Flathead Camshaft Suggestions ?
Discussion in 'The Hokey Ass Message Board' started by 1934calkid, Oct 4, 2012.
  1. 1934calkid
    1934calkid
    Here is whats on the engine stand, a 1951 merc flathead, 286 ci, 4 inch merc crank, weiand 4x2 intake,with 4 stromberg 48`s,jetted @.043, Kong Jackson twin plug heads and a nash twin 8 distributor, will be backed up with a 4sp transmission and a qc rearend, any suggestions for a cam from the experts out there ???? pics in my photo album tonight if I can figure it out LOL......
  2. Tank
    Tank
    An Isky 400 jr. always sounds healthy in my opinion. Drivability is pretty good too.
  3. 87Heaven
    87Heaven
    Check with "pete1" here on the HAMB. Old school cam grinder. He knows as much as anyone.
    For what you have so far "Potvin Elimenator" comes to mind:):)
  4. Tommy's Cycle
    Tommy's Cycle
    from So Cal
    Running a 400 jr in my 8CM and love it.
  5. flat 39
    flat 39
    Schneider F270.
  6. Russco
    Russco
    from Central IL
    X 2 on checking with Pete. I just built a 286 8BA and used a 1007B grind on Pete's advice. Its a pretty good choice it pulls realy well on bottom and midrange very strong smooth power, great for street driving I love it. (BTW if you get one from Isky you better check it with a degree wheel to make sure its ground correctly) here is a video of what it sounds like
  7. flatheadfreakv8
    flatheadfreakv8
    I ran a Isky max 1 in my flattie and i loved it
  8. fenderless
    fenderless
    from Norway
    Russco, your 1007B sounds really bad, nice:)!
    1934calkid, depends on what type of car, heavy or light?
    As stated before Pete1 knows.
    But you can consider a isky 404! :)
    Taildragger&fenderless
  9. flatheadkid1
    flatheadkid1
    from OHIO
    Potvin 3/8 or Isky 400JR
  10. Keither
    Keither
    Hard to beat a 400 JR.
  11. HotRodMicky
    HotRodMicky
    But who grinds one apart from Isky?
    Lots of guys have problems with Iskys beein out out of specs
  12. HotRodMicky
    HotRodMicky
    And 4x48 s are a lot for that size engine.
    3x2 with 97s would be better.
    So you need a big cam for all those carbs.
    Next is the Nash distriburor im stock fom will only be good to arond 3000 Rpms
    find points with stiffer springs
    Is the block ported properly?
    I would go for a Potvin 3/8s
    and change the 48s for 81s
  13. 1934calkid
    1934calkid
    distributor has been reworked to a higher rpm, thanks
  14. dan c
    dan c
    400 jr would be good in that mill. max 1 makes torque but i think would be better in a smaller/milder engine. you'll want to use isky/zephyr single springs (185 g) and the extra -length adjustable lifters. the 400 jr will give you beaucoup power above 40 mph!
  15. Litterio L100 cam with 4-71 lung on a 286 cube engine...
    <iframe width="420" height="315" src="http://www.youtube.com/embed/QK4xMplEhJw" frameborder="0" allowfullscreen></iframe>
    Rat
  16. Pete1
    Pete1
    from Wa.
    With all that neat stuff I would recommend an Eliminator unless you want to spend the money for a 404.
    The Eliminator will pull good right off the idle as long as you have good breathing.
  17. bobo1
    bobo1
    from France
    hello , I have 289ci flat with 400 jr it's very good , but now would like to blown it with a 4.71 can I keep the 400 jr with the blown 4.71 ?
  18. acme30
    acme30
    from Australia
    Sorry for the thread hijack - my understanding is yes you can - I have a blown flat motor (fully machined but not yet ***embled) and a well respected flathead guy in Aust recomended and ground a 400 jr for me.
    He could have ground to pretty much any specs but this was his recomendation.
    I appreciate than some on HAMB may disagree but I think that there is so much confilicting advice on here about flat motors that my advice would be to pick a knowledgeble flathead person that you respect and trust then take their advice and only their advice. At least that way you will get a matched motor;)
    PS Your English is better than my French - I could not even say blown flathead in french :)
  19. bobo1
    bobo1
    from France
    ok thank's for your answer
    Blown flathead in french is : flathead compressé ;)
