How to patina a new alternator
Discussion in 'The Hokey Ass Message Board' started by tubbyTom, Oct 10, 2012.
  1. tubbyTom
    tubbyTom
    What is the best way to make a new alternator look old? Someone told me to use over cleaner?????Any suggestions?
  2. chaddilac
    chaddilac
    Take the guts out and put them in an old case!
  3. Abomb
    Abomb
    Trade it for a generator ???
  4. 327Eric
    327Eric
    leave it outside on the workbench under the eves. mine got the finish in 2 weeks. didn't want it, but oh well
  5. langy
    langy
    I can imagine the replys already :D
  6. 117harv
    117harv
    A quick search for threads with patina in the ***le pulled up 3 pages, several are closed. Many if not all of them have the info you seek:cool:
  7. Is it aluminum and not painted? Even if you put it on your engine fresh and new it will not look new very long. Or as has been said just leave it outside for a bit. its fall take it out in the yard and burry it in wet leaves, they will stain it real quick, like in a couple of days.
  8. BOWTIE BROWN
    BOWTIE BROWN
    Wash machine & dry on line . Works everytime .
  9. flatheadpete
    flatheadpete
    from Burton, MI
    Beat me to it.
  10. Blue One
    Blue One
    from Alberta
    Take an oxy acetylene torch and light the flame with acetylene only. Then generously blacken the case.
    Then take a large hammer and vigrously beat marks and small dents into the case.
    Then spray the whole works down with easy off oven cleaner and let it sit for several days.
    Then hose it off with lots of water and dry using old dirty shop rags. :D
    From this I suppose you can get the drift on my opinion when it comes to "patina"
  11. propwash
    propwash
    from Las Vegas
    I'm with "Blue One". Why are you getting all caught up in the 'patina' of an alternator? Patina connotes age...if it's NEW - install it - the age will accrue in due time. Do you 'patina' your tires? I get SOOOOO tired of this patina silliness. Painting cars/trucks and then spending time sanding it so it looks old. How phoney is that? Do you 25yr-olds put grey IN your hair? Do you wrinkle your skin on purpose? That's patina. Quit jumping on the bandwagon of every flash-in-the-pan fad that comes along, gee whiz.
  12. I don't try to hide my chit I just run it and let the chips fall where they may.
    I did run some dummy wires from a one wire once to an old burnt out regulater to see how many people would notice that it was a one wire and not an externally regulated atlernator. :D
  13. 61TBird
    61TBird
  14. HomemadeHardtop57
    HomemadeHardtop57
    Haha
  15. BISHOP
    BISHOP
  16. 61TBird
    61TBird
    Then give it a good rub down with Dryer Sheets...
  17. notaford1
    notaford1
    from webster ny
    Yep..Easy Off oven cleaner works great on aluminum.....makes it look old and nasty in no time
  18. PBRmeASAP
    PBRmeASAP
    damn it, you beat me to that idea...
  19. Pimpin37zephyr
    Pimpin37zephyr
    I'm with propwash, if you want old, buy old. Otherwise your fake. Sorry I mean your a poser.
  20. zibo
    zibo
    from dago ca
    An easy way is to position your radiator overflow hose over the alternator,
    run the car nice and hot.
    You want to boil it over and really **** out the grime in the block.
    If you're lucky the coolant is nice and brown,
    this leaves the most realistic patina.
    Hopefully you have a lifetime warranty at O-reilly so the gift just keeps giving!
    TP
  21. ParkinsonSpeed
    ParkinsonSpeed
    Dollar store oven cleaner will stain anything if you leave it on there.... I thought it would be awesome to just spray on a old junk motor to clean up but then my ADD kicked in and i had some real patina real quick even on a brand new holley carb....
