302 in a ford 36 without recess firewall????
Discussion in 'The Hokey Ass Message Board' started by kustoms36, Sep 30, 2012.
  1. kustoms36
    kustoms36
    sbf in a 36 without recess?? is it possible?????i really d'ont want cutting my firewall any tips???? thanks for reply
  2. kustoms36
    kustoms36
  3. F&J
    F&J
  4. saxet
    saxet
    from Texas
    Use pan, short water pump and accessories, as in '91 or so Cougar/T-Bird.
    In addition, the frame's front crossmember needs to be lowered (going with MII type suspension, or something similar. An alternative would be to drop the buggy-spring crossmember drastically, which would necessitate a deeply dropped axle in order for the driver to see over the front fenders. :))
    Without doing the above, I believe that the firewall must be recessed.
  5. lowtech36rod
    lowtech36rod
    from Kentucky
    i don't think so. a SBC, however, is! :) I did it in my sedan and run a mechanical fan.
  6. flynbrian48
    flynbrian48
    I can tell you for certain that a 302 will NOT fit in a '40 without major surgery, becaue I used to have one. Deep recess in firewall, trans tunnel. Even more on a '36.
    Brian
  7. Pensive Scribe
    Pensive Scribe
    I've seen this setup in a thirty four coupe, but I think it had MT II front suspension.
  8. bluestang67
    bluestang67
    I have a 37 I am placing a 351 in using the 95 mustang short water pump , must use the same timing cover. This is a reverse rotation with the serpentine but you can get a pump with correct rotation to run V belts .
    This combo will shorten a SBF to the same specs as a SBC .
  9. metal man
    metal man
    I have a 302 in my '40 with the original uncut firewall and long water pump. Just moved the radiator forward maybe an inch or so (very easy). It's not a '36 though.....
