What to do with a 241 hemi?
Discussion in 'The Hokey Ass Message Board' started by ironhill, Oct 9, 2012.
  1. ironhill
    ironhill
    from Simms, MT
    I happened upon an old 241 hemi, it's a truck hemi. Picked it up to put in one of my coupes. This would be my first hemi and any help would be greatly appreciated. Do any of the parts interchange with these early ones? As far as the water pump I see adapters for sbc pumps but what will work with that 4port factory setup? I've found some adapters already for ******s. Can't wait to get working on it! Thanks for any info!
  2. Go to Scooter's Hemi page on here...you'll choke on all the resources and info there. There are PLENTY of Hemi gurus on here - ask and you shall receive the knowledge!
  3. ironhill
    ironhill
    from Simms, MT
    Perfect just what I was looking for thanks!
  4. themoose
    themoose
    I had one in my 39 Chevy coupe a few years back that came out of a 53 Dodge. I Bored and balanced it and installed Jahns pistons,Crower cam and Weiand manifold with 4 "97's".I used the 3 speed with OD that came with Dodge.Great engine........I beat the hell out of it and it just kept asking for more
  5. George
    George
    There's a 241 build on webrodder. Custom pistons are needed, your truck engine is probably 6:1 in real C/R.
  6. Squablow
    Squablow
    The heads swap onto a 270 poly block and those are pretty plentiful, gives you more cubic inches. Pistons need to be replaced, but if you're rebuilding it anyway...
  7. sunbeam
    sunbeam
    I've got a bunch of low deck dodge parts pm me for needs.
  8. Marty Strode
    Marty Strode
    Here is a 241 with the Chev water pump installed, along with adapter to Ford trans.
  9. -Brent-
    -Brent-
    Sharp looking, Marty.
  10. If the lower end is solid as in doesn't need a bore etc I would leave it @ 6:1 and put a blower on it. At that compression ratio even with small bores you have lots of room to push air/fuel mix in there.
  11. CB_Chief
    CB_Chief
    from Oklahoma
    PB, I like the way you think. We just finished up building and installing a 355 ci 4 bolt SBC in my boys 58 Apache that was static 8.2 CR. We installed a Weiand 142 with a 4150 Holley running 7-8 psi boost and that thing really came alive when we hooked up the blower belt. It is worth every dollar it cost!
  12. HHH
    HHH
  13. RichFox
    RichFox
    I had this same question 50 years ago. This was the answer I came up with.
  14. gnichols
    gnichols
    from Tampa, FL
    That is so cool. Is this your work? Outside builder? Gary
  15. You can even overcome smallish ports with a blower, head work helps but if you can't or don't want to do a lot of port work you can force the mix through thee. :D
    Rich I have said it before but it is worh mention again. I just love that goofy looking little car. I wish you still had it or I did.
  16. CGkidd
    CGkidd
    Hey Marty what trans adapter is that?
  17. RichFox
    RichFox
    I did buy another Bantam about this time last year. A 37 or 8 pickup. It is making progress, but wont look much like the old one. But then i don't look much like i did either. 50 years. damn, it's hard to believe it went by that fast.
  18. You may have to put blisters on the doors, we are getting older ya know. ;)
  19. RichFox
    RichFox
    Oh I know. i keep hoping I'll grow up. Any way i look at it 70 is old. But then you go to Bonneville and 70 seems about normal.
  20. TR Waters
    TR Waters
    from Vermont
    You can adapt an aftermarket water pump, but you will still need to fabricate the upper crossover with thermostat housing between the heads.
  21. Von MoPar
    Von MoPar
    from Australia
    the 241 is a nice compact hemi....great for crusing all day
  22. 39 Ford
    39 Ford
    The 241 does not have provisions for side mounts it mounts from the front of the engine and will require a custom fabricated mount, other that that its a great engine. Parts are available but not cheep. Check E-Bay for intakes etc.
    My friend is doing one now and finding a useable cam was the hardest part, he ended up with a NOS Racer Brown mild grind.
  23. ironhill
    ironhill
    from Simms, MT
    Very nice! Looks good with the sbc water pump conversion
  24. ironhill
    ironhill
    from Simms, MT
    Thanks for all the great pics and info guys, dug into it a little tonight and so far so good nice and clean. Definitely going in a 't' or an 'a' coupe. Probably multiple carb, but a small blower would be nice too!
  25. Marty Strode
    Marty Strode
    Gary, This one of 9 Track Roadsters that I built, it has a Hot Heads front cover along with a front mount and header flanges for 1.5/8" pipe that I produce for the little Dodge. BTW it has 19,000 miles on it.
    CG kidd, That is an Offy adapter with a late 60's Ford trans with the T-150 Jeep top.
  26. gnichols
    gnichols
    from Tampa, FL
    ^That's just SO nice. Marty. Thanx, Gary
  27. Actually 70 @ B-Ville is slow unless you are on a mini bike. :D
    There is an upside to getting older that I have discovered as of late. We know some stuff, the down side is that we have absolutely no excuse for totally screwing up a car or a bike. I do hope to see 70 and I hope I see it from behind a wind screen.
  28. George
    George
    How about a "T & A coupe"?:):eek::cool:
  29. sunbeam
    sunbeam
    I'd thinking the compression is like the p*** cars at 7.1 and the pistons are more than likely T slots not the best with a suppercharger.
