Hot Rods Model A spindles
Discussion in 'The Hokey Ass Message Board' started by sygreaser, Oct 3, 2012.
  1. sygreaser
    sygreaser
    from SO-CAL
    I have Model A spindles and I have small bolt pattern Ford rims.. What brakes can I run on the A spindles that will accept the smaller bolt pattern?
    Thanks guys..
  2. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Volare rotors, but you need to make your own adaptors and brackets.
  3. 70's Barracuda (same I know, I just like the word) You use GM Calipers...there are whole or partial kits available.....just google......TCI kits or 37-48 brake kits
  4. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Model A and 37-48 spindles are different.
  5. 296 V8
    296 V8
    from Nor~Cal
    What exactly are "small bolt pattern Ford rims" and why use model A spindes.
  6. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    I'm "guessing" 5 on 4.5 bolt pattern, and probabley because he has A spindles, even though they are way more expensive to put kingpins in and arent designed for heavier cars.
  7. 296 V8
    296 V8
    from Nor~Cal
    why guess
    want help - ideas ........ give all details
    we cant see your car from here
  8. sygreaser
    sygreaser
    from SO-CAL
    hey guys sorry for lack of info.. the rims are 5 on 4.5 and the reason im using model A spindles is because i have them and im building my roadster on the cheap. so i was just wondering if theres an easy way to get my rims on those spindles. if not, whats a good set up run on my 37 ford axle?
  9. George Miller
    George Miller
    from NC usa
    I done it years ago, if memory is right, had to turn the spindle to fit the GM bearings, and use a spacer, because the spindle is to long.
  10. 296 V8
    296 V8
    from Nor~Cal
    You don’t say drum or disc brakes …… but either way you will have it a lot easier and probably less time and cost if you find some 37 - 48 spindles.
