Current photos of modern day "Nostalgia" race cars
Discussion in 'The Hokey Ass Message Board' started by falcongeorge, Jun 22, 2011.
  1. rfraze
    rfraze
    I will try a different approach. Bill Fitting followed up with a blown gas 33 coupe. The body is one of Matt and George Travers, Morgan Hill, CA, Kicker Craft beauties. (black gelcoat pics Sears Point) The Fitting Co. ch***is experimented with torsion bars and carried a BBC. It ran A/GS in silver at The World G***er Championships. Also shown at Willys Roundup 94.
  2. rfraze
    rfraze
    The Varmit owned by Warren Bilbrey called Oakdale, CA home when this was shot at Pleasanton. 40 Willys coupe ran blown gas BBC at 5 lbs/cubic inch back in the last days of NDRA and second period of ANRA. Saw the car and Warren at Gateway G***er Gathering in St. Louis in '99 and found out that they had moved to Alabama or somewhere in the southeast.
    EVL401 likes this.
  3. redlinetoys
    redlinetoys
    from Midwest
  4. rfraze
    rfraze
    Thanks, Bob. Hang on as I try to work my way thru the west coast blown gas guys. (I mostly have pics of the west.) Any pics of Rick and Aggie Parrish's Aggravation Anglia, Howard Gottlieb's yellow Anglia, Chuck Young's Anglia and later Ute Scootin' Anglia Ute, Ray Caster's 39 Chev, Bob Clayton's Rat Infested 41 Willys, Gary Fore's black Willys, and Brian Stairs' Anglia posted will be appreciated. There are bound to be other 5 lb. blown GAS cars since the Fremont days. Then I will show naturally aspirated cars and ask for some help there. I WILL be covering the nostalgia cars that chose to run alcohol instead of gas, because "it was easier on parts", since their story continues. See aasupercharged.net. We can fill in the blanks between now and then.
  5. rfraze
    rfraze
    It's Magic '41 of Rich Williams, Windsor, CA. Blown Big Block. Photo: 1st- Willys Roundup 94. Second ? This car was said to have been around for some time. Never saw it run.
  6. rfraze
    rfraze
    Aggravation. Rick AND Aggie Parrish, Phelan,CA. The BBC sat back far enough that scoop came thru windshield. In the points in the final years of NDRA. Pics from one of their events at the old Vegas track. Mucho fun to watch. Why would you want a center line rule when Anglias are running?
  7. rfraze
    rfraze
    Rat-Infested, a blown gas BBC powered 41 Willys owned by BOB and DONNA CLAYTON, LaGrange,CA participated in NDRA and ANRA west coast events for many years. KS Pittman frequently tuned and occasionally drove this car. This car appears on most g***er videos. Additional pics appreciated. These are from Sears Point and Bakersfield.
    EVL401 likes this.
  8. rfraze
    rfraze
    RAY CASTOR ran a 39 Chev with a blown gas BBC out of San Leandro, CA. I am pretty sure this one came out to compete in The Fastest Street Rod cl*** (or Super Street) and ran infrequently in A Gas Eliminator (lovingly referred to as fruit salad) at Goodguys events. Efforts to run similar cars in separate cl***es only occurred once, at Pomona, with pretty good success. Rick Gold and Rhys Lloyd put a TON of effort into creating the Pacific Coast G***er ***ociation, using historically significant rules to separate similar cars into heads-up cl***es at second era ANRA events. This car could have competed in A/GS at either of these events.
    If you use your imagination, you can almost see Castor making a p*** at Sears Point.
    EVL401 likes this.
  9. rfraze
    rfraze
    Gary Hart and Ron Kilmer ran two 41 Willys out from Springfield, MO. Both supercharged gas, Hart's yellow coupe ran a Big Block w/carbs. Kilmer's 392 was fed by a 4 port Hilborn and turned a torqueflite. Recreating the g***er wars, putting on a show, and having a good time was their quest. Shown here at Sears Point. In '94 they faced off in the A/GS final at Denver, with Kilmer's trans giving up and Hart taking the ***le.
    EVL401 likes this.
  10. ags41dave
    ags41dave
    from midwest
    rfraze;Just some info,the Varmint car currently resides in Ohio and regularly runs in the g***er meets in northeast OH.the owner has health issues and someone else drives the car,he also runs an altered,and you may have seen him in 99 at the gateway g***er meet running a black 41 willys with flames,Dave
  11. FunnyCar65
    FunnyCar65
    from Colorado
    a couple of mine
  12. rfraze
    rfraze
    Thanks Dave. I would love to see current pics and get updated info. If they run it on gas, now would be the time to post. Thanks to Larry T, so far I have been talking about 5 lb./cubic inch blown gas cars that raced in a heads-up A/Gas Supercharged cl*** since nostalgia racing started. I'm thinking 85 or so, but there are clubs and tracks which have been putting on "vintage" events for quite a while. Many of those cars fit drag cars in motion thread. Some belong here. Larry T said pre 68 car post 68 photo. Helped me.
