so i've been collecting parts
Discussion in 'The Hokey Ass Message Board' started by silent rick, Feb 12, 2012.
  1. TexasSpeed
    TexasSpeed
    from Texas
    Looking great! It's crazy how similar this is to the hot rod I want to build next.. Except mine won't have over head valves. :) You've come a long ways with your T. I'd say I can't wait to see it moving under its own power but I'm sure you feel much more strongly that way than I.
  2. rd martin
    rd martin
    from indiana
    looks good rick, glad to see it rolling.
  3. cool project! looking' great!
  4. Camaro Mike
    Camaro Mike
    Looking good Rick!
  5. wizzard23
    wizzard23
    Subscribed!!!!!!!!!!!!
  6. Thirdyfivepickup
    Thirdyfivepickup
    She's a beaut, Rick! You've definitely thought this one through. You're going to have to change your signature to read "must ride on lap" now.
  7. Chris 50
    Chris 50
    I was at Jason's the night the wheels got painted. I know I was a little jacked up on clear fumes, as were a couple other guys helping turn the wheels as Jay painted. Jason was worst of all, even with the mask on he was hurtin'. It's about time we had a fresh build or two coming together. Real cool man.
  8. silent rick
    silent rick
    chris, are you going to be able to stop by tonight? we can finalize plans for the iron invasion.
  9. NortonG
    NortonG
    Oh man! You're really making me wish I kept my '27!
  10. Chris 50
    Chris 50
    Don't think I'm going to make it tonight, but I'll send my representative to work out the details.
  11. silent rick
    silent rick
    big mitts norm?
  12. Chris 50
    Chris 50
    Is that a problem?
  13. chopz56
    chopz56
    Man i'm so out of the loop.....Rick it's really looking great!Now i have to get a day off so i can come look at the progress in person!Congrats on your work!
  14. magnet
    magnet
    It's looking good.. it's nice to see steady progress being made.
  15. silent rick
    silent rick
    i made the diamond shaped wishbone mounts for the front to match the rears. i need to do a little work on the frame before mounting them. right to the rear of where the front bones will mount is a triangle shaped raised portion. running board mount? anyway the diamond shaped mounts won't lay flat. i was going to cut out the raised portion and weld in a patch, then a friend suggested heating and hammering the frame flat. i haven't decided which way to go.
    i purchased some forged p&j dropped arms. i already whacked off the hole for cross steer setup. i'll touch it up with the grinder, sandblast and get a coat of paint on them. i need to get a tierod on it. it's a pain in the *** pushing it around when the front wheels want to go all googly.
    kidcampbell71 likes this.
  16. silent rick
    silent rick
    i mounted the headlights and made a U shaped mount for the radiator and grill shell.
    i want to do a wire mesh insert in the A shell, sort of protect the radiator some.
    the radiator will get rubber mounted.
  17. phat rat
    phat rat
    Nice to see how it's coming. But I gotta say it's also got me to saying to myself. "Why didn't I keep it?" If I'm remembering correctly you're right about the raised triangle on the frame.
  18. TexasSpeed
    TexasSpeed
    from Texas
    Looking really great, man.
  19. yetiskustoms
    yetiskustoms
  20. treb11
    treb11
    It might be too late, but could you make a set of tie rod mounts that attach right at the triangular mounting point? looks like you would have to extend the wishbones though
  21. Man thats lookin' good! I gotta say I'm jealous.
    Hate to derail but is that your Panhead in the back of those pictures? Can't tell what year it is but thats lookin' pretty damn good as well! :D
    Anyways, subscribed!
  22. silent rick
    silent rick
    the original plan had the bones' mounts side by side, back when the axle was going under the front crossmember, but then i couldn't get the ride height and stance i wanted. i moved the axle out in front of the crossmember to drop the front down a couple inches so that's where the rear mount ended up. i'm leaning towards heating it up and smacking it a few times.
  23. silent rick
    silent rick
    it's a 59. i had to swap over to a late 60's frame around 15 years ago.
  24. Damn I like that. I've always had a thing for Painheads ( :eek: ) my dad has a 48. Anyways thanks for the picture man, judging from your bike and the pictures so far this builds gonna be wicked.
  25. silent rick
    silent rick
    i made a couple of frames that fit inside the grill shell to stretch the wire mesh over and sandwich the mesh.
    i rubber mounted the radiator inside the frame i had made
    and then mounted the grill shell over everything
  26. silent rick
    silent rick
    i then turned my attention to the body mounts. i decided on six. why six, i do not know. i guess there's no kill like overkill.
    my friend killbilly gave me some rubber discs in various thicknesses. they're not too hard, not too soft. as goldilocks would say "that killbilly is a swell dude".
    the front four mounts were easy, i just welded some 1/4 inch plate between the frame and crossmember to weld my mounts to.
    the rear mounts needed another approach. i made stanchions off the frame for the last two mounts. i started with C channel.
    i shaped the ends with a cutoff wheel on my air grinder and shaped them with the electric 4 inch
    finished product
  27. silent rick
    silent rick
    body mounted and rolled out in the alley for some photos. i even popped on the v8 caps. shiney.
    kidcampbell71 and Tim_with_a_T like this.
  28. silent rick
    silent rick
    i made a cardboard pattern for the floor. thanks for the cardboard stinky
    i cut it out of some 13 gauge metal i have. i know it's heavy but i have a ton of it and it will help stiffen up the body. i took the piece over to steve, the offy guru, at gary bridge and iron and asked him to bend it for me. it fits very nice.
  29. Looks great!
  30. scrap metal 48
    scrap metal 48
    Nice work.. Very nice work...
