Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. 88daryl88
    88daryl88
    UKAde "Would love to see a picture of the whole engine" Thanks for asking. :D
    This is the 8hp.
    This is a TWELVE
    There are almost no Australian Manufactured, Pre-war, engines, suitable for automotive use except the Howard's.
    The 12hp. was built between 1934 & 1953 in Northmead, NSW.. They were exported worldwide.
    The 12hp has a bore: 98.425 mm. and stroke: 120.650 mm. Capacity: 918cc.
    Big enough for a small car...but it's a Twin.
    Total capacity: 1836cc !!!
  2. 88daryl88
    88daryl88
  3. 88daryl88
    88daryl88
    This is the little car I want to put it in.
  4. banjeaux bob
    banjeaux bob
    from alaska
    Daryl,thanks for showing us the Howard.Very interesting.
    Bob
  5. chuxx
    chuxx
    That motor is tough. Is it running a big ole tiller?
  6. UKAde
    UKAde
    from Oxford UK
    Nice engine, one of those would be great fun in an Austin 7 ch***is
  7. ebtm3
    ebtm3
    I agree,Ade, and thanks Daryl!
    Herb
  8. The37Kid
    The37Kid
  9. 88daryl88
    88daryl88
    Thanks Bob, it generally is best to find a Spe******t!!!:rolleyes:
    You do need to watch out for Howard Scams though.
    Chu**, Yes, it is running a big ole tiller. Here's a link to one in action. http://youtu.be/dSDaNh6NIgI
    Re: Austin 7 ch***is. Based on the engine supports, the little roadster probably had a small Austin engine in it at one time.
    I don't know all that much about it. I bought it from a fellow who got it from an old wrecking yard in Lismore, New South Wales.
    The painted number plate on the front apron is "all digits". These were last used in NSW in 1937. Unfortunately the NSW motor registration people do not release information on previous owner history.
    The general look is sort of late 20's early 30's. Curved cowl & dash are not very common. The hood is short, not long like most of the English sports cars. I've been trying to find a production car that the design could have been based on.
    The interesting feature is the tubular frame. There were not too many cars built before WW2 with this type of construction. The tubing is quite thin, like heavy exhaust tube. Some sections have been rolled to oval shape. It's not a triangulated space frame but just tubular rails and hoops & some braces. Two men can easily pick up & carry the body (with the rear springs only)
    The welding is all oxy-acetylene gas welded and some brazing. Panels are all tack welded to the tube structure. Seat has wooden bases and leather covering. Brakes were cable operated.
    Based on all the above I consider that it is a rather special, Australian, one-off, built pre-war and I want to fit a "suitable" drive train.
    There are plenty of little english flathead motors available, I was even offered a French OHV 7hp DFP but that wouldn't be special or particularly Aussie enough.
    Hence the Howard V-Twin engine.
    The whole thing is a "Bit of a *******" (an endearing, colloquial term):eek: and I don't think it could/should be posted anywhere better than this Tread. I hope you all agree.
    Cheers, Daryl.
  10. UKAde
    UKAde
    from Oxford UK
  11. UKAde
    UKAde
    from Oxford UK
    Got a few hours on the jappic yesterday in between daddydaycare
    Just doing the gearbox mounting crossmember and working on seat mounting setback bulkhead ,
    I need to get the driver in before the engine mounting as it is going to get a bit tight in the area
  12. UKAde
    UKAde
    from Oxford UK
    Just looking at my picture I think it's time to tidy my work bench
  13. ebtm3
    ebtm3
    A BIT tight???
    Herb
  14. banjeaux bob
    banjeaux bob
    from alaska
    There's a bench in the picture?
  15. UKAde
    UKAde
    from Oxford UK
    Jappic update today I tidied up so Bob can see my bench ,
    Made part to join gearbox x member to seatback bulkhead
    Dragged out the 600 sv engine which will be temp engine for the car until the correct 350 ohv twin port engine can be found
  16. Huvius
    Huvius
    from Colorado
  17. Huvius
    Huvius
    from Colorado
    I saw there was some discussion about the original Jappic engine.
    In one photo, it looks like it is a three valve head. One inlet, two exhaust.
  18. UKAde
    UKAde
    from Oxford UK
    The twin port engine had two valves one inlet and one exhaust but the exhaust exits through twin pipes
    http://kioteegarage.blogspot.co.uk/2011_10_01_archive.html. Pics here
  19. banjeaux bob
    banjeaux bob
    from alaska
    Ade,you should see my bench at work while I'm building an 18 speed Fuller transmission.I hate putting anything away,much wiping anything down before I do!
  20. banjeaux bob
    banjeaux bob
    from alaska
    Welcome to the HAMB and the Cyclecar thread Huvius!
  21. Huvius
    Huvius
    from Colorado
    Thanks!!
    Spent the last 15yrs or so in English guns and am starting to get the itch for some motoring.
    Had some OK cars int he past, Alfa Giulietta Sprint, '38 Ford 1ton pickup, BMW 3.0CS and a bunch more but now am thinking a 20's-30's car is where to go or a self build.
    Ade, I looked at the stills of the Jappic film and now see that it is a 2V twin port.
  22. banjeaux bob
    banjeaux bob
    from alaska
    A couple of Morgans in the Malvern Hills...
  23. I was prepared not to like the new Morgan at all (it isn't really a Morgan what with an S&S engine and no sliding pillar front suspension) but I like it a lot on its own terms. Would have one in a heart beat and £30k isn't that expensive for a handbuilt low volume car - easy to spend that on creating a replica.
  24. Ned Ludd
    Ned Ludd
    The engine doesn't bother me. After all, Morgan have used a variety of engines over the years, JAP, Ford, Standard, Fiat, Rover, etc. To my mind the S&S fits right in. I have more of a problem with how it is aspirated and sparked: I'd prefer a big SU and ****ogue power-transistor ignition.
    The sliding-pillar suspension is part of the traditional idiosyncratic Morgan (and Lancia, for that matter) character, though I have grave misgivings about the system as such. I can understand the considerations that probably originally led to the design, but I'd have liked to see a few layers of subsequent cleverness (as opposed to "progress") deposited upon it. The current set-up looks much the state of the art, but rather boring as a consequence.
  25. trooper32b
    trooper32b
    from Surrey, UK
    Hi,
    The Morgans suffered from rear wheel displacement in some cases because of the output of the 1000c.c. J.A.P. engine and the inertia that had to be overcome when launching the vehicle with two ocupants. Modern engineering has overcome that problem and do not doubt the performance of the 3 wheeler. These were genuine sports cars in their day, outperforming many more conventional compe***ors.
  26. James D
    James D
    The new Morgan Trike was tested on BBCs Top Gear, Series 18 Episode 6.
  27. banjeaux bob
    banjeaux bob
    from alaska
    Welcome to the HAMB and the cyclecar thread Trooper32B. From the looks of your avatar you might know Sancta Rosa!
    Bob
  28. Someone's ankles are gonna be BURNING :eek::D!!!
  29. Gofannon
    Gofannon
    Ade, are those the same **** they ran in speedway bikes? There was one for sale in NZ on the TradeMe auction site but I can't find it now. Must have got snapped up real quick. Complete bike, pre war engine in a later frame, built late 50's or early 60's, had about NZ$7000 on it if my vague memory serves me correctly. I'll let you know if I see it again.
  30. Gofannon
    Gofannon
