Turn signal lever shocks me why?
Discussion in 'The Hokey Ass Message Board' started by fisherboys, Oct 7, 2012.
  1. fisherboys
    fisherboys
    I finally got my truck going, the wiring is not completely done but the tail lghts,rear turn signals,brakes, four way flashers,headlights high and low beams and and the front signals work. The problem is that while I am holding the steering wheel (metal) and touch the turn signal lever at the same time I get a little tingeling shock---why? The steering column is ididit and an ez wiring harness. The horn is not on the truck yet, the wire for the horn is wired up under the seat right now. It may be touching something metal, would this cause this? tryin to think ahead so I can get this fixed this week. Any ideas?? Thanks Mark
  2. brigrat
    brigrat
    from Wa.St.
    Is your turn signal housing insulated or grounded to the column?
    My Dad had a '57 Ford Hard top retractable, every time you would rest your arm out the drivers window you would get a shock under the arm, thanks for the memory!
  3. 1949 caddyman
    1949 caddyman
    from arizona
    Sounds like static electricity on your body discharging when you touch the grounded metal turn signal handle.
  4. Sphynx
    Sphynx
    from Central Fl
    I dont know why but sounds like your getting AC current into your column.
  5. Try a bad ground When you touch the turn single lever you complete the circuit.
  6. GTS225
    GTS225
    Mark...is it a short, single jolt, or is it a continuing tingle?
    Roger
  7. fisherboys
    fisherboys
    It is a short single jolt. At first I thought I was imagining it but my son was driving it and he said the same thing. How canI tell if it is insulated or not. Not trying to be smart but wiring isnt my strong point as you can see? Thanks Mark
  8. For one,your not going to get a shock from 12v dc ... its either static or ignition current (post coil) .... open your hood in the dark
    and check your sparkplug/coil wires for arching
    jimmy six and Bob Lowry like this.
  9. brigrat
    brigrat
    from Wa.St.
    Not so sure about that.
    Do you get a shock when it's running, not running or both?
    Take a piece of wire with Allagator clips, ground the turn signal housing to the column and see what happens ...........................
  10. fisherboys
    fisherboys
    It only does it when it;s running. Tomorrow I'll try and ground it and see if that helps. It only does it when you turn the signal lever on to use the signal and touching the steering wheel at the same time. You can touch them both at the same time with no shock as long as you don't turn the signal on. Thanks Mark
    Elcohaulic likes this.
  11. themoose
    themoose
    Even though you don't have the horn hooked up you might have the horn relay installed in the fuse panel.The zap could be coming from the coil in the horn relay for the same reason the ignition coil puts out high voltage.
    When you energize the coil of wire in the horn relay, it builds up a magnetic field. That magnetism pulls on the contact that closes the circuit for the horn(s). When the circuit is broken, the magnetic field collapses, inducing voltage in the coil. Depending on the number of turns in the coil and the amount of current flowing through it, and thus the intensity of the magnetic field, the voltage induced in the coil can be quite large. Ignition coils have primary coils with a much smaller number of turns than the secondary coil. That's why they can generate thousands of volts to send to spark plugs from only 12 volts in the primary system. If you are somehow completing the circuit to the relay when you touch the signal light lever it might be using you as a path to ground.........Or NOT
    GeezersP15 likes this.
  12. fisherboys
    fisherboys
    The horn relay is mounted right next to the fuse box. Should it be mounted farther away from the fuse box?? It has about six to eight inches of wire, so it could be that much farther away. Thanks Mark
  13. Diavolo
    Diavolo
    Uhm, try using a volt meter? Just saying.
  14. fisherboys
    fisherboys
    I wouldn't know what exactly to check and where to hook it up if I had one
  15. sedanbob
    sedanbob
    I had a similar deal with my Ididit column, Haywire harness, in my '33 sedan. When it was running, sometimes (not always), I would get a small shock from the turn signal lever when I first turned on the signal. One difference, my horn is hooked up, and when I would get the shock, the horn would beep - once. I stopped happening, but I didn't do anything - maybe it was a bad ground that I inadvertantly fixed? Thinking about it just now, my shifter is on the column, and the shifter arm at the bottom of the column comes extremely close to the spark plug wires as they come around the left head - but that doesn't explain the shock only happening once.
  16. Ebbsspeed
    Ebbsspeed
    Folks, don't forget that the flasher relay for the turn signals does have a relay coil in it, so therefore it has a magnetic field that is collapsing and could cause a voltage spike. Wired wrong, or a short could possibly put this voltage spike onto the turn signal lever.
    And you can definitely feel a shock from 12 volts, especially it you've got sweaty body parts:eek:
    Hard to troubleshoot without details and some close-up shots of the turn signal switch, etc.
    Desoto291Hemi likes this.
  17. Commish
    Commish
    from NW Ok
    Used to mechanic for a living, I have been shocked countless times working under the hood, from 12 volt d c , it is very possible.
  18. Try this,,,grab onto the 12V DC pos & neg battery terminals of your car & have someone crank it over.
    I guarantee you'll never do it again.
    Sounds like somethings up with a relay as already suggested.
  19. davo461
    davo461
    X2
    12volts was bad enough; 24volts was quite painful. Davo.
  20. CharlieBlue22
    CharlieBlue22
    Old post, but appreciate the info. Shock on my aftermarket steering column started after i removed the harness from the column and installed an external ignition switch. Touch the turn signal and bam! The shock was definitely high-voltage. My guess is I removed the ground when I removed the harness. It isn’t spark coil, so I believe it is static generated from spinning front wheels. Regardless, grounding the column should tame the beast.
  21. Budget36
    Budget36
    Alrighty then!
