Projects 38 ford coupe from downunder downunderIve done
Discussion in 'The Hokey Ass Message Board' started by mercurymitch, Jun 11, 2011.
  1. pug man
    pug man
    from louisiana
    Damn Mitch you Aussies sure do some great work. What a challenge and you seem to be taking it head on. Keep it up!!!!!
  2. rodl
    rodl
  3. s1buell
    s1buell
    from Indiana
    Mitch,
    It was great meeting you and your friend. It is amazing what you are able to do. Thanks again for the great shirt. I plan to to wear it this weekend at the NSRA Nationals in Louisville KY.
    Andy - Indiana
  4. mercurymitch
    mercurymitch
    from Australia
    Start by hammering from the inner end of the puck and work your way out ,the first row were 3inches long then 2 then 1 inch
  5. mercurymitch
    mercurymitch
    from Australia
    Sorry about that pic
  6. mercurymitch
    mercurymitch
    from Australia
    Notice I marked the top with a T,nothing worse than making 2 left hand sections
  7. mercurymitch
    mercurymitch
    from Australia
    Next i ran the panel through the English wheel to iron the bumps out
  8. mercurymitch
    mercurymitch
    from Australia
  9. mercurymitch
    mercurymitch
    from Australia
    I was quite pleased how this panel came out as it was the first time i had used a tucking fork.Next will be to make a bench / tool to bend the sides of the main section of the bonnet
  10. rodl
    rodl
  11. mercurymitch
    mercurymitch
    from Australia
    Next was to fit electric windows ,this was made fairly easy because i dont have door skins fitted.I used chip board as a temporary mount to work out how thick the bracket had to be
  12. rodl
    rodl
    Hi Mitch, those mechanisms seem to fit pretty neatly. What are they out of?
    RodL
  13. mercurymitch
    mercurymitch
    from Australia
    They are Dolphin ,most companies have the same set up.The only thing i would change is the attachment points for the glass by glueing a long channel to the bottom if useing triplex glass
  14. zibo
    zibo
    from dago ca
    Amazing amount of work going on down there.
    Makes my project seem rather light in comparison!
    You'll be a pro metalworker once it's done!
    TP
  15. afaulk
    afaulk
    Hi Mitch, totally impressed here in Alabama! So....looking at the before and after pics, exactly what original metal is left? Again, looking good.
  16. mercurymitch
    mercurymitch
    from Australia
    I pulled 4 doors apart and removed the antiburst bars ,then fitted them into the side of my car.
  17. clubcoupe37
    clubcoupe37
    this is a pretty cool pic. is the standard grille club coupe prevalent down under? the american club coupes were always deluxes.
  18. mercurymitch
    mercurymitch
    from Australia
    The original piece of the car is the section around the trunk lid and the body number
  19. mercurymitch
    mercurymitch
    from Australia
    I made two of everything to make the job easier and quicker and once you have one side made its so easy to do the other side
  20. mercurymitch
    mercurymitch
    from Australia
  21. mercurymitch
    mercurymitch
    from Australia
  22. mercurymitch
    mercurymitch
    from Australia
    I have been doing a lot of finishing of welds so not much to look at.Saturday i made a top bar for the bonnet side ,it tapers to the front so the bonnet will be more like a 37.
  23. mercurymitch
    mercurymitch
    from Australia
    I also wanted a strip to cover the join between the two halves of the grill and found a trim off an Austin A40 bonnet and bent it to suit
  24. dozza
    dozza
    Awesome job mate!
  25. Roy39
    Roy39
    Awsome job you are doing there " mate " Came across your thread and must commend you on your talents. I did a 39 tudor but not to the extent you are doing yours. As we would say "way to go buddy"
  26. mercurymitch
    mercurymitch
    from Australia
    Made the other side for the bonnet sides
  27. mercurymitch
    mercurymitch
    from Australia
    The next 2 bars are damaged and need to be repaired before welding the new top on
    also setting the brake booster up and pedal assembly
  28. The Deluxe is a little more popular, most people think it's better looking than the Club Coupe. There are not a lot of Deluxe or Club coupes here in Oz the 37 is much more popular.
    Doc.
  29. mercurymitch
    mercurymitch
    from Australia
    As i did not have a dash board ,i decided to make my own.Something a little different and probably not every ones choice.[​IMG]
  30. mercurymitch
    mercurymitch
    from Australia
    and the return on the door.