    If the Varmit runs alky, maybe they could wait til we get to g***ers on meth. That might be the time to open a new thread to debate "the g***ers on alcohol" deal. Be patient on that one, please.
  13. Larry T
    Larry T
    WHOA, if you're paying attention to anything I say you're probably messing up. You'd have to ask the guy who started the thread what belongs here. That was just my take on what I'd post here and a comment on that one particular car.
    But while we're talking about that post, did Stairs Beatnik run on pump gas, racing gas, or alcohol? I'm betting most of the guys that are close to the 8.00 mark run alcohol, just because it's easier to tune and easier on parts.
  14. rfraze
    rfraze
    Larry T, Stairs ran gas, probably racing gas, because he was a serious compe***or in a blown gas cl*** and, personally, honored the history. There was a fuel check and you had to roll across the scales at no less than 5 lbs./cubic inch. They would also check your engine size. Real racing. You are correct that some of the teams that brought out old cars in the early days of nostalgia racing chose to run methanol. Corn was food. It's not that there was anything wrong with making that decision, but doing so changed the deal. Quite literally, there was no cl*** name for g***ers on meth, yet. In the beginning, it did not matter too much. People were just playing with their cars. When the racing got serious, parity became a problem. Alcohol was easier, UNTIL guys started running it hard. The cars shown so far, chose gasoline. Few saw any reason to try and compete against blown alcohol cars. They could not figure out why all sanctioning bodies didn't run a blown gas cl***. The story continues.
  15. rfraze
    rfraze
    Here is another blown gas car in it's earliest stages. CHUCK and MARCELLA LIPKA's Willys at their Gateway event in 99. As did early A/GS cars, their's was evolving from an over-powered old car to the basis of the Geezer G***ers. (3 and 4) Read about them in Dec 12 Street Rodder mag.
    EVL401 and 550Coupe like this.
  16. colinschopshop
    colinschopshop
    I love these old race cars ! They are just so cool !
  17. colinschopshop
    colinschopshop
    NOW THAT'S AN ACTON PITCHER!
  18. rfraze
    rfraze
    Gotta love those fire burnouts! Here is a BLOWN GAS car/truck called UTE SCOOTIN', owned and built by CHUCK and SHARI YOUNG, Lancaster, CA. Chuck loved drag racing and Anglias. The candy burgundy Popular (still looking for a better pic) with blown BBC and Mike's Glide was a player in A/GS, because of Chuck's skill and dedication as a builder, tuner, and driver. It evolved from a naturally aspirated version which runner-upped in A/G at Denver WGC. As I recall, wind got the sedan at Vegas, so the drive train went into the Ute (Australian Anglia utility) which was already under construction. One of a kind and a potentially serious threat, Chuck and the Ute got quicker and quicker. Ran a best of 152. Head-on shot from 2000 March Meet. Cancer took this great racer and Shari found a good home for Ute Scootin' with Carlos and Mary Cedeno, NY, right along side King Kong.
  19. jimmy1931
    jimmy1931
    Got some new paint & striping on th '31.
      98.1 KB
    EVL401 likes this.
  20. hog mtn dave
    hog mtn dave
    Cool ride. Never seen that one before.
  21. Toymaker
    Toymaker
    from Fresno,CA
    A couple more of the TWIN at Eagle Field 10-6-12
  22. drofdar
    drofdar
    from Fresno Ca
    Joanna driving the 55 at Eagle Field two years ago. We will be running the altered "Demon" at A.N.R.A. this weekend. Great thread. I just love these "real deal" cars.
  23. Model A John
    Model A John
    from wichita ks
    Looks good, Jim.
  24. good friend of mine...taz 2 ....
    george and i at bakerfield
  25. AHotRod
    AHotRod
    Such a beautiful car and so tastefully done!
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    The Last Logghe altered got orange paint this year:
  27. hemigeorge
    hemigeorge
    Bowling Green 2012
  28. rfraze
    rfraze
    BLOWN GAS CARS - I am diggng for pictures, but not finding them. SO, I am inserting this reply that I can edit. I mentioned above names of cars I needed help with. Please post any pics you have of them.
    HOWARD and ANN GOTTLIEB, Northridge, CA, ran an Anglia named Blown Innocence. The name referred to his work as an attorney. No good guesses why it was previously named The B-Itch. A blown BBC powered this lane-changer, which last competed in ANRA and Pacific Coast G***er ***n. events. Howard put his engine in a Topolino altered and was seriously injured at Palmdale.
