optional gear drive?
Discussion in 'The Hokey Ass Message Board' started by shtterbug8, Sep 30, 2012.
  1. shtterbug8
    shtterbug8
    just been p***ing BS with the guys and a subject got brought up which i thought was intersting enough to talk on here about.
    here soon i will enbark in a 28roadster build with 4cyl ford banger and factory 3spd trans. we were talking about how it would be cool if there was a GEAR BOX drive inwhich had input of 1 and output of 2. that way you could get higher speeds also be awesome to find an OVERDRIVE attachment to install behind the transmission. all of this would require extensive fabrication to even attach one another together but i thought atleast in theory it would be cool to do 80-100mph with a stock banger engine. lol
  2. shtterbug8
    shtterbug8
    anyone know where i could locate a 1-2 gear box???? prefer small unit......
  3. Mount two transmissions *** to *** and that would do it.
    There are industrial applications that do what you are asking however I don't think they are switchable.
  4. CutawayAl
    CutawayAl
    from MI
    Doug Nash and Hone-O-Drive both made ***orted versions of what you asked about. Some were free-standing, others were integrated into the trans or axle. Others have made them too, but I'm not remembering any other company names.
  5. Not in a 1:2 ratio
    0.75:1 maybe a tad more
  6. RichFox
    RichFox
    It's unlikely that your banger could pull a 100% overdrive. If you could just keep adding gears to go faster, Bonneville cars would all be going 400. Maybe you could look for a Columbia two speed axle.
  7. squirrel
    If you can quadruple (or more) the torque output of the engine, then that would be a good idea. Modern go fast cars like Vettes run a 1:2 overdrive.
  8. Mr48chev
    There are a lot of overdrive units that mount either behind or in front of the regular transmission. One of my running buds has one on his big Block 4x4 chev that makes his cruising on the highway gas mileage half way reasonable. It only has a .75 or something overdrive though.
  9. 46Ford
    46Ford
    Ford, as well as most manufacturers in the up through the 60's offered 3 speeds with the Borg Warner electric shift overdrive unit. They were available for both open and closed drivelines and are 30% overdrive.
    Ford also had a top loader 4 speed that was used as a 3 speed + 4 was overdrive. They came in trucks back in the 70's and 80's. GM and Mopar had similar units made by New Process. Actually 3rd was the overdrive gear and the 3-4 shifter arm was inverted so that 1 to 1 4th became 3rd and OD 3rd became 4th. These were about 30% OD as well.
    30% OD will turn a 4.11 rear ratio into a 2.88.
    Not 1 to 2, but readily available and pretty much a bolt in.
    Mike
  10. A tub
    A tub
    get your wallet ready, this doesnt sound like a cheap option , but sounds good to me, keep us updated as to what you decide
  11. shtterbug8
    shtterbug8
    has any hamber done such a thing before with any luck? i know these engine dont put out much....
  12. Top speed on a Model A engined car with a 100% OD may be less than top speed with no OD. It simply cannot pull gears that tall unless it's putting out some very serious power. Plus, how will you engage and disengage this 1:2 box when you don't want it? If you are able to disengage it, how will the power flow through to the rear end?
    Ain't gonna work
  13. Cerberus
    Cerberus
    How about a two speed rearend?
  14. 46Ford
    46Ford
  15. shtterbug8
    shtterbug8
    i cant find a price for it. that sounds freaking awesome though
  16. Bruce Lancaster
    Bruce Lancaster
    They will happily pull the 30%, and the price starts looking fairly reasonable compsred to machine work to custom insert an OD into torque tube or convert T5 to TT.
  17. Go to the junk yard and find a small transfer case from a 4x4.
    Figure out how to mount it up backwards.
    Most have a 2:1 4x4 low range, if you can figure out how to spin it around it would be 1:2 100% overdrive
  18. Bad Daddy
    Bad Daddy
    I have one of those Mitchell overdrive units sitting up in the garage. It's never been used as far as I can tell. I had no idea they were still available.
  19. shtterbug8
    shtterbug8
    my heart skipped a beat when i saw the price. omg
    i think i might try a 4x4 transfer case like mentioned....
  20. squirrel
    What are you using for an engine?
  21. shtterbug8
    shtterbug8
    1928 model 4cyl. stock no mods. just trying to come up with a cheap way to run it on the freeway...
  22. seb fontana
    seb fontana
    from ct
    So you want to run a Model A at 65 mph or so? With everything else doing 75/80? Ambious but not a good idea...
  23. squirrel
    You might find that it runs out of torque, at about the same speed that it runs out of rpm.
    I can see adding an overdrive to an early ford if it has a flathead V8, which has twice as much power as your A. But I think you'll be disappointed with the performance if you try it in the A.
  24. shtterbug8
    shtterbug8
    well i guess ive been having a brain fart the past couple days. i forgot to tell yall that im not running the original rear end for the model a. im probably going to use a ford or chevy rear end from lets say an impala or ford f150. something like that. would that help me out on the highway or make the 0-60 any better just because of the gearing? then what would yall say be the best gears or rear end to use?
  25. RichFox
    RichFox
    Why do you want to use a 9 inch? Out of a pickup? isn't it going to be kind of wide for your car? And heavy? And they do use more horsepower than most just to turn them. Your banger will never need the strength of a nine inch. And the gears were right for a 351 or larger engine. Not going to help you on 0-60. What transmission are you thinking about?
  26. shtterbug8
    shtterbug8
    stock engine and trans. 4cyl model a . 1928 model.
    using a modern style rear end. the reason i use f150 rear ends sometimes is because they are cheap and plentyful.
    ford explorer is nice also because disk brake.
