanted. I got mine at Hershey. I did not know what it was when I bought it. All that I was interested in was the shape. I learned later that it was from a fat fendered coupe or possibly even a sedan. It has a vent that goes all the way to the cap so it doesn't belch when you fill it up. We don't see these because most is hidden under the rear fender.
  29. 2935ford
    2935ford
    So, not like this vented '39/'40 repop from Mac's?
  30. 2935ford
    2935ford
    or Bob Drake's?
