Cast a car club plate today
Discussion in 'The Hokey Ass Message Board' started by Smokey, Sep 30, 2012.
  1. Smokey
    Smokey
    I didn’t realize this morning when I set out to cast up a car club plate for my car with the intention of posting it tonight that there would already be a post on aluminum casting today. So I hope this doesn’t make for too much casting **** for one day. I will keep mine real short and just show a couple photos of right after the pour and then a finished shot.
    Nice post Johnny Boy by the way.
    The purpose of this pour was to create a club plate that honors the former State highway 50 that runs past my place. It was probably one of the shortest state highways in Iowa, starting at Highway 169 and ending about 10 miles later at the end of main street in Lehigh. I have the original highway 50 sign, that used to grace the road on main street, hanging in my garage. I said former because a few years ago the state gave up rights to the highway and turned it over to the county and old Highway 50 was no more. So this is my “Hi-Way 50 Fords” plate I have been wanting to do for quite a while and I wanted it on my car for the Iron Invasion show.
    Shortly after the pour
    Finished and on the car, finally got my HAMB topper installed also
    Smokey
  2. lothiandon1940
    lothiandon1940
  3. IowaMercMan
    IowaMercMan
    Nice work Smokey! Is that aluminum, or pewter (like from your name plate thread)?
  4. mow too much
    mow too much
  5. dirtbag13
    dirtbag13
  6. Smokey
    Smokey
    Thanks to all
    IowaMercMan --
    I used aluminum for this plate. Pewter could have been used but would have been costly.
    Also in this case, aluminum would be much harder and hold up alot better.
    Smokey
  7. 19Fordy
    19Fordy
    Gosh, remember when we used to make those in high school shop cl***. You'd make the pattern, ram up the flask, pour the metal and smile when broke open the mold. Another popular item was 1932 headlite stanchions. But, those days are gone, for the most part.
  8. FFFFrank
    FFFFrank
    What did you make the plug out of?
  9. Johnny Boy
    Johnny Boy
    from Chicago
    I dont know about you but I'm hooked now, the amount of time spent to get to that point and you break open the mold the pour is successful is kick *** to say the least. Great job Smokey and see ya at the Invasion!
    Hey look for the U Boat!
  10. Smokey
    Smokey
    FFFFrank –
    The pattern for the plate was made from mdf. The main reason for this is it’s cheap and easy to work with. I coated it with about five coats of polyurethane. It builds up in the corners and gives them a radius to make it pull out of the sand better. I then coat it with spray on slip-plate, a graphite spray paint that farmers use to coat augers and wagon slides and such. Works great with talc parting dust for good release from the sand.
    Johnny Boy –
    Yes very addictive. Especially when you start thinking about all the things you want to make. My motto has become “why buy a part for $10 when you can make it yourself for $20”…….
    Nice car, that will be easy to spot. Look forward to talking with ya this weekend.
    Smokey
  11. FFFFrank
    FFFFrank
    So how do you make the MDF plate?
    I just so happen to have a shop full of laser cutting/engraving equipment so I could make these mold plates all day. Unfortunately, they don't work super well with MDF but there are plenty of other materials that I'm sure would work.
  12. K-88 ghost
    K-88 ghost
    from Nevada
    There's a side job for you, I'd bet you would get a ton of request's
    I for one have acouple of things in mind. :cool:
  13. Smokey
    Smokey
    **So how do you make the MDF plate?**
    Yea, I should have explained that. I use a couple of different methods. One is to use a router and I like to use a little formica (hard laminate) trimmer. It is small , very powerful, and easy to control. Another method I use is to just build up in layers. Both methods would have worked on this particular project, but I used the router. The inside of the plate was cut .100” deep and the outside surrounding the plate was cut .300” deep. This gives you a match plate type of affair, meaning the pattern is attached to a substrate which aids in the alignment of the pattern to the casting flask. As I mentioned in the previous post, several coats of polyurethane builds up around the details and you can get by without purposely putting any draft angle on the walls of the features. Like if you were to use a router bit with a 5 degree angle so you can extract it out of your molding sand.
    Helpful or too much mindless rambling?
    **There's a side job for you, I'd bet you would get a ton of request's
    I for one have acouple of things in mind.**
    I do requests from time to time. It’s usually when I can find spare time and if it’s different enough to be interesting. I do find the whole casting process a blast and fun to combine it with other processes.
    I located these from a few years ago here on the Hamb and they might be of some interest and another way to make a casting pattern.
    Part 1 http://www.jalopyjournal.com/forum/showthread.php?t=48504
    Part 2 http://www.jalopyjournal.com/forum/showthread.php?t=48868
    Part 3 http://www.jalopyjournal.com/forum/showthread.php?t=49040
    Smokey
  14. HotRodJosh
    HotRodJosh
    I saw these at the Iron Invasion. They looked great!
  15. Johnny Boy
    Johnny Boy
    from Chicago
    Met Smokey at the invasion and had a great conversation about pouring your own! Really great dude and wish I had more time to talk, maybe next year at the Invasion or at Vintage Torque Fest?
  16. Jalopy Joker
    Jalopy Joker
  17. 383deuce
    383deuce
    Now that is kick ***.......
