primer search greenish color?
Discussion in 'The Hokey Ass Message Board' started by kscarguy, Oct 1, 2012.
  1. kscarguy
    kscarguy
    Does anyone know of an epoxy type primer with a soft green/grey color ?(similar to etching primer).
  2. pimtina
    pimtina
    PPG makes a light green epoxy primer, DP40 I think is it.
  3. writerDennis
    writerDennis
    PPG's DP40LF epoxy primer is gray-green.
  4. harleycontracter
    harleycontracter
    PPG DP40. I color matched it and painted the car in PPG Concept
  5. Spray Chief is white and you can tint it to whatever shade you want.
    <<< My coupe is sprayed with it.
  6. flt-blk
    flt-blk
    from IL
    this is DP green sealer. I can't remember if its DP90LF, DP40LF or which number it is.
    This is also after seveal years in the sun so it is a bit faded.
  7. HOTRODPRIMER
    HOTRODPRIMER
    NAPA offers one. HRP
  8. tudorkeith
    tudorkeith
    Not sure if it's still available but SEM had kind of an olive drab type or primer
  9. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    I believe that Squeege's is Green. Also, BASF has a pea green epoxy. I think it has EP .... in the number.
    VR&C.
  10. Lpdesignz
    Lpdesignz
    from Sin city
    Dp40 is the grey/green dp90 is black.. There a 2 part epoxy sealer not really a primer and only hold up for so long.. I would just get a high build primer and tint it such as ppg k36... Ppg used to offer a k-200 which was the best IMHO but I don't think it's available any more..
  11. MP&C
    MP&C
    House of Kolor epoxy primer, KP2-CF
  12. RodStRace
    RodStRace
  13. Lpdesignz
    Lpdesignz
    from Sin city
    Duponts vari-prime and ppg's dpx-171 acid etching primers are also a greenish color.. They stick like a champ to anything...
  14. CutawayAl
    CutawayAl
    from MI
    Yes, DP40. If that isn't quite what you want, white or grey DP primer can be tinted to suit you needs.
