No Damn Tailights!
Discussion in 'The Hokey Ass Message Board' started by alaskaal, Sep 30, 2012.
  1. alaskaal
    alaskaal
    from Delaware
    I knew there was a problem with the rear tail light buckets but thought I had it fixed till I got to the DMV inspection line!
    After my initial failure, went home and finally got em to work! Back to DMV and finally p***ed.
    With my Delaware Antique tags on the 63 i proudly cruised home to show the wife I was street legal!
    Decided I would take the beast to work early the next morning, not understanding the flashing lights of cars p***ing by.
    Damn rear running/brake lights arent workin. Signals are fine. Checked the buckets, adjusted the bayonet light sockets to fit snuggly, replaced a broken wire and checked the brake light switch off the master brake cylinder. Nothing.
    Ideas guys/gals? Have gotten lots of great help from ya'll during this build and was hoping for some more!!!!
  2. chaddilac
    chaddilac
    You check the ground?? Check the bulbs too!
  3. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Tail lights or stop lights? You seem to be referenceing both? Check that its gounded really well.
  4. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Chad, quit out typing me :mad:
    :D
  5. HOTRODPRIMER
    HOTRODPRIMER
    Sounds like your loosing the ground. HRP
  6. alaskaal
    alaskaal
    from Delaware
    Tail and brake lights. Have checked the ground under the hood. Unless there is a seperate ground for the rear wiring harness that I'm not aware of?
  7. alaskaal
    alaskaal
    from Delaware
    all new 1157 bulbs
  8. Engine man
    Engine man
    from Wisconsin
    Are you using the same bulbs for brakes and signals or are the signals independent?
  9. alaskaal
    alaskaal
    from Delaware
    dual filiment bulbs. A unitized system. 1 per side.
  10. 1964reo
    1964reo
    from mn
    your brake lites go throw your trun single switch try to pull back on your switch a little and work it up and down some times that helps do you have power at the brake switch
  11. alaskaal
    alaskaal
    from Delaware
    yup, and checked all that also....startin to think ive got a fuseable link issue.
  12. JohnEvans
    JohnEvans
    from Phoenix AZ
    Did you comfirm a good ground from bulb holder to bucket and bucket to body?
  13. Salty
    Salty
    from Florida
    Sounds like a ground issue.....
    The question begs what kind of tail lights? not the bulbs that are in there but the tail light buckets. Reason I asked is I have a set of repop 39 ford tail lights and regardless of being mounted on steel they did not want to work, after I soldered a ground wire on the back of the light fixture (bucket) and ran the wire to earth they worked fine.
  14. Engine man
    Engine man
    from Wisconsin
    The turn signal switch could cause the brake light problem because the brake and turn signal use the same filament in the bulb but it doesn't explain the tail light problem. It should be easy to check for power to the tail light from the light switch and from the brake light switch to the turn signal switch. Do the light sockets have a ground wire or do they rely on the socket body to provide the ground connection?
  15. headlite working ..
    taillite not?
    brake lite working?
    turn signal r-l front?
    turn signal r-l rear ?
    tools to fix
    a pointed 12V test lite that works
    do not disconnect anything use the sharp probe
    1st grounded to the neg post on battery in the car
    (USE A LONG LEAD WIRE IF NEEDED)
    check all above leads at the bulbs do they work?
    if not move the test probe closer to the source of power until the test light come on
    if they work then move test lite ground to other clean metal on the car
    you do have a ground batt to frame frame to body engine tobody right?
    retest take notes
    light sockets need to touch clean metal
    or have a separate grounded wire
    dash grounded
    steering column grounded
    check power with the test light at the flasher
    use the test light to check both side of fuses right in the box
    this is the ez stuff really
  16. 49ratfink
    49ratfink
    "a pointed 12V test lite that works"
    get a digital multimeter. your friends will think you are an electrical genius. I have a test light somewhere, haven't touched it in years.
  17. Mr48chev
    Each socket should have a ground or be grounded.
    Here is the back end of the car's wiring diagram.
    http://www.tocmp.com/tOCMP/wiring/5765wiring diagrams/Ford/MWire5765-214.jpg
    Here is the front end of the car's wiring diagram.
    http://www.tocmp.com/tOCMP/wiring/5765wiring diagrams/Ford/MWire5765-215.jpg
    Do you have working dash lights? NO dash lights means a blow fuse as the dash lights are connected to the tail lights/brake lights.
    If it's a six cylinder car the links are here http://www.tocmp.com/tOCMP/wiring/5765wiring diagrams/fordindex.htm
  18. alaskaal
    alaskaal
    from Delaware
    Wow. This is why I belong to the H.A.M.B!
    Workin today but will get back on it tomorrow. Updates to follow.
    Thanks to all!!!!!!!!!!!!!!!!!!!
  19. i think 49ratfink is an electrical genius and am not even his friend:D
  20. Dan Timberlake
    Dan Timberlake
    The problem(s) won't be able to hide from a multimeter or test light.
  21. mashed
    mashed
    from 4077th
    Forget about multimeters and get a simple test light. Be sure to clean the metal good where you clip the ground wire to.
    You're on the HAMB asking for advice about bad taillights. Unless your friends are complete idiots even a pocket protector won't help :D
  22. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Multimeters are street roddy. Test lights are traditional. :p
  23. n847
    n847
    Everyone has already pointed you to the usual culprits, ground or turn signal switch. I had a repeated problem with my after market 39 ford lights it just didn't want to ground, I wound up using an over sized screw through the body and it got better, but as soon as I added 3 new ground straps one from the frame to the body in the back, one from the frame to the body at the fire wall, and one from the frame to the block all my light problems went away and have never come back (knock on wood)! Ground straps are your friend!
  24. Check the housings, and follow Salty's route. Ground the bulb holders to a known good ground.
  25. alaskaal
    alaskaal
    from Delaware
    IT WORKED!
    After reading all the post and gaining ALOT of knowledge......dug in and worked all day.
    Replaced both rear sockets, several bad wires, installed 2 new grounds, and cleaned every elec connection I could find. Hell even the dash lights work now!
    Even found a new use for my pocket protector......great place to put my test light!!!
    Thanks again to all..................
  26. Congratulations!
    Glad you got it working! :)
  27. plodge55aqua
    plodge55aqua
    from Alberta
    Good to read that you got it working..
  28. tfeverfred
    tfeverfred
    Thanks for the update and closure. So few seem to do that.
  29. alaskaal
    alaskaal
    from Delaware
    Goin for a cruise in the morning!
  30. d2_willys
    d2_willys
    from Kansas
    A little tidbit, some headlight switches have small fuses for tailights. Also don't recall anyone pointing out a defective headlight switch. Even though the headlights work does not mean that the instrument and tailight portions of the switch are good.
