Hey peeps I'm in need of some info I have a 52 ford f1 with the 6 215ci I hate the stock ****** is there a newer trans I could swap in without to much trouble I hope you guys can give me tons of info thanks
John Mummert will do the conversion to the bellhousing that you provide him http://www.ford-y-block.com/truckt5.htm Or you can find a later bellhousing and use a later truck transmission. I'm not sure of all the details, but the 223 was made until 64 and it had the same bolt pattern on the block.
215's use the same trans as the flathead....as long as you have the 215 bell housing "ring", you can use a flathead/t5 adapter. 223's use a different trans setup. You will still need to make a new trans X member, driveshaft, etc...
