School me on MC bore size (and in the process help me solve my brake problem.)
Discussion in 'The Hokey Ass Message Board' started by FFFFrank, Sep 25, 2012.
  1. Mart
    Mart
    Seb, the area math is good, but the dual master cylinder stuff is wrong the dual cylinders are in tandem, the pressure is equal in both circuits to the single.
    Mart.
  2. FFFFrank
    FFFFrank
    Well finally had a chance to tinker and the new master from NAPA appears bad. Pumped it on my bench at least 100 times and no fluid coming out.
    Just my luck.....
    Sent from my DROID device using the TJJ mobile app
  3. cayager
    cayager
    rebuilt no doubt? have had same problems before . lots of good chinese rebuilds
  4. FFFFrank
    FFFFrank
    Nope. Brand new. The new one was only $4 more than the rebuilt so I thought I would be safe.
  5. bobss396
    bobss396
    Are you bleeding it correctly? Just wanted to rule that out first. Most masters I've bled took less than 10 pumps to bleed them.
    Either that or I'm astounded at the amount of bad rebuilt masters that are on the market.
    Bob
  6. FFFFrank
    FFFFrank
    Well, first I hooked up my bleed lines and bent them to return back into the reservoir. Pumped about 25 times and didn't get any fluid. Pulled the lines off and pumped another 25 or so times and not even a drip out of the ports. During the entire process only saw 2-3 air bubbles come up. ******!
  7. LesIsMore
    LesIsMore
    from Ohio
    You need a 10lb psi RPV if its a dual in front line and back line. Didnt reas whole thread, scratch this if you already do.
  8. bobss396
    bobss396
    I have my own method of bleeding masters. I place the master in my bemch vise, fill it up with brake fluid. I hold a thumb and forefinger over the ports, push the piston in with a screw driver, let it spring back and repeat until no bubbles come up in the reservoir.
    Top it off, put the top back on and install it and go on from there. Been unfailable in 40 years of doing it. I've probably seen 2-3 bad rebuilt masters out of the box, but maybe the quality ain't what it used to be.
    Bob
